opencv2/tracking/tracking_legacy.hpp compile error with sdk
2,023 次查看
astel_
Hello
Yocto OS : nanbield-6.6.3-1.0.0
Opencv : 4.8.1.imx
I tried to use tracking algorithm using opencv tracking_legacy.hpp.
But when I tried to compile it using sdk that I built, it seems i encounter some issue. the error log is at the attachment file.
Is this a bug in this opencv-imx in this version? and do anyone have solution for this
Thank you
1,962 次查看
astel_
Thank you for your reply.
apparently i use wrong implementation regarding how to use legacy tracker of opencv.
there is a sample file from opencv-contrib that tell us how to use that correctly:
https://github.com/opencv/opencv_contrib/blob/4fc6995375e384b8e25bd6c8693fa8dd2ed4bb0a/modules/track...
1,989 次查看
Zhiming_Liu
1,963 次查看
astel_
