questions about uart node in different imx8mp device trees
412件の閲覧回数
machangbao
In https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/arch/arm64/boot/dts/freescale/imx8mp-evk.dts
&uart1 { /* BT */
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart1>;
assigned-clocks = <&clk IMX8MP_CLK_UART1>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>;
uart-has-rtscts;
status = "okay";
bluetooth {
compatible = "nxp,88w8997-bt";
&uart3 {
pinctrl-0 = <&pinctrl_uart3>;
assigned-clocks = <&clk IMX8MP_CLK_UART3>;
uart-has-rtscts;
status = "okay";
In https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/arch/arm64/boot/dts/freescale/imx8mp-venice-gw74...
/* GPS / off-board header */
&uart1 {
status = "okay";
/* bluetooth HCI */
&uart3 {
pinctrl-0 = <&pinctrl_uart3>, <&pinctrl_uart3_gpio>;
cts-gpios = <&gpio3 21 GPIO_ACTIVE_LOW>;
rts-gpios = <&gpio3 22 GPIO_ACTIVE_LOW>;
status = "okay";
bluetooth {
compatible = "brcm,bcm4330-bt";
shutdown-gpios = <&gpio3 8 GPIO_ACTIVE_HIGH>;
Two questions:
1. are propertys assigned-clocks assigned-clock-parents  necessary?  What would happen if it's lacking?
2. What are the differences between the two hardware flow control methods uart-has-rtscts and uart-has-rtscts &cts-gpios&rts-gpios?
348件の閲覧回数
Rita_Wang
Q1:
A:Yes, necessary. These properties are part of the Common Clock Framework in Linux device trees. They are used to configure the clock source and parent for a peripheral at boot time.
If lacking, Incorrect baud rate if the default clock frequency doesn’t match what the driver expects.Potential instability if the clock source is not optimal for low-power or performance modes.
A:uart-has-rtscts 是一个 Device Tree 属性,用于告诉 Linux UART 驱动该串口支持 硬件流控 (RTS/CTS),并且应该启用它。RTS (Request To Send) 和 CTS (Clear To Send) 信号由 UART 控制器硬件自动处理,不需要软件干预
The driver will enable hardware flow control( (RTS/CTS)) function when initializing UART.
cts-gpios 和 rts-gpios 是 Device Tree 属性,用于在硬件没有原生 RTS/CTS 引脚,或者需要通过 GPIO 来模拟流控时使用。驱动会通过 GPIO 来实现流控,而不是使用 UART 控制器的硬件 RTS/CTS.
4 返答(返信)
349件の閲覧回数
Rita_Wang
Q1:
309件の閲覧回数
kawateb265
@Rita_Wang
There's a very serious mistake in your answer.
https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/Documentation/devicetree/bindings/serial/serial....
if:
  required:
    - uart-has-rtscts
then:
  properties:
    cts-gpios: false
    rts-gpios: false
cts-gpios:
maxItems: 1
description:
Must contain a GPIO specifier, referring to the GPIO pin to be used as
the UART's CTS line.
 rts-gpios:
    maxItems: 1
    description:
      the UART's RTS line.
 uart-has-rtscts:
    $ref: /schemas/types.yaml#/definitions/flag
    description:
      The presence of this property indicates that the UART has dedicated lines
      for RTS/CTS hardware flow control, and that they are available for use
      (wired and enabled by pinmux configuration).  This depends on both the
      UART hardware and the board wiring.
if:
  required:
    - uart-has-rtscts
then:
  properties:
    cts-gpios: false
    rts-gpios: false
201件の閲覧回数
Rita_Wang
I got it, and thank you piont it and sharing, great thanks @kawateb265
168件の閲覧回数
kawateb265
@Rita_Wang
We came here because we trust the professional expertise of NXP engineers.
We came here because we are seeking professional support.
The trust in NXP led to @machangbao  marking an incorrect answer as the solution.
It’s obvious at a glance from your table that it was generated by AI. We are not here to get AI-rephrased answers.
If NXP engineers are also just asking AI, then why wouldn’t we just ask AI directly?
