Recognition model for microcontroller use
In the SDK_2.7.0_EVKB-IMXRT1050, it contains some eIQ machine learning demo projects, there's the tensorflow_lite_kws among them.
It's a keyword spotting example that is based on Keyword spotting for Microcontrollers and it deploys a deepwise separable convolutional neural network called MobileNet in this demo project. It can classify a one-second audio clip as either silence, an unknown word, "yes", "no", "up", "down", "left", "right", "on", "off", "stop", or "go".
Figure 1 shows the components that comprise it.
Fig 1
Training Our New Model
The model we are using is trained with the TensorFlow script which is designed to demonstrate how to build and train a model for audio recognition using TensorFlow.
The script makes it very easy to train an audio recognition model. Among other things, it allows us to do the following:
  1. Download a dataset with audio featuring 20 spoken words.
  2. Choose which subset of words to train the model on.
  3. Specify what type of preprocessing to use on the audio.
  4. Choose from several different types of the model architecture.
  5. Optimize the model for microcontrollers using quantization.
When we run the script, it downloads the dataset, trains a model, and outputs a file representing the trained model. We then use some other tools to convert this file into the correct form for TensorFlow Lite.
Training in virtual machine (VM)
Preparation
Make sure the TensorFlow has been installed, and since the script downloads over 2GB of training data, it'll need a good internet connection and enough free space on the machine.
Note that: The training process itself can take several hours, be patient.
Training
To begin the training process, use the following commands to clone ML-KWS-for-MCU.
git clone https://github.com/ARM-software/ML-KWS-for-MCU.git‍‍‍‍‍‍
The training scripts are configured via a bunch of command-line flags that control everything from the model’s architecture to the words it will be trained to classify.
The following command runs the script that begins training. You can see that it has a lot of command-line arguments:
python ML-KWS-for-MCU/train.py --model_architecture ds_cnn --model_size_info 5 64 10 4 2 2 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 \
--wanted_words=zero, one, two, three, four, five, six, seven, eight, nine \
--dct_coefficient_count 10 --window_size_ms 40 \
--window_stride_ms 20 --learning_rate 0.0005,0.0001,0.00002 \
--how_many_training_steps 10000,10000,10000 \
--data_dir=./speech_dataset --summaries_dir ./retrain_logs --train_dir ./speech_commands_train ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Some of these, like --wanted_words=zero, one, two, three, four, five, six, seven, eight, nine. By default, the selected words are yes, no, up, down, left, right, on, off, stop, go, but we can provide any combination of the following words, all of which appear in our dataset:
  • Common commands: yes, no, up, down, left, right, on, off, stop, go, backward, forward, follow, learn
  • Digits zero through nine: zero, one, two, three, four, five, six, seven, eight, nine
  • Random words: bed, bird, cat, dog, happy, house, Marvin, Sheila, tree, wow
Others set up the output of the script, such as --train_dir=/content/speech_commands_train, which defines where the trained model will be saved. Leave the arguments as they are, and run it. The script will start off by downloading the Speech Commands dataset (Figure 2), which consists of over 105,000 WAVE audio files of people saying thirty different words. This data was collected by Google and released under a CC BY license, and you can help improve it by contributing five minutes of your own voice. The archive is over 2GB, so this part may take a while, but you should see progress logs, and once it's been downloaded once you won't need to do this step again. You can find more information about this dataset in this Speech Commands paper.
Fig 2
Once the downloading has completed, some more output will appear. There might be some warnings, which you can ignore as long as the command continues running. Later, you'll see logging information that looks like this (Figure 3).
Fig 3
This shows that the initialization process is done and the training loop has begun. You'll see that it outputs information for every training step. Here's a break down of what it means:
  • Step shows that we're on the step of the training loop. In this case, there are going to be 30,000 steps in total, so you can look at the step number to get an idea of how close it is to finishing.
  • rate is the learning rate that's controlling the speed of the network's weight updates. Early on this is a comparatively high number (0.0005), but for later training cycles it will be reduced 5x, to 0.0001, then to 0.00002 at last.
  • accuracy is how many classes were correctly predicted on this training step. This value will often fluctuate a lot, but should increase on average as training progresses. The model outputs an array of numbers, one for each label, and each number is the predicted likelihood of the input being that class. The predicted label is picked by choosing the entry with the highest score. The scores are always between zero and one, with higher values representing more confidence in the result.
  • cross-entropy is the result of the loss function that we're using to guide the training process. This is a score that's obtained by comparing the vector of scores from the current training run to the correct labels, and this should trend downwards during training.
  • checkpoint
    After a hundred steps, you should see a line like this:
    This is saving out the current trained weights to a checkpoint file (Figure 4). If your training script gets interrupted, you can look for the last saved checkpoint and then restart the script with --start_checkpoint=/tmp/speech_commands_train/best/ds_cnn_xxxx.ckpt-400 as a command line argument to start from that point .
Fig 4
  • Confusion Matrix
    After four hundred steps, this information will be logged:
    The first section is a confusion matrix. To understand what it means, you first need to know the labels being used, which in this case are "silence", "unknown", "zero", "one", "two", "three", "four", "five", "six", "seven", "eight", and "nine". Each column represents a set of samples that were predicted to be each label, so the first column represents all the clips that were predicted to be silence, the second all those that were predicted to be unknown words, the third "zero", and so on.
    Each row represents clips by their correct, ground truth labels. The first row is all the clips that were silence, the second clips that were unknown words, the third "zero", etc.
    This matrix can be more useful than just a single accuracy score because it gives a good summary of what mistakes the network is making. In this example you can see that all of the entries in the first row are zero (Figure 5), apart from the initial one. Because the first row is all the clips that are actually silence, this means that none of them were mistakenly labeled as words, so we have no false negatives for silence. This shows the network is already getting pretty good at distinguishing silence from words.
    If we look down the first column though, we see a lot of non-zero values. The column represents all the clips that were predicted to be silence, so positive numbers outside of the first cell are errors. This means that some clips of real spoken words are actually being predicted to be silence, so we do have quite a few false positives.
