if I set 2 pins' pinMux to I2C, and set their padCtrl as 22K pull-up, Open-drained, is it ok?
5angxr
there are 2 Slaves & 1 Master on I2C bus except RT1042,
no External pull-up resistance on the bus.
Does I2C work in this case?
5angxr
Or I don't need to set I2C pin pads to open-drained? Setting them as push-pull meets the requirements.
Gavin_Jia
Hi @5angxr ,
Thanks for your interest in NXP MIMXRT series!
For the I2C bus, SCL and SDA pin must be open-drain and pull-up. Push-pull outputs cannot be used.
Gavin
