server certificate verification failed
3,404 次查看
embedded_Dev
Hello @all,
I am trying to download android 11 source. When I run the script imx_android_setup.sh, I am facing the following issues
Error:
fatal: unable to access 'https://source.codeaurora.org/external/imx/aosp/platform/development/': server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
When I am trying to compile the imx6ul yocto source, I am facing the same issue as shown above. Previousely the yocto source use to compile but from yesterday it is showing the certificates error.
Please let me know if any
3,354 次查看
embedded_Dev
Thanks for the response
i used the below commands
$ sudo apt update
$ sudo apt upgrade
The issue got resolved
3,385 次查看
jimmychan
I tried to build it and do not see the error you mentioned. Could you try to make a clean build again?
Jimmy
3,355 次查看
embedded_Dev
$ sudo apt update
$ sudo apt upgrade