    A perfect model would produce a confusion matrix where all of the entries were zero apart from a diagonal line through the center. Spotting deviations from that pattern can help you figure out how the model is most easily confused, and once you've identified the problems you can address them by adding more data or cleaning up categories.
                                                           Fig 5
  • Validation
    After the confusion matrix, you should see a line like Figure 5 shows.
    It's good practice to separate your data set into three categories. The largest (in this case roughly 80% of the data) is used for training the network, a smaller set (10% here, known as "validation") is reserved for evaluation of the accuracy during training, and another set (the last 10%, "testing") is used to evaluate the accuracy once after the training is complete.
    The reason for this split is that there's always a danger that networks will start memorizing their inputs during training. By keeping the validation set separate, you can ensure that the model works with data it's never seen before. The testing set is an additional safeguard to make sure that you haven't just been tweaking your model in a way that happens to work for both the training and validation sets, but not a broader range of inputs.
    The training script automatically separates the data set into these three categories, and the logging line above shows the accuracy of model when run on the validation set. Ideally, this should stick fairly close to the training accuracy. If the training accuracy increases but the validation doesn't, that's a sign that overfitting is occurring, and your model is only learning things about the training clips, not broader patterns that generalize
Training Finished
In general, training is the process of iteratively tweaking a model’s weights and biases until it produces useful predictions. The training script writes these weights and biases to checkpoint files (Figure 6).
Fig 6
A TensorFlow model consists of two main things:
  • The weights and biases resulting from training
  • A graph of operations that combine the model’s input with these weights and biases to produce the model’s output
At this juncture, our model’s operations are defined in the Python scripts, and its trained weights and biases are in the most recent checkpoint file. We need to unite the two into a single model file with a specific format, which we can use to run inference. The process of creating this model file is called freezing—we’re creating a static representation of the graph with the weights frozen into it.
To freeze our model, we run a script that is called as follows:
python ML-KWS-for-MCU/freeze.py --model_architecture ds_cnn --model_size_info 5 64 10 4 2 2 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 \
--window_stride_ms 20 --checkpoint ./speech_commands_train/best/ds_cnn_9490.ckpt-21600 \
--output_file=./ds_cnn.pb‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
To point the script toward the correct graph of operations to freeze, we pass some of the same arguments we used in training. We also pass a path to the final checkpoint file, which is the one whose filename ends with the total number of training steps.
The frozen graph will be output to a file named ds_cnn.pb. This file is the fully trained TensorFlow model. It can be loaded by TensorFlow and used to run inference. That’s great, but it’s still in the format used by regular TensorFlow, not TensorFlow Lite.
Convert to TensorFlow Lite
Conversion is a easy step: we just need to run a single command. Now that we have a frozen graph file to work with, we’ll be using toco, the command-line interface for the TensorFlow Lite converter.
toco --graph_def_file=./ds_cnn.pb --output_file=./ds_cnn.tflite \
--input_shapes=1,49,10,1 --input_arrays=Reshape_1 --output_arrays='labels_softmax' \
--inference_type=QUANTIZED_UINT8 --mean_values=227 --std_dev_values=1 \
--change_concat_input_ranges=false \
--default_ranges_min=-6 --default_ranges_max =6‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
In the arguments, we specify the model that we want to convert, the output location for the TensorFlow Lite model file, and some other values that depend on the model architecture. we also provide some arguments (inference_type, mean_values, and std_dev_values) that instruct the converter how to map its low-precision values into real numbers.
The converted model will be written to ds_cnn.tflite, this a fully formed TensorFlow Lite model!
Create a C array
We’ll use the xxd command to convert a TensorFlow Lite model into a C array in the following.
xxd -i ./ds_cnn.tflite > ./ds_cnn.h
cat ./ds_cnn.h‍‍‍‍‍‍‍‍
The final part of the output is the file’s contents, which are a C array and an integer holding its length, as follows:
Fig 7
Next, we’ll integrate this newly trained model with the tensorflow_lite_kws project.
Using the Model in tensorflow_lite_kws Project
To use the new model, we need to do two things:
  1. In source/ds_cnn_s_model.h, replace the original model data with our new model.
  2. Update the label names in source/kws.cpp with our new ''zero'', ''one'', ''two'', ''three'', ''four'', ''five'', ''six'', ''seven'', ''eight'' and ''nine'' labels.
const std::string labels[] = {"Silence", "Unknown","zero", "one", "two", "three","four", "five", "six", "seven","eight", "nine"};‍‍‍
Before running the model in the EVKB-IMXRT1050 board (Figure 8), please refer to the readme.txt to do the preparation, in further, the file also demonstrates the steps of testing, please follow them.
Fig 8
Figure 9 shows the testing I did, I've attached the model file, please give a try by yourself.
Fig 9
Labels (2)
Comments
@jeremyzhou, First of all thanks for this example. I bought the board and followed the instructions to add KSW to IMXRT1050 board. I am stuck at final stage at section:
I cant find source/ds_cnn_s_model.h to replace the trained ds_cnn.h. I have searched online and in downloaded SDK_2.7.0_EVKB-IMXRT1050. There is no kws_tensorflow_lite example nor directory in it.
Appreciate your quick help here.
Hi ,
In the MCUXpreeso, expand the source fold on the Workspace window, you can see the ds_cnn_s_mode.h, as below shows.
BR,
Jeremy
Thanks jeremyzhou for your quick response. My problem is that I cant find the project kws_tensorflow_lite. Your screen shot shows only the source folder. Not sure how you got the source folder in your IDE? Which project is it? Can you please share the link to that?
I have searched the downloaded MCUExpresso IDE workspace folder (C:\Users\B2F\Documents\MCUXpressoIDE_11.1.1_3241\workspace) which came with all examples, but no luck. Is there some kind of version mismatch?
