About Modbus library file.
1,360 次查看
Pavankumar1
Hi, I am working on the MXRT1176 controller, I need to implement Modbus RTU protocol using RS485, is there any Modbus library avaliable for RT1176 controller.
1,342 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, unfortunately, there is no library from NXP for Modbus. I suggest searching on the community if someone shares the library.
Pavel
1,336 次查看
Pavankumar1
Thank you Pavel for you replay, Please share any other modbus library that will support RT1176 controller. and You have any idea how to port Freemodbus library into mcuxpresso IDE.
