weston.ini is invalid
songhongliang
HI,
I set export XDG_CONFIG_DIRS="/etc/xdg/"  And configure weston.ini, but the configured parameters do not work, invalid,
E.g,
vi /etc/xdg/weston/weston.ini
#[shell]
#size=1920x1080
panel-location=none
background-color=0x00FFFFFF
Can you tell me what if modifying the parameters does not work?
joanxie
how did you configure westion.ini? what do you mean configured parameters doesn't work? what do you expect?