As I point out at the beginning of this article, the tensorflow_lite_kws demo is from the SDK_2.7.0_EVKB-IMXRT1050, and you can download this SDK library via the below link. Then install the SDK library in the MCUXpreeso IDE, after that, you can load the  tensorflow_lite_kws demo.
So please give a try.
https://mcuxpresso.nxp.com/en/welcome
BR,
Jeremy
jeremyzhou‌, turns out I had followed all the steps but never selected eiq while building the SDK and hence it was missing.
Now that I have it, I cant import any of eiq examples including tensorflow_lite_kws
"tensorflow_lite_kws] The project 'tensorflow_lite_kws' refers to the external XML file, but it cannot be found!"
On eiq
Thanks for your reply.
It seems a bit weird, I've not encountered it before.pastedImage_1.pngird,
So I'd like to suggest you delete the installed SDK library and clean-up the projects in the workspace directory, then build a complete new SDK library (as below shows), then install it to the MCUXpresso IDE.
After doing that, reimport the eIQ demos again.
BR,
Jeremy
Yes Only selecting eid with tensorflow_lite_kws worked great. I am able to test deault Keywords and the 0 to 9. Just that the recognition is not very accurate.
Also do you know if I can increase the label size from 12 to 20? Where I can add numbers to existing buffer, combining both models data? I tried but didnt work.
Do you have any project where you used the display in your picture above based on KSW? I am trying to display the output on the screen rather than on Tera Term.
Hi ,
1) Do you know if I can increase the label size from 12 to 20?
-- Yes, you can, however, it needs to train a completely new model for that, and the article has already demonstrated the training procedure.
2) Do you have any project where you used the display in your picture above based on KSW?
-- In the SDK library, there're some GUI demos, maybe you can refer to them.
BR,
Jeremy
%3CLINGO-SUB%20id%3D%22lingo-sub-1103364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERecognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EIn%20the%20SDK_2.7.0_EVKB-IMXRT1050%2C%20it%20contains%20some%20eIQ%20machine%20learning%20demo%20projects%2C%20there's%20the%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Etensorflow_lite_kws%3C%2FSTRONG%3E%3C%2FSPAN%3E%20among%20them.%3CBR%20%2F%3EIt's%20a%20keyword%20spotting%20example%20that%20is%20based%20on%20%3CA%20href%3D%22https%3A%2F%2Farxiv.org%2Fpdf%2F1711.07128.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EKeyword%20spotting%20for%20Microcontrollers%3C%2FA%3E%20and%20it%20deploys%20a%20deepwise%20separable%20convolutional%20neural%20network%20called%20MobileNet%20in%20this%20demo%20project.%20It%20can%20classify%20a%20one-second%20audio%20clip%20as%20either%20silence%2C%20an%20unknown%20word%2C%20%22yes%22%2C%20%22no%22%2C%20%22up%22%2C%20%22down%22%2C%20%22left%22%2C%20%22right%22%2C%20%22on%22%2C%20%22off%22%2C%20%22stop%22%2C%20or%20%22go%22.%3CBR%20%2F%3EFigure%201%20shows%20the%20components%20that%20comprise%20it.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%20style%3D%22width%3A%20839px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97314i659F7052ABD670C1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.jpg%22%20alt%3D%22pastedImage_1.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EFig%201%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId-380577421%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-380577421%22%20id%3D%22toc-hId-1297632841%22%3E%3CSPAN%20class%3D%22%22%3ETraining%20Our%20New%20Model%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EThe%20model%20we%20are%20using%20is%20trained%20with%20the%20TensorFlow%20script%20which%20is%20designed%20to%20demonstrate%20how%20to%20build%20and%20train%20a%20model%20for%20audio%20recognition%20using%20TensorFlow.%3CBR%20%2F%3EThe%20script%20makes%20it%20very%20easy%20to%20train%20an%20audio%20recognition%20model.%20Among%20other%20things%2C%20it%20allows%20us%20to%20do%20the%20following%3A%3C%2FP%3E%3COL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3EDownload%20a%20dataset%20with%20audio%20featuring%2020%20spoken%20words.%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3EChoose%20which%20subset%20of%20words%20to%20train%20the%20model%20on.%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3ESpecify%20what%20type%20of%20preprocessing%20to%20use%20on%20the%20audio.%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3EChoose%20from%20several%20different%20types%20of%20the%20model%20architecture.%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3EOptimize%20the%20model%20for%20microcontrollers%20using%20quantization.%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EWhen%20we%20run%20the%20script%2C%20it%20downloads%20the%20dataset%2C%20trains%20a%20model%2C%20and%20outputs%20a%20file%20representing%20the%20trained%20model.%20We%20then%20use%20some%20other%20tools%20to%20convert%20this%20file%20into%20the%20correct%20form%20for%20TensorFlow%20Lite.%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId--1426877042%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--1426877042%22%20id%3D%22toc-hId--509821622%22%3E%3CSPAN%20class%3D%22%22%3ETraining%20in%20virtual%20machine%20(VM)%3C%2FSPAN%3E%3C%2FH1%3E%3CDIV%20class%3D%22%22%20style%3D%22overflow%3A%20hidden%3B%20float%3A%20right%3B%22%3E%3CA%20id%3D%22preparation_3%22%20name%3D%22preparation_3%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CA%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20float%3A%20right%3B%20width%3A%201px%3B%20height%3A%200px%3B%20visibility%3A%20hidden%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CA%20id%3D%22preparation%22%20name%3D%22preparation%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CA%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20float%3A%20right%3B%20width%3A%201px%3B%20height%3A%200px%3B%20visibility%3A%20hidden%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FDIV%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId--736315568%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--736315568%22%20id%3D%22toc-hId-180739852%22%3E%3CSPAN%20class%3D%22%22%3EPreparation%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EMake%20sure%20the%20TensorFlow%20has%20been%20installed%2C%20and%20since%20the%20script%20downloads%20over%202GB%20of%20training%20data%2C%20it'll%20need%20a%20good%20internet%20connection%20and%20enough%20free%20space%20on%20the%20machine.%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3ENote%20that%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EThe%20training%20process%20itself%20can%20take%20several%20hours%2C%20be%20patient.%3C%2FP%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId-1751197265%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-1751197265%22%20id%3D%22toc-hId--1626714611%22%3E%3CSPAN%20class%3D%22%22%3ETraining%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3ETo%20begin%20the%20training%20process%2C%20use%20the%20following%20commands%20to%20clone%20ML-KWS-for-MCU.