music no sound when upgrade to android 5.0
1,033 次查看
jacklu
Hi expert,
I have gotten the patch android_L5.0.0_1.0.0-ga_omxplayer_source.tar.gz for this issue.
And I have made the patch available for our android 5.0.
But unfortunately, it is still failed.
The platform can only play music a little moment, then, it will show fail like these:
10-11 04:14:07.996 E/OMXNodeInstance(  154): getParameter(100663311) ERROR: 0x8000100e
10-11 04:14:07.997 E/OMXNodeInstance(  154): getParameter(100663297) ERROR: 0x8000100e
10-11 04:14:07.997 E/OMXNodeInstance(  154): OMX_SetParameter() failed for StoreMetaDataInBuffers: 0x8000101a
it is the same as the log before patching.
Could help analize this issue again?
Thank You!
BRs,
Jack
Original Attachment has been moved to: after_patch_log_fail_audio_playback.zip
Original Attachment has been moved to: em70_0907_log.zip
标签 (3)
921 次查看
jacklu
看来是android 5.0 导入后,audio codec这边的一个新动作:runtime suspend导致codec工作不正常。
