Integrating Processor Expert for i.MX and ARM GCC with Eclipse
   The purpose of this article is to describe how to join together the Processor
Expert and ARM GCC toolchain under Eclipse environment.
  Freescale provides the Processor Expert, which contains the Pin Settings Tool
to support an easy way to configure pin signals, from multiplexing to the electrical
properties of pins. With such Tool all the pins can be configured with a graphical
user interface, and then generate C code, in order to use it as an example in applications.
Please refer to the following Web for more details.
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=PROCESSOR-EXPERT-IMX
  The Processor Expert Software for i.MX Processors (Version 1.0) does not include
a compiler or linker. Customers should merge the generated code into a build system.
  However, it is possible to use common Eclipse-based IDE for the Processor Expert (V 1.0)
and GNU ARM “C” toolchains. In particular, the following sequence may be implemented for
both Linux and Windows hosts.
1.
Install Eclipse (Kepler release) IDE for C/C++ Developers.
https://eclipse.org/downloads/packages/eclipse-ide-cc-developers/keplersr2
2.
Add Eclipse Processor Expert plug-in, as recommended in the documentation.
https://community.freescale.com/docs/DOC-101470
3.
Add GNU ARM Eclipse, which contains configurations for different toolchains,
including Linux ones.
http://gnuarmeclipse.livius.net/blog/plugins-install/
4.
Install appropriate toolchain. For bare-metal applications Sourcery CodeBench Lite
for ARM is sutable one.
Sourcery CodeBench Lite Edition including ARM GCC IDE - Mentor Graphics
Please use Getting Started Guide document from the CodeBench Lite package,
that explains how to install and build applications with the CodeBench Lite.
   As an example, let’s consider minimal startup code for i.MX6Q (LED flickering
project on i.MX6Q SDB / SDP). Assuming Eclipse IDE with the Processor Expert
and GNU ARM tools is installed, we should create new “C” project under Eclipse :
New -> C Project. Select “Empty Project” and “Cross ARM GCC”, enter “Project
name”.
Then : select “Advanced settings” -> C/C++ Build -> Settings
Tab “Target Processor” :
ARM Family : cortex – a9
Architecture : armv7-a
Instruction set : ARM (-marm)
Endianness : Little endian (-mlittle-endian)
FloatABI : Library with FP (softfp)
FPU Type : neon
Unaligned access : Disabled (-mno-unaligned-access)
“Cross ARM GNU Create Flash Image” :
General : Raw binary.
TAB “Toolchains” :
Name : Sourcery CodeBench Lite for ARM EABI (arm-none-eabi-gcc)
(If needed customers can select appropriate toolchain)
Architecture : ARM (AArch32)
Prefix : arm-none-eabi
Check “Use global toolchain path” or select the required path directly.
Source codes may added via Eclipse : File -> Import -> File System -> From directory
Example source is enclosed.
After sources as included in the project, let’s configure linker options via
project properties,
C/C++ Build -> Settings -> Tool Settings -> Cross ARM C Linker -> General.
Add script file “mx6dq.ld”, uncheck “Remove unused section”, check
“Do not use standard start files”.
Note, the article of Miro Samek is very helpful in clarifying of startup code and linker
script. Please refer to “Building Bare-Metal ARM Systems with GNU”. Article Published
online at www.Embedded.com,  July/August 2007.
So, now we can build the project : Project -> Build Project.
Two executable file will be generated : test.elf (for JTAG debugger) and test.bin,
which may be used to create bootable SD card, using cfimager-imx.exe utility :
CMD> cfimager-imx -o 0 -f test.bin -d g:
Please use readme files in the enclosed for more details.
ラベル(4)
添付
コメント
I have built the above program using GCC ARM GCC ARM Embedded in Launchpad . However given sample is compiled using Sourcery CodeBench Lite (which is available for evaluation period of 30 days only).
