mimxrt1170 spi status registers
1,035 次查看
sandeep_c
Hi everyone
iam developing driver ksz88751nsl  for ethernet by referring of existing sam microcontroller driver, for developing i havent found few information about spi status register registers as below are the which havent found in nxp datasheet if any one knows for this please revert me back
1) End of RX buffer
2) ) Receive Buffer Full Interrupt Enable
3) Receive Buffer Full Interrupt Disable
4) End of Receive Buffer Interrupt Enable
5) End of Receive Buffer Interrupt Disable
6)RX Buffer Full
iam using mimxrt1170
the provide status registers are in rt1170 are below but i need above flags if anyone knows any other way or similar flags available in diffrerent register in nxp controoler please help  me
Nxp spi register
MBF = Module Busy Flag
DMF = Data Match Flag
REF = Receive Error Flag
TEF = Transmit Error Flag
TCF = Transfer Complete Flag
FCF  = Frame Complete Flag
WCF =Word Complete Flag
RDF =Receive Data Flag
TDF =Transmit Data Flag
1,018 次查看
EdwinHz
Hi @sandeep_c,
Please look into the i.MX RT1170 Processor Reference Manual, specifically Chapter "70.5 Memory map and registers" for more information about the available registers and flags for our LPSPI module. If the register is not mentioned in this chapter, I'm afraid it isn't available for our LPSPI.
BR,
Edwin.
1,011 次查看
sandeep_c
thank you for your reply
i gone thorough that Chapter "70.5 Memory map and registers i didnt found the above register bits is there any other way to find
