webkit/html5
webkit/html5
3,091 次查看
PlartiNuhtl
Did anyone ever try using the Qt Webkit HTML5 support on the imx53? Can Qt Webkit work together with Gstreamer? Is it possible to play HTML5 videos using Webkit+Gstreamer?
Any answer would be appreciated.
标记 (2)
2,814 次查看
rogerio_silva
I just built QT with webkit support.
You can see if webkit will be built by adding --verbose on configure command. It will provide you a list of what will be included or not on your build.
Rgds
Rogerio
2,814 次查看
PlartiNuhtl
Thanks for your answer. Is there something special you had to do to get it running or was it just compiling qt with webkit support?
2,814 次查看
rogerio_silva
I made a video showing HTML5 running on QT Webkit and i.MX51. Check on link: http://www.youtube.com/watch?v=wSTRczc4QH8
I wasn't able to run videos yet.
Rgds,
Rogerio