I get errors when compiled with GCC ARM. Check .jpg attachedlcs3arm_errror.jpg
Building target: Prog_from_Integrating.elf
Invoking: Cross ARM C Linker
arm-none-eabi-gcc --specs=rdimon.specs  -lrdimon -mcpu=cortex-a9 -march=armv7-a -marm -mlittle-endian -mfloat-abi=softfp -mfpu=neon -mno-unaligned-access -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -T "E:\Kepler_Programs\Prog_from_Integrating\mx6dq.ld" -nostartfiles -Wl,-Map,"Prog_from_Integrating.map" -o "Prog_from_Integrating.elf"  ./main.o
c:/program files (x86)/gnu tools arm embedded/4.9 2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: cannot find -lcs3arm
collect2.exe: error: ld returned 1 exit status
makefile:41: recipe for target 'Prog_from_Integrating.elf' failed
make: *** [Prog_from_Integrating.elf] Error 1
It shows cs3arm & cs3 cannot find. These are written in mx6dq.ld (linker Script)  at GROUP(-lgcc -lc -lcs3arm -lcs3).
If I remove them from GROUP I get this 'Reset Handler' error.Check .jpg attachedResetHandler_error.jpg
c:/program files (x86)/gnu tools arm embedded/4.9 2015q3/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: warning: cannot find entry symbol Reset_Handler; defaulting to 00900000
./main.o: In function `start_secondary_cpu':
E:\Kepler_Programs\Prog_from_Integrating\Debug/../main.c:124: undefined reference to `Reset_Handler'
Any help to solve this error would be appreciated? I want to build it using GCC ARM. (not Sourcery CodeBench)
Thanks and regards,
Sarang
The web links in the article beginning with www.freescale.com are not up to date. Where are they currently mapped to, please?
  It may be recommended to use the Pins Tool now
Pins Tool for i.MX Application Processors|NXP
Yuri.
Hi Yuri,
thank you for your recommendation. I was able to generate the iomux_config files for my EVA board.
Could you please give me an additional advice where to get a simple bare-metal “HelloWorld”/ “Blinky” template project for MCIMX6UL-EVKB under ARM GCC with Eclipse?
I need just a quick start help. Maybe https://community.nxp.com/docs/DOC-94139 would be helpfull for me, but, the link to the “i.MX 6Series Platform SDK” files doesn’t work…
Thank you!
Waldemar Rempel
Engineering Automation Systems Basis Firmware DC-IA/EAH2
Bosch Rexroth. The Drive & Control Company
Tel. +49 6062 78-1834
Fax +49 6062 78-771
[email protected]<mailto:[email protected]>
www.boschrexroth.com<http://www.boschrexroth.com>;
Bosch Rexroth AG
Berliner Straße 25
64711 Erbach
GERMANY
Firmensitz: Stuttgart, Registrierung: Amtsgericht Stuttgart HRB 23192
Vorstand: Rolf Najork (Vorsitzender) , Dr. Markus Forschner; Dr. Bertram Hoffmann; Dr. Marc Wucherer
Vorsitzender des Aufsichtsrats: Dr. Stefan Hartung
Von: Yuri
Gesendet: Dienstag, 23. Mai 2017 11:01
An: Rempel Waldemar (DC-IA/EAH2) <[email protected]>
Betreff: Re: - Integrating Processor Expert for i.MX and ARM GCC with Eclipse
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
new comment by Yuri Muhin<https://community.nxp.com/people/Yuri?et=watches.email.document_comment> View all comments on this document<https://community.nxp.com/docs/DOC-103736?commentID=43458&et=watches.email.document_comment#comment-43458>
  You may use the following regarding the Platform SDK :
swp-report/iMX6_Platform_SDK at master · backenklee/swp-report · GitHub
 Also, You may  look at the following :
i.MX6 Bare Metal
Perhaps the following helps regarding i.MX6UL, since it may be considered as i.MX6SL derivative.
https://community.nxp.com/docs/DOC-331921
Yuri.
  values of heap_start, top_of_stacks  and __mmu_page_table_base__ are defined in linker file
mx6dq.ld. Verify if it is involved in Your case.
Yuri.
Hi Yuri Muhin,
I am getting error for -lcs3 and -lcs3arm,
are they library?
  the mentioned  lcs3 concerns with Sourcery CodeBench toolchain specifics.
Perhaps for Your toolchain linker file should be modified.