%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%3Egit%20clone%20https%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3Egithub%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecom%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3EARM%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esoftware%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3EML%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EKWS%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EMCU%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egit%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EThe%20training%20scripts%20are%20configured%20via%20a%20bunch%20of%20command-line%20flags%20that%20control%20everything%20from%20the%20model%E2%80%99s%20architecture%20to%20the%20words%20it%20will%20be%20trained%20to%20classify.%3CBR%20%2F%3EThe%20following%20command%20runs%20the%20script%20that%20begins%20training.%20You%20can%20see%20that%20it%20has%20a%20lot%20of%20command-line%20arguments%3A%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%3Epython%20ML%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EKWS%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EMCU%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etrain%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epy%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_architecture%20ds_cnn%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_size_info%20%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewanted_words%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Ezero%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20one%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20two%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20three%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20four%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20five%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20six%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20seven%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20eight%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20nine%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edct_coefficient_count%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_size_ms%20%3CSPAN%20class%3D%22number%20token%22%3E40%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_stride_ms%20%3CSPAN%20class%3D%22number%20token%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elearning_rate%20%3CSPAN%20class%3D%22number%20token%22%3E0.0005%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0.0001%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0.00002%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ehow_many_training_steps%20%3CSPAN%20class%3D%22number%20token%22%3E10000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E10000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E10000%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edata_dir%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Espeech_dataset%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esummaries_dir%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eretrain_logs%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Etrain_dir%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Espeech_commands_train%20%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3ESome%20of%20these%2C%20like%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E--wanted_words%3Dzero%2C%20one%2C%20two%2C%20three%2C%20four%2C%20five%2C%20six%2C%20seven%2C%20eight%2C%20nine%3C%2FSTRONG%3E%3C%2FSPAN%3E.%20By%20default%2C%20the%20selected%20words%20are%20yes%2C%20no%2C%20up%2C%20down%2C%20left%2C%20right%2C%20on%2C%20off%2C%20stop%2C%20go%2C%20but%20we%20can%20provide%20any%20combination%20of%20the%20following%20words%2C%20all%20of%20which%20appear%20in%20our%20dataset%3A%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3ECommon%20commands%3C%2FSTRONG%3E%3C%2FSPAN%3E%3A%20yes%2C%20no%2C%20up%2C%20down%2C%20left%2C%20right%2C%20on%2C%20off%2C%20stop%2C%20go%2C%20backward%2C%20forward%2C%20follow%2C%20learn%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3EDigits%20zero%20through%20nine%3C%2FSTRONG%3E%3C%2FSPAN%3E%3A%20zero%2C%20one%2C%20two%2C%20three%2C%20four%2C%20five%2C%20six%2C%20seven%2C%20eight%2C%20nine%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3ERandom%20words%3C%2FSTRONG%3E%3C%2FSPAN%3E%3A%20bed%2C%20bird%2C%20cat%2C%20dog%2C%20happy%2C%20house%2C%20Marvin%2C%20Sheila%2C%20tree%2C%20wow%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EOthers%20set%20up%20the%20output%20of%20the%20script%2C%20such%20as%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E--train_dir%3D%2Fcontent%2Fspeech_commands_train%3C%2FSTRONG%3E%3C%2FSPAN%3E%2C%20which%20defines%20where%20the%20trained%20model%20will%20be%20saved.%20Leave%20the%20arguments%20as%20they%20are%2C%20and%20run%20it.%20%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThe%20script%20will%20start%20off%20by%20downloading%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fstorage.cloud.google.com%2Fdownload.tensorflow.org%2Fdata%2Fspeech_commands_v0.02.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%22%20target%3D%22_blank%22%3ESpeech%20Commands%20dataset%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E(Figure%202)%2C%20which%20consists%20of%20over%20105%2C000%20WAVE%20audio%20files%20of%20people%20saying%20thirty%20different%20words.%20This%20data%20was%20collected%20by%20Google%20and%20released%20under%20a%20CC%20BY%20license%2C%20and%20you%20can%20help%20improve%20it%20by%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Faiyprojects.withgoogle.com%2Fopen_speech_recording%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%22%20target%3D%22_blank%22%3Econtributing%20five%20minutes%20of%20your%20own%20voice%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E.%20The%20archive%20is%20over%202GB%2C%20so%20this%20part%20may%20take%20a%20while%2C%20but%20you%20should%20see%20progress%20logs%2C%20and%20once%20it's%20been%20downloaded%20once%20you%20won't%20need%20to%20do%20this%20step%20again.%20You%20can%20find%20more%20information%20about%20this%20dataset%20in%20this%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Farxiv.org%2Fabs%2F1804.03209%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESpeech%20Commands%20paper%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97882i3BCEC497EC888AF9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-align%3A%20center%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EFig%202%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EOnce%20the%20downloading%20has%20completed%2C%20some%20more%20output%20will%20appear.