usb host stack support for 4G modem device
1,853 次查看
sbabu
Dear All,
Just wanted to check if the USB host stack available in MCUXpresso SDK supports 4G modem type devices. Also SFTP protocol as i don't see any SFTP protocol in lwip stack in the SDK.
Babu
1,820 次查看
sbabu
Hi Chavira,
We are using MX RT1024.
Subash
4 回复数
1,745 次查看
EdwinHz
Hi again @sbabu,
I believe this Application Note will be useful for your inquiry: https://www.nxp.com/docs/en/application-note/AN13940.pdf
1,770 次查看
EdwinHz
Hi @sbabu,
The SFTP protocol is not supported. As for the 4G modem type devices, I believe it depend on the USB class type required for your modem. As long as it is a supported class, it should be OK.
BR,
Edwin.
1,829 次查看
Chavira
Thank you for contacting NXP support!
Are you using iMX8 or iMXRT?
1,821 次查看
sbabu
Hi Chavira,
Subash