Yuri.
solve library issue:
-lcs3, -lcs3arm library issue.
from here:
-lcs3 and -lcs3arm library
%3CLINGO-SUB%20id%3D%22lingo-sub-1123453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EProcessor%20Expert%20for%20i.MX%20%E3%81%8A%E3%82%88%E3%81%B3%20ARM%20GCC%20%E3%81%A8%20Eclipse%20%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%E7%9B%AE%E7%9A%84%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%20%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E7%B5%90%E5%90%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3EEclipse%E7%92%B0%E5%A2%83%E4%B8%8B%E3%81%A7%E3%81%AE%E3%82%A8%E3%82%AD%E3%82%B9%E3%83%91%E3%83%BC%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3ARM%20GCC%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%80%82%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%20%3CSTRONG%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%3C%2FSTRONG%3E%E3%83%94%E3%83%B3%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E5%90%AB%E3%82%80Processor%20Expert%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3CBR%20%2F%3E%20%E3%83%94%E3%83%B3%E4%BF%A1%E5%8F%B7%E3%82%92%E7%B0%A1%E5%8D%98%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%A4%9A%E9%87%8D%E5%8C%96%E3%81%8B%E3%82%89%E9%9B%BB%E6%B0%97%E3%81%BE%E3%81%A7%20%3CBR%20%2F%3E%20%E3%83%94%E3%83%B3%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%82%AB%E3%83%AB%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3CBR%20%2F%3E%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81C%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AEWeb%E3%82%B5%E3%82%A4%E3%83%88%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DPROCESSOR-EXPERT-IMX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DPROCESSOR-EXPERT-IMX%3C%2FA%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%26nbsp%3Bi.MX%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8%20Processor%20Expert%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20(%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.0)%20%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AB%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%26nbsp%3B%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81Processor%20Expert%20(V%201.0)%20%E3%81%AB%E5%85%B1%E9%80%9A%E3%81%AE%20Eclipse%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%20IDE%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%81%8A%E3%82%88%E3%81%B3%20GNU%20ARM%20%22C%22%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%80%82%E7%89%B9%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AF%E3%80%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3ELinux%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A8%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Verdana%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20line-height%3A%201.5em%3B%22%3EWindows%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E4%B8%A1%E6%96%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%20%3CBR%20%2F%3E%201.%3CBR%20%2F%3E%20C%2FC%2B%2B%20%E9%96%8B%E7%99%BA%E8%80%85%E5%90%91%E3%81%91%E3%81%AE%20Eclipse%20(Kepler%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%20IDE%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Feclipse.org%2Fdownloads%2Fpackages%2Feclipse-ide-cc-developers%2Fkeplersr2%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Feclipse.org%2Fdownloads%2Fpackages%2Feclipse-ide-cc-developers%2Fkeplersr2%3C%2FA%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E2.%3CBR%20%2F%3E%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Eclipse%20Processor%20Expert%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DPROCESSOR-EXPERT-IMX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DPROCESSOR-EXPERT-IMX%3C%2FA%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2251688%22%20data-containertype%3D%22700%22%20data-objectid%3D%22101470%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101470%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-101470%3C%2FA%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%203.%20%3CBR%20%2F%3E%20%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E5%90%AB%E3%82%80%20GNU%20ARM%20Eclipse%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3ELinux%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E5%90%AB%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgnuarmeclipse.livius.net%2Fblog%2Fplugins-install%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fgnuarmeclipse.livius.net%2Fblog%2Fplugins-install%2F%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E4.