%20There%20might%20be%20some%20warnings%2C%20which%20you%20can%20ignore%20as%20long%20as%20the%20command%20continues%20running.%20Later%2C%20you'll%20see%20logging%20information%20that%20looks%20like%20this%20(Figure%203).%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97982iFEF96213CAE542E6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EFig%203%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThis%20shows%20that%20the%20initialization%20process%20is%20done%20and%20the%20training%20loop%20has%20begun.%20You'll%20see%20that%20it%20outputs%20information%20for%20every%20training%20step.%20Here's%20a%20break%20down%20of%20what%20it%20means%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3EStep%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eshows%20that%20we're%20on%20the%20step%20of%20the%20training%20loop.%20In%20this%20case%2C%20there%20are%20going%20to%20be%2030%2C000%20steps%20in%20total%2C%20so%20you%20can%20look%20at%20the%20step%20number%20to%20get%20an%20idea%20of%20how%20close%20it%20is%20to%20finishing.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Erate%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20the%20learning%20rate%20that's%20controlling%20the%20speed%20of%20the%20network's%20weight%20updates.%20Early%20on%20this%20is%20a%20comparatively%20high%20number%20(0.0005)%2C%20but%20for%20later%20training%20cycles%20it%20will%20be%20reduced%205x%2C%20to%200.0001%2C%20then%20to%200.00002%20at%20last.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Eaccuracy%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20how%20many%20classes%20were%20correctly%20predicted%20on%20this%20training%20step.%20This%20value%20will%20often%20fluctuate%20a%20lot%2C%20but%20should%20increase%20on%20average%20as%20training%20progresses.%20The%20model%20outputs%20an%20array%20of%20numbers%2C%20one%20for%20each%20label%2C%20and%20each%20number%20is%20the%20predicted%20likelihood%20of%20the%20input%20being%20that%20class.%20The%20predicted%20label%20is%20picked%20by%20choosing%20the%20entry%20with%20the%20highest%20score.%20The%20scores%20are%20always%20between%20zero%20and%20one%2C%20with%20higher%20values%20representing%20more%20confidence%20in%20the%20result.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Ecross-entropy%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20the%20result%20of%20the%20loss%20function%20that%20we're%20using%20to%20guide%20the%20training%20process.%20This%20is%20a%20score%20that's%20obtained%20by%20comparing%20the%20vector%20of%20scores%20from%20the%20current%20training%20run%20to%20the%20correct%20labels%2C%20and%20this%20should%20trend%20downwards%20during%20training.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Echeckpoint%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3EAfter%20a%20hundred%20steps%2C%20you%20should%20see%20a%20line%20like%20this%3A%3CBR%20%2F%3EThis%20is%20saving%20out%20the%20current%20trained%20weights%20to%20a%20checkpoint%20file%20(Figure%204).%20If%20your%20training%20script%20gets%20interrupted%2C%20you%20can%20look%20for%20the%20last%20saved%20checkpoint%20and%20then%20restart%20the%20script%20with%20--start_checkpoint%3D%2Ftmp%2Fspeech_commands_train%2Fbest%2Fds_cnn_xxxx.ckpt-400%20as%20a%20command%20line%20argument%20to%20start%20from%20that%20point%20.%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F98663i9D2F03283C331648%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3EFig%204%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3EConfusion%20Matrix%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EAfter%20four%20hundred%20steps%2C%20this%20information%20will%20be%20logged%3A%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThe%20first%20section%20is%20a%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FConfusion_matrix%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%22%20target%3D%22_blank%22%3Econfusion%20matrix.%3C%2FA%3E%20%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3ETo%20understand%20what%20it%20means%2C%20you%20first%20need%20to%20know%20the%20labels%20being%20used%2C%20which%20in%20this%20case%20are%20%22silence%22%2C%20%22unknown%22%2C%20%22zero%22%2C%20%22one%22%2C%20%22two%22%2C%20%22three%22%2C%20%22four%22%2C%20%22five%22%2C%20%22six%22%2C%20%22seven%22%2C%20%22eight%22%2C%20and%20%22nine%22.%20Each%20column%20represents%20a%20set%20of%20samples%20that%20were%20predicted%20to%20be%20each%20label%2C%20so%20the%20first%20column%20represents%20all%20the%20clips%20that%20were%20predicted%20to%20be%20silence%2C%20the%20second%20all%20those%20that%20were%20predicted%20to%20be%20unknown%20words%2C%20the%20third%20%22zero%22%2C%20and%20so%20on.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EEach%20row%20represents%20clips%20by%20their%20correct%2C%20ground%20truth%20labels.%20The%20first%20row%20is%20all%20the%20clips%20that%20were%20silence%2C%20the%20second%20clips%20that%20were%20unknown%20words%2C%20the%20third%20%22zero%22%2C%20etc.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThis%20matrix%20can%20be%20more%20useful%20than%20just%20a%20single%20accuracy%20score%20because%20it%20gives%20a%20good%20summary%20of%20what%20mistakes%20the%20network%20is%20making.%20In%20this%20example%20you%20can%20see%20that%20all%20of%20the%20entries%20in%20the%20first%20row%20are%20zero%20(Figure%205)%2C%20apart%20from%20the%20initial%20one.%20Because%20the%20first%20row%20is%20all%20the%20clips%20that%20are%20actually%20silence%2C%20this%20means%20that%20none%20of%20them%20were%20mistakenly%20labeled%20as%20words%2C%20so%20we%20have%20no%20false%20negatives%20for%20silence.%20This%20shows%20the%20network%20is%20already%20getting%20pretty%20good%20at%20distinguishing%20silence%20from%20words.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EIf%20we%20look%20down%20the%20first%20column%20though%2C%20we%20see%20a%20lot%20of%20non-zero%20values.%20The%20column%20represents%20all%20the%20clips%20that%20were%20predicted%20to%20be%20silence%2C%20so%20positive%20numbers%20outside%20of%20the%20first%20cell%20are%20errors.%20This%20means%20that%20some%20clips%20of%20real%20spoken%20words%20are%20actually%20being%20predicted%20to%20be%20silence%2C%20so%20we%20do%20have%20quite%20a%20few%20false%20positives.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EA%20perfect%20model%20would%20produce%20a%20confusion%20matrix%20where%20all%20of%20the%20entries%20were%20zero%20apart%20from%20a%20diagonal%20line%20through%20the%20center.%20Spotting%20deviations%20from%20that%20pattern%20can%20help%20you%20figure%20out%20how%20the%20model%20is%20most%20easily%20confused%2C%20and%20once%20you've%20identified%20the%20problems%20you%20can%20address%20them%20by%20adding%20more%20data%20or%20cleaning%20up%20categories.%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F99321i966B3F04207F8247%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Fig%205%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3EValidation%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EAfter%20the%20confusion%20matrix%2C%20you%20should%20see%20a%20line%20like%20Figure%205%20shows.