multi core debugging
1,385 次查看
saida
I.mx6sabresd board not connecting with core1 and smp but working with core0
DS-5 error message is "unable to connect debugg hardware"
can any one tellme how to debugg two cores ?
Saida
1,260 次查看
Yuri
   by default cores 1-3 are disabled, there is special procedure to
run them. Please look at example codes in
Integrating Processor Expert for i.MX and ARM GCC with Eclipse
Also, You may look at Chapter 3 (Multicore Startup) of "iMX6_Firmware_Guide.pdf"
of the i.MX6 Platfrom SDK. Please create request if You need the SDK, it is not located
on the Web now.
1)    Please open www.nxp.com
2)    On the top level menu, select Support > Sales and Support (http://www.nxp.com/support/sales-and-support:SUPPORTHOME).
3)    On the bottom of the page, select Hardware & Software.
4)    Register with your business email to access the technical NXP online support.
5)    A verification email will be sent to your account. Click the embedded link to verify your access.
6)    On the NXP online support page, select Contact Support from the top menu and click “submit a new case” to start the process.
Yuri
