unable to build System image when adding custom app
rakeshpatil
I want to add my app in build which uses 4 .jar files and 2 .so libraries in libs folder
folder structure ---
libs
-armeabi
          -     lib0001.so
          -     lib002.so
-v4-support.jar
-Framework.jar
-asap.jar
-jvse.jar
and in .mk file i am writing
LOCAL_PATH:= $(call my-dir)
include $(CLEAR_VARS)
LOCAL_MODULE_TAGS := optional
LOCAL_SRC_FILES := $(call all-subdir-java-files)
LOCAL_PACKAGE_NAME := TestApp
LOCAL_STATIC_JAVA_LIBRARIES := \
android-support-v4 \
asap \
Framework \
jvse
LOCAL_PRIVILEGED_MODULE := true
include $(BUILD_PACKAGE)
include $(call all-makefiles-under,$(LOCAL_PATH))
I am trying o add one app in the packages folder and compile but it gives following error
Install: out/target/product/sabresd_6dq/system/lib/modules/ath6kl_sdio.ko
make: *** No rule to make target `out/target/common/obj/JAVA_LIBRARIES/asapsdk_intermediates/javalib.jar', needed by `out/target/common/obj/APPS/MDTTestApp_intermediates/classes-full-debug.jar'.  Stop.
what all things i needs to do to add those .so files and .jar files.
Labels (3)