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EIt's%20good%20practice%20to%20separate%20your%20data%20set%20into%20three%20categories.%20The%20largest%20(in%20this%20case%20roughly%2080%25%20of%20the%20data)%20is%20used%20for%20training%20the%20network%2C%20a%20smaller%20set%20(10%25%20here%2C%20known%20as%20%22validation%22)%20is%20reserved%20for%20evaluation%20of%20the%20accuracy%20during%20training%2C%20and%20another%20set%20(the%20last%2010%25%2C%20%22testing%22)%20is%20used%20to%20evaluate%20the%20accuracy%20once%20after%20the%20training%20is%20complete.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThe%20reason%20for%20this%20split%20is%20that%20there's%20always%20a%20danger%20that%20networks%20will%20start%20memorizing%20their%20inputs%20during%20training.%20By%20keeping%20the%20validation%20set%20separate%2C%20you%20can%20ensure%20that%20the%20model%20works%20with%20data%20it's%20never%20seen%20before.%20The%20testing%20set%20is%20an%20additional%20safeguard%20to%20make%20sure%20that%20you%20haven't%20just%20been%20tweaking%20your%20model%20in%20a%20way%20that%20happens%20to%20work%20for%20both%20the%20training%20and%20validation%20sets%2C%20but%20not%20a%20broader%20range%20of%20inputs.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThe%20training%20script%20automatically%20separates%20the%20data%20set%20into%20these%20three%20categories%2C%20and%20the%20logging%20line%20above%20shows%20the%20accuracy%20of%20model%20when%20run%20on%20the%20validation%20set.%20Ideally%2C%20this%20should%20stick%20fairly%20close%20to%20the%20training%20accuracy.%20If%20the%20training%20accuracy%20increases%20but%20the%20validation%20doesn't%2C%20that's%20a%20sign%20that%20overfitting%20is%20occurring%2C%20and%20your%20model%20is%20only%20learning%20things%20about%20the%20training%20clips%2C%20not%20broader%20patterns%20that%20generalize%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId--56257198%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--56257198%22%20id%3D%22toc-hId-860798222%22%3E%3CSPAN%20class%3D%22%22%3ETraining%20Finished%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EIn%20general%2C%20training%20is%20the%20process%20of%20iteratively%20tweaking%20a%20model%E2%80%99s%20weights%20and%20biases%20until%20it%20produces%20useful%20predictions.%20The%20training%20script%20writes%20these%20weights%20and%20biases%20to%20checkpoint%20files%20(Figure%206).%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20664px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F99323i8CA980C3337257F9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-align%3A%20center%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EFig%206%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EA%20TensorFlow%20model%20consists%20of%20two%20main%20things%3A%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3EThe%20weights%20and%20biases%20resulting%20from%20training%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3EA%20graph%20of%20operations%20that%20combine%20the%20model%E2%80%99s%20input%20with%20these%20weights%20and%20biases%20to%20produce%20the%20model%E2%80%99s%20output%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EAt%20this%20juncture%2C%20our%20model%E2%80%99s%20operations%20are%20defined%20in%20the%20Python%20scripts%2C%20and%20its%20trained%20weights%20and%20biases%20are%20in%20the%20most%20recent%20checkpoint%20file.%20We%20need%20to%20unite%20the%20two%20into%20a%20single%20model%20file%20with%20a%20specific%20format%2C%20which%20we%20can%20use%20to%20run%20inference.%20The%20process%20of%20creating%20this%20model%20file%20is%20called%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Efreezing%3C%2FSTRONG%3E%3C%2FSPAN%3E%E2%80%94we%E2%80%99re%20creating%20a%20static%20representation%20of%20the%20graph%20with%20the%20weights%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Efrozen%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Einto%20it.%3CBR%20%2F%3ETo%20freeze%20our%20model%2C%20we%20run%20a%20script%20that%20is%20called%20as%20follows%3A%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%3Epython%20ML%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EKWS%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EMCU%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Efreeze%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epy%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_architecture%20ds_cnn%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_size_info%20%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewanted_words%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Ezero%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20one%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20two%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20three%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20four%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20five%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20six%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20seven%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20eight%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20nine%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edct_coefficient_count%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_size_ms%20%3CSPAN%20class%3D%22number%20token%22%3E40%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_stride_ms%20%3CSPAN%20class%3D%22number%20token%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Echeckpoint%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Espeech_commands_train%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebest%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn_9490%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eckpt%3CSPAN%20class%3D%22number%20token%22%3E-21600%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eoutput_file%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epb%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3ETo%20point%20the%20script%20toward%20the%20correct%20graph%20of%20operations%20to%20freeze%2C%20we%20pass%20some%20of%20the%20same%20arguments%20we%20used%20in%20training.%20We%20also%20pass%20a%20path%20to%20the%20final%20checkpoint%20file%2C%20which%20is%20the%20one%20whose%20filename%20ends%20with%20the%20total%20number%20of%20training%20steps.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThe%20frozen%20graph%20will%20be%20output%20to%20a%20file%20named%20ds_cnn.pb.%20This%20file%20is%20the%20fully%20trained%20TensorFlow%20model.%20It%20can%20be%20loaded%20by%20TensorFlow%20and%20used%20to%20run%20inference.%20That%E2%80%99s%20great%2C%20but%20it%E2%80%99s%20still%20in%20the%20format%20used%20by%20regular%20TensorFlow%2C%20not%20TensorFlow%20Lite.