why CAAM enable will IO hung format SDcard when disk encrypted
1,128 次查看
xu_ji1
In i.MX6Q we find CAAM enable will IO hung format SDcard when disk encrypted,
after disable CAAM,format SDcard will not hung,why CAAM caused this?
1,121 次查看
Hi xu_ji1
what bsp used in the case, may be suggested to test with latest 5.4.70_2.3.0
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_5.4.70_2.3.0
Documentation:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
Regarding "disable CAAM", there are limitations described in sect.8.1.7 Limitations
i.MX Linux Reference Manual​
1,118 次查看
xu_ji1
we used 4.14.98_2.3.0 BSP
1,112 次查看
 4.14.98_2.3.0 BSP does not support i.MX6Q  as described on below link
column "Supported Platforms"