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%90%91%E3%81%91%20Sourcery%20CodeBench%20Lite%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3EARM%E3%81%AF%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CBR%20%2F%3E%3CA%20href%3D%22http%3A%2F%2Fwww.mentor.com%2Fembedded-software%2Fsourcery-tools%2Fsourcery-codebench%2Feditions%2Flite-edition%2F%22%20title%3D%22http%3A%2F%2Fwww.mentor.com%2Fembedded-software%2Fsourcery-tools%2Fsourcery-codebench%2Feditions%2Flite-edition%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESourcery%20CodeBench%20Lite%20Edition%20(ARM%20GCC%20IDE%20%E3%82%92%E5%90%AB%E3%82%80)%20-%20Mentor%20Graphics%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3ECodeBench%20Lite%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E5%85%A5%E9%96%80%E3%82%AC%E3%82%A4%E3%83%89%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Verdana%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81CodeBench%20Lite%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%20%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3CSTRONG%3E%20%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%3C%2FSTRONG%3Ei.MX6Q(LED%E3%81%AE%E7%82%B9%E6%BB%85)%E3%81%AE%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%80%83%E3%81%88%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3Ei.MX6Q%20SDB%20%2F%20SDP%E4%B8%8A%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88)%E3%80%82Eclipse%20IDE%E3%81%A8Processor%20Expert%E3%81%AE%E4%BB%AE%E5%AE%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3EGNU%20ARM%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Eclipse%E3%81%AE%E4%B8%8B%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%80%8CC%E3%80%8D%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84-%26gt%3BC%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%82%E3%80%8C%E7%A9%BA%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%8D%E3%81%A8%E3%80%8CCross%20ARM%20GCC%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%80%8C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%20name%22%E3%81%A7%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20848px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110972i770465C3457ED017%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%80%8C%E8%A9%B3%E7%B4%B0%E8%A8%AD%E5%AE%9A%E3%80%8D-%26gt%3B%20C%20%2F%20C%20%2B%2B%E3%83%93%E3%83%AB%E3%83%89-%26gt%3B%E8%A8%AD%E5%AE%9A%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20709px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110971iAD622188708FC983%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20799px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110970i0499DAA7D96228EA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%80%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%80%8D%E3%82%BF%E3%83%96%3A%3CBR%20%2F%3E%20ARM%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%20%3A%E7%9A%AE%E8%B3%AA%E2%80%93%20a9%3CBR%20%2F%3E%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%20%3A%20armv7-a%3CBR%20%2F%3E%20%E5%91%BD%E4%BB%A4%E3%82%BB%E3%83%83%E3%83%88%3AARM(-marm)%3CBR%20%2F%3E%20%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%20%3A%20%E3%83%AA%E3%83%88%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%20(-mlittle-endian)%3CBR%20%2F%3E%20FloatABI%20%3A%20FP%E4%BB%98%E3%81%8D%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA(softfp)%3CBR%20%2F%3E%20FPU%E3%82%BF%E3%82%A4%E3%83%97%20%3A%20%E3%83%8D%E3%82%AA%E3%83%B3%3CBR%20%2F%3E%20%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%20%3A%20%E7%84%A1%E5%8A%B9%20(-mno-unaligned-access)%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20792px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110969iE43AF10014AB81B0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%80%8CCross%20ARM%20GNU%20Create%20Flash%20Image%E3%80%8D%3A%3CBR%20%2F%3E%20%E4%B8%80%E8%88%AC%20%3A%20%E7%94%9F%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20704px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110968iA3A7E5169319AB23%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E3%82%BF%E3%83%96%E3%80%8C%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%80%8D%3A%3CBR%20%2F%3E%20%E5%90%8D%E5%89%8D%20%3A%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3ESourcery%20CodeBench%20Lite%20for%20ARM%20EABI%20(arm-none-eabi-gcc)%3C%2FSPAN%3E%3CBR%20%2F%3E%20(%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E9%81%A9%E5%88%87%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%3CBR%20%2F%3E%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%20%3A%20ARM%20(AArch32)%3CBR%20%2F%3E%20%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%20%3A%20arm-none-eabi%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E3%80%8C%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%83%91%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%80%8D%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%82%B9%E3%82%92%E7%9B%B4%E6%8E%A5%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22toolchain.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22toolchain.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110991i96C13C1193DDC034%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22toolchain.jpg%22%20alt%3D%22toolchain.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Etoolchain.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3EEclipse%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E5%8F%AF%E8%83%BD%20%3A%20File%20-%26gt%3B%20Import%20-%26gt%3B%20File%20System%20-%26gt%3B%20From%20directory%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22import_file_system.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22import_file_system.jpg%22%20style%3D%22width%3A%20768px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110973i906C7CFDC0854CEA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22import_file_system.jpg%22%20alt%3D%22import_file_system.