%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId--66760302%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--66760302%22%20id%3D%22toc-hId-850295118%22%3E%3CSPAN%20class%3D%22%22%3EConvert%20to%20TensorFlow%20Lite%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EConversion%20is%20a%20easy%20step%3A%20we%20just%20need%20to%20run%20a%20single%20command.%20Now%20that%20we%20have%20a%20frozen%20graph%20file%20to%20work%20with%2C%20we%E2%80%99ll%20be%20using%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Etoco%3C%2FSTRONG%3E%3C%2FSPAN%3E%2C%20the%20command-line%20interface%20for%20the%20TensorFlow%20Lite%20converter.%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%3Etoco%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Egraph_def_file%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epb%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eoutput_file%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Etflite%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Einput_shapes%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E49%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Einput_arrays%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3EReshape_1%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eoutput_arrays%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E'labels_softmax'%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Einference_type%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3EQUANTIZED_UINT8%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emean_values%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E227%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Estd_dev_values%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Echange_concat_input_ranges%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Efalse%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edefault_ranges_min%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edefault_ranges_max%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E6%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EIn%20the%20arguments%2C%20we%20specify%20the%20model%20that%20we%20want%20to%20convert%2C%20the%20output%20location%20for%20the%20TensorFlow%20Lite%20model%20file%2C%20and%20some%20other%20values%20that%20depend%20on%20the%20model%20architecture.%20we%20also%20provide%20some%20arguments%20(inference_type%2C%20mean_values%2C%20and%20std_dev_values)%20that%20instruct%20the%20converter%20how%20to%20map%20its%20low-precision%20values%20into%20real%20numbers.%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThe%20converted%20model%20will%20be%20written%20to%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Eds_cnn.tflite%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%2C%20this%20a%20fully%20formed%20TensorFlow%20Lite%20model!%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId-623801172%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-623801172%22%20id%3D%22toc-hId-1540856592%22%3E%3CSPAN%20class%3D%22%22%3ECreate%20a%20C%20array%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EWe%E2%80%99ll%20use%20the%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Exxd%3C%2FSTRONG%3E%3C%2FSPAN%3E%20command%20to%20convert%20a%20TensorFlow%20Lite%20model%20into%20a%20C%20array%20in%20the%20following.%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%3Exxd%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ei%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Etflite%20%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eh%0Acat%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eh%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EThe%20final%20part%20of%20the%20output%20is%20the%20file%E2%80%99s%20contents%2C%20which%20are%20a%20C%20array%20and%20an%20integer%20holding%20its%20length%2C%20as%20follows%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20667px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F98022i2319213B6B5879C7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EFig%207%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3ENext%2C%20we%E2%80%99ll%20integrate%20this%20newly%20trained%20model%20with%20the%20tensorflow_lite_kws%20project.%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId-613298068%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-613298068%22%20id%3D%22toc-hId-1530353488%22%3E%3CSPAN%20class%3D%22%22%3EUsing%20the%20Model%20in%20tensorflow_lite_kws%20Project%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3ETo%20use%20the%20new%20model%2C%20we%20need%20to%20do%20two%20things%3A%3C%2FSPAN%3E%3C%2FP%3E%3COL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3EIn%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Esource%2Fds_cnn_s_model.h%3C%2FSTRONG%3E%3C%2FSPAN%3E%2C%20replace%20the%20original%20model%20data%20with%20our%20new%20model.%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3EUpdate%20the%20label%20names%20in%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Esource%2Fkws.cpp%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ewith%20our%20new%20''zero''%2C%20''one''%2C%20''two''%2C%20''three''%2C%20''four''%2C%20''five''%2C%20''six''%2C%20''seven''%2C%20''eight''%20and%20''nine''%20labels.%3C%2FLI%3E%3C%2FOL%3E%3CPRE%20class%3D%22language-cpp%20line-numbers%22%3E%3CCODE%3E%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20std%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Estring%20labels%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22Silence%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22Unknown%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22zero%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22one%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22two%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22three%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22four%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22five%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22six%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22seven%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22eight%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22nine%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EBefore%20running%20the%20model%20in%20the%20EVKB-IMXRT1050%20board%20(Figure%208)%2C%20please%20refer%20to%20the%20readme.txt%20to%20do%20the%20preparation%2C%20in%20further%2C%20the%20file%20also%20demonstrates%20the%20steps%20of%20testing%2C%20please%20follow%20them.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F98282i6A2913C5EAFC5CD7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.jpg%22%20alt%3D%22pastedImage_6.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EFig%208%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EFigure%209%20shows%20the%20testing%20I%20did%2C%20I've%20attached%20the%20model%20file%2C%20please%20give%20a%20try%20by%20yourself.