mx27 ssi interface program
1,949 次查看
zhangjay
Dear all
I am using imx27 cpu as your board processor, I want to use the ssi interface as i2s to control TW2835 chip which has audio codec inside, but I cannot find any sample codes to refer.
Is there any example I can refer to?
I can find the functions in ssi.c, but I don't know how to use them.
I want to use the ssi interface as i2s.
标签 (3)
1,810 次查看
fabio_estevam
You need a codec driver for the TW2835. Could not find it under soc/codecs, so you would need to add support for this codec first.
1,811 次查看
fabio_estevam
