unable to compile the newly added files in the android source code while building the android image
1,712 次查看
mutyalaraoneela
HI,
     Iam not able to see the binaries of my newly added folder in the android source code in kitkat 4.4.3_2.0.0 in EXECUTABLES while building the source code.But at the time of building I am able to see it including the Android.mk file of my folder but not compiling the "c" files in that particular folder.Iam using 12.04 ubuntu (64bit).
Please help me in getting out of this.Waiting for positive reply.
Thank you,
Mutyala rao.
4 回复数
1,626 次查看
sanshanzhang
Can you share your Android.mk?
1,626 次查看
jimmychan
here is the example:
LOCAL_PATH:=$(call my-dir)
include $(CLEAR_VARS)
LOCAL_SRC_FILES:= helloworld.c
LOCAL_MODULE:= helloworld
LOCAL_MODULE_TAGS := optional
include $(BUILD_EXECUTABLE)
1,626 次查看
sanshanzhang
Firstly your .mk file  should be included by your last dir.
Secondly, you should add helloworld in PRODUCT_PACKAGE which is in  device/fsl/imx6/imx6.mk
1,626 次查看
jimmychan
what is the content of your Android.mk ?