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20697px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97939i1898215A432AFE52%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EFig%209%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20105x%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MXRT%20106x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply.%3CBR%20%2F%3E1)%20Do%20you%20know%20if%20I%20can%20increase%20the%20label%20size%20from%2012%20to%2020%3F%3CBR%20%2F%3E--%20Yes%2C%20you%20can%2C%20however%2C%20it%20needs%20to%20train%20a%20completely%20new%20model%20for%20that%2C%20and%20the%20article%20has%20already%20demonstrated%20the%20training%20procedure.%3CBR%20%2F%3E2)%20Do%20you%20have%20any%20project%20where%20you%20used%20the%20display%20in%20your%20picture%20above%20based%20on%20KSW%3F%3CBR%20%2F%3E--%20In%20the%20SDK%20library%2C%20there're%20some%20GUI%20demos%2C%20maybe%20you%20can%20refer%20to%20them.%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%20Only%20selecting%20eid%20with%20tensorflow_lite_kws%20worked%20great.%20I%20am%20able%20to%20test%20deault%20Keywords%20and%20the%200%20to%209.%20Just%20that%20the%20recognition%20is%20not%20very%20accurate.%3CBR%20%2F%3EAlso%20do%20you%20know%20if%20I%20can%20increase%20the%20label%20size%20from%2012%20to%2020%3F%20Where%20I%20can%20add%20numbers%20to%20existing%20buffer%2C%20combining%20both%20models%20data%3F%20I%20tried%20but%20didnt%20work.%3CBR%20%2F%3EDo%20you%20have%20any%20project%20where%20you%20used%20the%20display%20in%20your%20picture%20above%20based%20on%20KSW%3F%20I%20am%20trying%20to%20display%20the%20output%20on%20the%20screen%20rather%20than%20on%20Tera%20Term.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply.%3CBR%20%2F%3EIt%20seems%20a%20bit%20weird%2C%20I've%20not%20encountered%20it%20before.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113133i72442911719A92CC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3Eird%2C%26nbsp%3B%3C%2FP%3E%3CP%3ESo%20I'd%20like%20to%20suggest%20you%20delete%20the%20installed%20SDK%20library%20and%20clean-up%20the%20projects%20in%20the%20workspace%20directory%2C%20then%20build%20a%20complete%20new%20SDK%20library%20(as%20below%20shows)%2C%20then%20install%20it%20to%20the%20MCUXpresso%20IDE.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113134i1AC8E326B3383BC9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAfter%20doing%20that%2C%20reimport%20the%20eIQ%20demos%20again.%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjeremyzhou%22%20target%3D%22_blank%22%3Ejeremyzhou%3C%2FA%3E%E2%80%8C%2C%20turns%20out%20I%20had%20followed%20all%20the%20steps%20but%20never%20selected%20eiq%20while%20building%20the%20SDK%20and%20hence%20it%20was%20missing.%26nbsp%3B%3CBR%20%2F%3ENow%20that%20I%20have%20it%2C%20I%20cant%20import%20any%20of%20eiq%20examples%20including%20tensorflow_lite_kws%3CBR%20%2F%3E%22tensorflow_lite_kws%5D%20The%20project%20'tensorflow_lite_kws'%20refers%20to%20the%20external%20XML%20file%2C%20but%20it%20cannot%20be%20found!%22%3CBR%20%2F%3EOn%20eiq%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113088iB9DE2F78CD26AEAF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EAs%20I%20point%20out%20at%20the%20beginning%20of%20this%20article%2C%20the%20tensorflow_lite_kws%20demo%20is%20from%20the%20SDK_2.7.0_EVKB-IMXRT1050%2C%20and%20you%20can%20download%20this%20SDK%20library%20via%20the%20below%20link.%20Then%20install%20the%20SDK%20library%20in%20the%20MCUXpreeso%20IDE%2C%20after%20that%2C%20you%20can%20load%20the%26nbsp%3B%20tensorflow_lite_kws%20demo.%20%3CBR%20%2F%3ESo%20please%20give%20a%20try.%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fwelcome%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fwelcome%3C%2FA%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjeremyzhou%22%20target%3D%22_blank%22%3Ejeremyzhou%3C%2FA%3E%20for%20your%20quick%20response.%20My%20problem%20is%20that%20I%20cant%20find%20the%20project%20kws_tensorflow_lite.%20Your%20screen%20shot%20shows%20only%20the%20source%20folder.%20Not%26nbsp%3Bsure%20how%20you%20got%20the%20source%20folder%20in%20your%20IDE%3F%20Which%20project%20is%20it%3F%20Can%20you%20please%20share%20the%20link%20to%20that%3F%26nbsp%3B%3CBR%20%2F%3EI%20have%20searched%20the%20downloaded%20MCUExpresso%20IDE%20workspace%20folder%20(C%3A%5CUsers%5CB2F%5CDocuments%5CMCUXpressoIDE_11.1.1_3241%5Cworkspace)%20which%20came%20with%20all%20examples%2C%20but%20no%20luck.%20Is%20there%20some%20kind%20of%20version%20mismatch%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3EIn%20the%20MCUXpreeso%2C%20expand%20the%20source%20fold%20on%20the%20Workspace%20window%2C%20you%20can%20see%20the%20ds_cnn_s_mode.h%2C%20as%20below%20shows.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20383px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F112724iEEA538B90C01FD80%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Recognition%20model%20for%20microcontroller%20use%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%40%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22213424%22%20data-username%3D%22jeremyzhou%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjeremyzhou%22%20style%3D%22color%3A%20%2353aaea%3B%20background-color%3A%20%23181a1b%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.9994px%3B%22%20target%3D%22_blank%22%3Ejeremyzhou%3C%2FA%3E%3CSPAN%20style%3D%22background-color%3A%20%23181a1b%3B%20color%3A%20%23c4c0b7%3B%22%3E%2C%20First%20of%20all%20thanks%20for%20this%20example.%20I%20bought%20the%20board%20and%20followed%20the%20instructions%20to%20add%20KSW%20to%20IMXRT1050%20board.%20I%20am%20stuck%20at%20final%20stage%20at%20section%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20data-darkreader-inline-bgcolor%3D%22%22%20data-darkreader-inline-color%3D%22%22%20style%3D%22color%3A%20%232f2f2f%3B%20background-color%3A%20%23f7f7f7%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%22%20id%3D%22toc-hId-380577422%22%20id%3D%22toc-hId--277100975%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2028px%3B%22%3EUsing%20the%20Model%20in%20tensorflow_lite_kws%20Project%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23181a1b%3B%20color%3A%20%23c4c0b7%3B%22%3EI%20cant%20find%26nbsp%3B%3CSTRONG%20class%3D%22%22%20style%3D%22color%3A%20%23d7d4ce%3B%20background-color%3A%20%231b1c1d%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2016px%3B%22%3Esource%2Fds_cnn_s_model.h%20to%20replace%20the%20trained%20ds_cnn.h.%20I%20have%20searched%20online%20and%20in%20downloaded%26nbsp%3B%3CSPAN%20style%3D%22font-weight%3A%20400%3B%22%3ESDK_2.7.0_EVKB-IMXRT1050.%20There%20is%20no%20kws_tensorflow_lite%20example%20nor%20directory%20in%20it.%3CBR%20%2F%3E%3CBR%20%2F%3EAppreciate%20your%20quick%20help%20here.%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-10-2020 01:48 AM
Updated by:
