migration from QualLite to Quad core
1,167 次查看
saida
HI
we have developed a hew board based I.MX6 DualLite and we want to upgrate to Quad core based processor
what are the precautions need to take ?
is both are pin to pin compatible ?
thanks and regards
Saida
标签 (2)
2 回复数
1,052 次查看
gusarambula
Hello Saida S,
The i.MX6DualLite and the i.MX6Quad are pin-to-pin compatible, provided that some design decisions are followed. You can see Application Note 4397 (link below) for more details.
https://www.nxp.com/docs/en/application-note/AN4397.pdf
The hardware requirements are in section 4 of the application note. Its recommended to design with the possibility to migrate to a smaller pin-to-pin compatible processor if you are interested in doing so at some point. If your design is done for the i.MX6Q it’s possible that you will need to make some layout changes if you didn’t follow the guidelines listed on the application note.
I hope this helps!
1,052 次查看
saida
thank you
i will come back to you once i done the changes for any queries
regards
saida
