Certificate issue while accessing source.codeaurora.org
ソリューションへジャンプ
4,221件の閲覧回数
arunkumar_maniv
Following certificate error appeared when downloading the U-boot v2020.04.
fatal: unable to access 'https://source.codeaurora.org/external/imx/uboot-imx.git/': server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
With Regards,
Arun
4,211件の閲覧回数
nxf63675
Hi @arunkumar_maniv,
Please update all the packages from your Linux distribution, for ubuntu is:
sudo apt update
sudo apt upgrade
Then I recommend you to repo sync your build directory, it should work just with the commands above but is better if you leave your folders updated.
Israel.
4,212件の閲覧回数
nxf63675
sudo apt update
sudo apt upgrade
Israel.