%3CLINGO-SUB%20id%3D%22lingo-sub-2200767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%95%B0%E3%81%AA%E3%82%8Bimx8mp%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E5%86%85%E3%81%AEuart%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%3C%2FA%3E%E5%86%85%3CBR%20%2F%3E%3CEM%3E%26amp%3Buart1%20%7B%20%2F*%20BT%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart1%26gt%3B%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_UART1%26gt%3B%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL1_80M%26gt%3B%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Euart-has-rtscts%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%20%7B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22nxp%E3%80%8188w8997-bt%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CEM%3E%26amp%3Buart3%20%7B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart3%26gt%3B%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_UART3%26gt%3B%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL1_80M%26gt%3B%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3Euart-has-rtscts%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-venice-gw74xx.dts%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-venice-gw74xx.dts%3C%2FA%3E%E3%81%A7%3C%2FP%3E%3CP%3E%3CEM%3E%2F*%20GPS%20%2F%20%E3%82%AA%E3%83%95%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%26amp%3Buart1%20%7B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart1%26gt%3B%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%2F*%20Bluetooth%20HCI%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%26amp%3Buart3%20%7B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart3%26gt%3B%E3%80%81%26lt%3B%26amp%3Bpinctrl_uart3_gpio%26gt%3B%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3Ects-gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2021%20GPIO_ACTIVE_LOW%26gt%3B%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3Erts-gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2022%20GPIO_ACTIVE_LOW%26gt%3B%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%20%7B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22brcm%E3%80%81bcm4330-bt%22%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3-gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%208%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3B%3C%2FEM%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%3A%3C%2FP%3E%3CP%3E1.%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3CEM%3E%3CSTRONG%3Eassigned-clocks%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3Eassigned-clock-parents%E3%81%AF%3C%2FSTRONG%3E%3C%2FEM%3E%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3CSPAN%3E%E4%B8%8D%E8%B6%B3%E3%81%99%E3%82%8B%E3%81%A8%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2.%202%20%E3%81%A4%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E6%96%B9%E6%B3%95%3CEM%3E%3CSTRONG%3E(uart-has-rtscts%3C%2FSTRONG%3E%E3%81%A8%3C%2FEM%3E%3CSTRONG%3Euart-has-rtscts%3C%2FSTRONG%3E%20%26amp%3B%20%3CEM%3E%3CSTRONG%3Ects-gpios%26amp%3Brts-gpios)%3C%2FSTRONG%3E%3C%2FEM%3E%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2200767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20questions%20about%20uart%20node%20in%20different%20imx8mp%20device%20trees%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%82%BF%E3%83%BB%E3%83%AF%E3%83%B3%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E3%81%93%E3%81%93%E3%81%AB%E6%9D%A5%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81NXP%20%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%81%AE%E5%B0%82%E9%96%80%E7%9F%A5%E8%AD%98%E3%82%92%E4%BF%A1%E9%A0%BC%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%B1%82%E3%82%81%E3%81%A6%E3%81%93%E3%81%93%E3%81%AB%E6%9D%A5%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ENXP%20%E3%81%B8%E3%81%AE%E4%BF%A1%E9%A0%BC%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196155%22%20target%3D%22_blank%22%3E%40machangbao%20%E3%81%AF%3C%2FA%3E%E8%AA%A4%E3%81%A3%E3%81%9F%E5%9B%9E%E7%AD%94%E3%82%92%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A1%A8%E3%82%92%E8%A6%8B%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%20AI%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E4%B8%80%E7%9B%AE%E7%9E%AD%E7%84%B6%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%20AI%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A8%80%E3%81%84%E6%8F%9B%E3%81%88%E3%82%89%E3%82%8C%E3%81%9F%E5%9B%9E%E7%AD%94%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%93%E3%81%93%E3%81%AB%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3ENXP%20%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%82%20AI%20%E3%81%AB%E8%B3%AA%E5%95%8F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%AA%E3%81%9C%20AI%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E8%B3%AA%E5%95%8F%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20questions%20about%20uart%20node%20in%20different%20imx8mp%20device%20trees%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%8C%87%E6%91%98%E3%81%97%E3%81%A6%E3%82%B7%E3%82%A7%E3%82%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254788%22%20target%3D%22_blank%22%3E%40kawateb265%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20questions%20about%20uart%20node%20in%20different%20imx8mp%20device%20trees%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%82%BF%E3%83%BB%E3%83%AF%E3%83%B3%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%AD%94%E3%81%88%E3%81%AB%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%87%8D%E5%A4%A7%E3%81%AA%E9%96%93%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2FDocumentation%2Fdevicetree%2Fbindings%2Fserial%2Fserial.yaml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2FDocumentation%2Fdevicetree%2Fbindings%2Fserial%2Fserial.yaml%3C%2FA%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eif%3A%0A%20%20required%3A%0A%20%20%20%20-%20uart-has-rtscts%0Athen%3A%0A%20%20properties%3A%0A%20%20%20%20cts-gpios%3A%20false%0A%20%20%20%20rts-gpios%3A%20false%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rita_Wang_0-1763017665901.