the question about internal ADC reference voltage -- i.mx257
1,923 次查看
王剑翰
We want to use the internal ADC reference voltage but we did not find the related information about the accuracy range and temperature drift characteristics of the internal ADC reference voltage.
I only find "The internal reference is fixed at 2.5 V", but I am not sure the accuracy range.
Could you kindly help me for this question?
1,760 次查看
igorpadykov
Hi 王
the internal reference voltage accuracy is 4%
5 回复数
1,761 次查看
igorpadykov
Hi 王
1,760 次查看
王剑翰
Hi Igor,
Thank you for your kindly answer.
Is the voltage accuracy ±4%?What is the temperature drift characteristics?
Could you kindly show me the related document?
1,760 次查看
igorpadykov
Hi 王
temperature drift included in that value
~igor
1,760 次查看
王剑翰
Hi Igor,
I think these specific should be noted in some document, but I can not find it.
1,760 次查看
igorpadykov
Hi 王
that value is is from internal documents.
It is not from public documents.
~igor