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimport_file_system.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E5%90%8C%E5%B0%81%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%80%81%3CBR%20%2F%3E%20C%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89%20-%26gt%3B%E8%A8%AD%E5%AE%9A%20-%26gt%3B%E3%83%84%E3%83%BC%E3%83%AB%E8%A8%AD%E5%AE%9A%20-%26gt%3B%20ARM%20C%E3%83%AA%E3%83%B3%E3%82%AB%20-%26gt%3B%20%E4%B8%80%E8%88%AC%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cmx6dq.ld%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%80%8C%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%89%8A%E9%99%A4%E3%80%8D%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E5%A4%96%E3%81%97%E3%80%81%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%80%8C%E6%A8%99%E6%BA%96%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%8D%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20736px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110967i8F339E7EB5079829%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%20%E3%81%AA%E3%81%8A%E3%80%81Miro%20Samek%20%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AF%E3%80%81%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%3CBR%20%2F%3E%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%80%82%E3%80%8CGNU%E3%81%AB%E3%82%88%E3%82%8B%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%ABARM%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E6%A7%8B%E7%AF%89%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%98%E4%BA%8B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.Embedded.com%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.Embedded.com%3C%2FA%3E%20%E3%81%A7%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%20%3CA%20href%3D%22www.Embedded.com%2C%26nbsp%3B%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%80%81%20%3C%2FA%3E2007%E5%B9%B47%E6%9C%88%2F%208%E6%9C%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3AProject%20-%26gt%3B%20Build%20Project%E3%80%82%3CBR%20%2F%3Etest.elf%20(JTAG%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E7%94%A8)%20%E3%81%A8%20test.bin%20%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E5%8F%AF%E8%83%BD%E3%81%AASD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99cfimager-imx.exe%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3ECMD%26gt%3B%20cfimager-imx%20-o%200%20-f%20test.bin%20-d%20g%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E5%90%8C%E5%B0%81%E3%81%AEreadme%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%3E%3CBR%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Verdana'%2C'sans-serif'%3B%22%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-lcs3%E3%80%81-lcs3arm%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E5%95%8F%E9%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fjsnyder%2Farm-eabi-toolchain%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E-lcs3%20%E3%81%8A%E3%82%88%E3%81%B3%20-lcs3arm%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%89%8D%E8%BF%B0%E3%81%AE%20lcs3%20%E3%81%AF%3CSPAN%20class%3D%22%22%3E%E3%80%81Sourcery%20CodeBench%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E8%A9%B3%E7%B4%B0%3C%2FSPAN%3E%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EYuri.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-content-finding%3D%22Community%22%20data-userid%3D%2211235%22%20data-username%3D%22Yuri%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FYuri%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%83%AA%E3%83%BB%E3%83%A0%E3%83%92%E3%83%B3%3C%2FA%3E%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-lcs3%E3%81%A8-lcs3arm%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%BC%E3%82%89%E3%81%AF%E5%9B%B3%E6%9B%B8%E9%A4%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47585iC7B859BA5D6CD73A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22error2.png%22%20alt%3D%22error2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eerror2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eheap_start%E3%80%81top_of_stacks%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20__mmu_page_table_base__%20%E3%81%AE%E5%80%A4%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emx6dq.ld%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AB%E9%96%A2%E4%B8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EYuri.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8B%E4%BE%8B%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35120i1F3DE04EFCDB2B57%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22error.png%22%20alt%3D%22error.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eerror.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlatform%20SDK%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fbackenklee%2Fswp-report%2Ftree%2Fmaster%2FiMX6_Platform_SDK%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fbackenklee%2Fswp-report%2Ftree%2Fmaster%2FiMX6_Platform_SDK%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EiMX6_Platform_SDK%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%C2%B7backenklee%2Fswp-%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%20%C2%B7GitHub%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%AC%A1%E3%81%AE%E7%82%B9%E3%82%82%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fatose.org%2F%3Fp%3D141%22%20title%3D%22http%3A%2F%2Fatose.org%2F%3Fp%3D141%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX6%20Bare%20Metal%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6UL%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81i.MX6SL%E3%81%AE%E6%B4%BE%E7%94%9F%E7%89%A9%E3%81%A8%E8%A6%8B%E3%81%AA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%AC%A1%E3%81%AE%E7%82%B9%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-331921%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-331921%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EYuri.