Previously I've used ltib and kernel 2.6.35 with g_ether running fine.
After I downloaded kernel 3.7.0
make mxs_defconfig
make menuconfig (enable usb ethernet gadget)
make -j4 uImage modules
make INSTALL_MOD_PATH=$ROOTFSDIR modules_install (using rootfs generated by ltib)
When running modprobe g_ether on target with my new kernel i get the following message:
modprobe: failed to load module g_ether (/lib/modules/3.7.0-04111-g9977d9b-dirty/kernel/drivers/usb/gadget/g_ether.ko): No such device
I get the same result if i insmod /lib/modules/.../g_ether.ko
Am I missing a step?
Cheers,
Lars