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1763017665901.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365749i9D131823C3A91D1F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Rita_Wang_0-1763017665901.png%22%20alt%3D%22Rita_Wang_0-1763017665901.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2FDocumentation%2Fdevicetree%2Fbindings%2Fserial%2Fserial.yaml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2FDocumentation%2Fdevicetree%2Fbindings%2Fserial%2Fserial.yaml%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ects-gpios%3A%0AmaxItems%3A%201%0Adescription%3A%0AMust%20contain%20a%20GPIO%20specifier%2C%20referring%20to%20the%20GPIO%20pin%20to%20be%20used%20as%0Athe%20UART's%20CTS%20line.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20rts-gpios%3A%0A%20%20%20%20maxItems%3A%201%0A%20%20%20%20description%3A%0A%20%20%20%20%20%20Must%20contain%20a%20GPIO%20specifier%2C%20referring%20to%20the%20GPIO%20pin%20to%20be%20used%20as%0A%20%20%20%20%20%20the%20UART's%20RTS%20line.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20uart-has-rtscts%3A%0A%20%20%20%20%24ref%3A%20%2Fschemas%2Ftypes.yaml%23%2Fdefinitions%2Fflag%0A%20%20%20%20description%3A%0A%20%20%20%20%20%20The%20presence%20of%20this%20property%20indicates%20that%20the%20UART%20has%20dedicated%20lines%0A%20%20%20%20%20%20for%20RTS%2FCTS%20hardware%20flow%20control%2C%20and%20that%20they%20are%20available%20for%20use%0A%20%20%20%20%20%20(wired%20and%20enabled%20by%20pinmux%20configuration).%20%20This%20depends%20on%20both%20the%0A%20%20%20%20%20%20UART%20hardware%20and%20the%20board%20wiring.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eif%3A%0A%20%20required%3A%0A%20%20%20%20-%20uart-has-rtscts%0Athen%3A%0A%20%20properties%3A%0A%20%20%20%20cts-gpios%3A%20false%0A%20%20%20%20rts-gpios%3A%20false%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20questions%20about%20uart%20node%20in%20different%20imx8mp%20device%20trees%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EQ1%3A%3C%2FP%3E%0A%3CP%3E1.%3CEM%3E%3CSTRONG%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A6%AA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FEM%3E%E5%BF%85%E8%A6%81%EF%BC%9F%3CSPAN%3E%E4%B8%8D%E8%B6%B3%E3%81%99%E3%82%8B%E3%81%A8%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EA%3A%20%E3%81%AF%E3%81%84%E3%80%81%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E3%80%81Linux%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%E3%80%82%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%3CSTRONG%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3E%E8%A6%AA%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3C%2FSTRONG%3E%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22YZqN6RYNqr%22%20data-para-id%3D%220%22%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%8C%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E6%83%B3%E5%AE%9A%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%222NwPP8R0wo%22%20data-para-id%3D%221%22%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AB%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%202%E3%81%A4%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E6%96%B9%E6%B3%95%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3E%3CSTRONG%3Euart-has-rtscts%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%E3%81%8A%E3%82%88%E3%81%B3%3C%2FEM%3E%3CSTRONG%3Euart-has-rtscts%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%26amp%3B%20%3CEM%3E%3CSTRONG%3Ects-gpios%26amp%3Brts-gpios%3C%2FSTRONG%3E%3C%2FEM%3E%20%3F%3C%2FP%3E%0A%3CP%3EA%3A%20%3CEM%3E%3CSTRONG%3Euart-has-rtscts%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FEM%3E%3CSPAN%20data-slate-fragment%3D%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%3D%22%3ERTS%20(Request%20To%20Send)%20%E3%81%8A%E3%82%88%E3%81%B3%20CTS%20(Clear%20To%20Send)%20%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%20(RTS%2FCTS)%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81UART%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%87%AA%E5%8B%95%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81Linux%20UART%20%E3%82%92%E9%A7%86%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-fragment%3D%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%3D%3D%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81UART%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%20(RTS%2FCTS)%20%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-fragment%3D%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%3D%3D%22%3Ects-gpios%20%E3%81%8A%E3%82%88%E3%81%B3%20rts-gpios%20%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%20RTS%2FCTS%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20UART%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20RTS%2FCTS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%20GPIO%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