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Yuri%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E6%8E%A8%E8%96%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82EVA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEiomux_config%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EEclipse%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6ARM%20GCC%E3%81%AE%E4%B8%8B%E3%81%A7MCIMX6UL-EVKB%E7%94%A8%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AA%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%20%22HelloWorld%22%2F%22Blinky%22%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%81%AE%E3%83%98%E3%83%AB%E3%83%97%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%B6%E3%82%93%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94139%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94139%3C%2FA%3E%20%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8C%E3%80%81%E3%80%8Ci.MX%206Series%20Platform%20SDK%E3%80%8D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWaldemar%20Rempel%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%9F%BA%E7%A4%8E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20DC-IA%2FEAH2%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%83%AD%E3%82%B9%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%26amp%3B%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%B3%E3%83%91%E3%83%8B%E3%83%BC%3C%2FP%3E%3CP%3ETel.%20%2B49%206062%2078-1834%3C%2FP%3E%3CP%3EFax%20%2B49%206062%2078-771%3C%2FP%3E%3CP%3EWaldemar.Rempel%40boschrexroth.de%3CWALDEMAR.REMPEL%3E%3C%2FWALDEMAR.REMPEL%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22www.boschrexroth.com%26lt%3Bhttp%3A%2F%2Fwww.boschrexroth.com%26gt%3B%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.boschrexroth.com%26lt%3B%26gt%3B%3C%2FA%3E%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%83%AD%E3%82%B9AG%3C%2FP%3E%3CP%3EBerliner%20Stra%C3%9Fe%2025%3C%2FP%3E%3CP%3E64711%20Erbach%3C%2FP%3E%3CP%3E%E3%83%89%E3%82%A4%E3%83%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFirmensitz%3A%20Stuttgart%2C%20Registrierung%3A%20Amtsgericht%20Stuttgart%20HRB%2023192%3C%2FP%3E%3CP%3EVorstand%3A%20Rolf%20Najork%20(Vorsitzender)%20%2C%20Dr.%20Markus%20Forschner%3B%20Dr.%20Bertram%20Hoffmann%3B%20Dr.%20Marc%20Wucherer%3C%2FP%3E%3CP%3EVorsitzender%20des%20Aufsichtsrats%3A%20Dr.%20Stefan%20Hartung%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EVon%3A%20Yuri%20%3C%2FP%3E%3CP%3EGesendet%3A%20Dienstag%2C%2023.%20Mai%202017%2011%3A01%3C%2FP%3E%3CP%3EAn%3A%20Rempel%20Waldemar%20(DC-IA%2FEAH2)%20%3CWALDEMAR.REMPEL%3E%3C%2FWALDEMAR.REMPEL%3E%3C%2FP%3E%3CP%3EBetreff%3A%20Re%3A%20-%20Eclipse%E3%81%A8%20i.MX%20%E3%81%8A%E3%82%88%E3%81%B3ARM%20GCC%E3%81%AEProcessor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EProcessor%20Expert%20for%20i.MX%20%E3%81%8A%E3%82%88%E3%81%B3%20ARM%20GCC%20%E3%81%A8%20Eclipse%20%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%20by%20Yuri%20Muhin%26lt%3B%26gt%3B%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%81%99%E3%81%90%E3%83%94%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fsoftware-development-tools%2Fprocessor-expert-and-embedded-components%2Fsoftware-suites%2Fpins-tool-for-i.mx-application-processors%3APINS-TOOL-IMX%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fsoftware-development-tools%2Fprocessor-expert-and-embedded-components%2Fsoftware-suites%2Fpins-tool-for-i.mx-application-processors%3APINS-TOOL-IMX%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8%E3%81%AE%E3%83%94%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EYuri.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%A8%98%E4%BA%8B%E5%86%85%E3%81%AE%20www.freescale.com%3C%2FA%3E%20%E3%81%A7%E5%A7%8B%E3%81%BE%E3%82%8B%20Web%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E6%9C%80%E6%96%B0%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%BD%BC%E3%82%89%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%A9%E3%81%93%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AEclipse%E3%81%A8Eclipse%E3%81%A8ARM%20GCC%E3%81%AE%20i.MX%20%E7%94%A8Processor%20Expert%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Flaunchpad.net%2Fgcc-arm-embedded%22%20title%3D%22https%3A%2F%2Flaunchpad.net%2Fgcc-arm-embedded%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELaunchpad%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9FGCC%20ARM%20GCC%20ARM%3C%2FA%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AFSourcery%20CodeBench%20Lite(%E8%A9%95%E4%BE%A1%E6%9C%9F%E9%96%9330%E6%97%A5%E9%96%93%E3%81%AE%E3%81%BF%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGCC%20ARM%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82.jpg%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E4%BB%98%E5%B1%9E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lcs3arm_errror.