where is busybox 1.32 source code  in yocto linux ?
2,464 次查看
jackey267
hello nxp :
1 where is busybox 1.32 source code  in yocto linux ?  how to find the source code location?
2 we are going to know how does cansend /candump   work . it's need to review they source code .
3 how to debug the cansend/candump on imx8qxpc0 board (which tools gdb or sth else ?).
thanks.
5 回复数
2,457 次查看
jimmychan
which version of bsp are you using?
In my bsp, I found the source is located :
can-utils
<yocto folder>/<build folder>/tmp/work/cortexa35-poky-linux/can-utils/2020.12.0-r0/git
busybox
<yocto folder>/<build folder>/tmp/work/cortexa35-poky-linux/busybox/1.33.1-r0
2,455 次查看
jackey267
1 thank you for your care .
2 how to debug with the cansend/ candump  on IMX8QXPC0board ?
3which tools should be use?
4 embed linux kernel : LF 5.10.9.1.0.0  with yocto
thanks
2,447 次查看
jimmychan
2,444 次查看
jackey267
that link seems to be expired.
can you check it ?
thanks
2,441 次查看
jimmychan
I can open the link. The link is work.