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lcs3arm_errror.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36956i97AC1F44A8354301%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22lcs3arm_errror.jpg%22%20alt%3D%22lcs3arm_errror.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elcs3arm_errror.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BB%BA%E7%89%A9%E5%AF%BE%E8%B1%A1%3AProg_from_Integrating.elf%3C%2FP%3E%3CP%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%20Cross%20ARM%20C%20%E3%83%AA%E3%83%B3%E3%82%AB%3C%2FP%3E%3CP%3Earm-none-eabi-gcc%20--specs%3Drdimon.specs-lrdimon%20-mcpu%3Dcortex-a9%20-march%3Darmv7-a%20-marm%20-mlittle-endian%20-mfloat-abi%3Dsoftfp%20-mfpu%3Dneon%20-mno-unaligned-access%20-O0%20-fmessage-length%3D0%20-fsigned-char%20-ffunction-sections%20-fdata-sections%20-g3%20-t%20%22E%3A%5CKepler_Programs%5CProg_from_Integrating%5Cmx6dq.ld%22-nostartfiles%20-Wl%2C-map%2C%22Prog_from_Integrating.map%22-o%20%22Prog_from_Integrating.elf%22.%2Fmain.o%20%3C%2FP%3E%3CP%3EC%3A%2FProgram%20Files%20(x86)%2FGNU%20Tools%20Arm%20Embedded%2F4.9%202015Q3%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F4.9.3%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Fld.exe%3A%20-lcs3arm%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EC%3A%2FProgram%20Files%20(x86)%2FGNU%20Tools%20Arm%20Embedded%2F4.9%202015Q3%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F4.9.3%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Fld.exe%3A%20-lcs3%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecollect2.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ld%20%E3%81%8C%201%20%E3%81%A4%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emakefile%3A41%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'Prog_from_Integrating.elf'%20%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emake%3A%20***%20%5BProg_from_Integrating.elf%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecs3arm%20%E3%81%A8%20cs3%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%20mx6dq.ld%20(%E3%83%AA%E3%83%B3%E3%82%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88)%20%E3%81%AE%20GROUP(-lgcc%20-lc%20-lcs3arm%20-lcs3)%20%E3%81%AB%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGROUP%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%80%8CResetHandler%E3%80%8D%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82.jpg%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E4%BB%98%E5%B1%9E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ResetHandler_error.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ResetHandler_error.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36912iCF17A492275711F9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ResetHandler_error.jpg%22%20alt%3D%22ResetHandler_error.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EResetHandler_error.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BB%BA%E7%89%A9%E5%AF%BE%E8%B1%A1%3AProg_from_Integrating.elf%3C%2FP%3E%3CP%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%20Cross%20ARM%20C%20%E3%83%AA%E3%83%B3%E3%82%AB%3C%2FP%3E%3CP%3Earm-none-eabi-gcc%20--specs%3Drdimon.specs-lrdimon%20-mcpu%3Dcortex-a9%20-march%3Darmv7-a%20-marm%20-mlittle-endian%20-mfloat-abi%3Dsoftfp%20-mfpu%3Dneon%20-mno-unaligned-access%20-O0%20-fmessage-length%3D0%20-fsigned-char%20-ffunction-sections%20-fdata-sections%20-g3%20-t%20%22E%3A%5CKepler_Programs%5CProg_from_Integrating%5Cmx6dq.ld%22-nostartfiles%20-Wl%2C-map%2C%22Prog_from_Integrating.map%22-o%20%22Prog_from_Integrating.elf%22.%2Fmain.o%20%3C%2FP%3E%3CP%3EC%3A%2FProgram%20Files%20(x86)%2FGNU%20Tools%20Arm%20Embedded%2F4.9%202015Q3%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F4.9.3%2F..%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Fld.exe%3A%20%E8%AD%A6%E5%91%8A%3A%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%20Reset_Handler%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF%2000900000%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.%2Fmain.o%3A%E9%96%A2%E6%95%B0%20'start_secondary_cpu'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EE%3A%5CKepler_Programs%5CProg_from_Integrating%5CDebug%2F..%2Fmain.c%3A124%3A'Reset_Handler'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3EE%3A%5CKepler_Programs%5CProg_from_Integrating%5CDebug%2F..%2Fmain.c%3A124%3A'Reset_Handler'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Ecollect2.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ld%20%E3%81%8C%201%20%E3%81%A4%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emakefile%3A41%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'Prog_from_Integrating.elf'%20%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emake%3A%20***%20%5BProg_from_Integrating.elf%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3FGCC%20ARM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(Sourcery%20CodeBench%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FP%3E%3CP%3ESarang%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-17-2015 04:21 AM
更新者:
