maximum emmc supported by i.mx8
2,305件の閲覧回数
ZZ383
What is the maximum emmc supported by i.mx8 : MIMX8ML8CVNKZAB?
9 返答(返信)
2,004件の閲覧回数
pengyong_zhang
Hi @ZZ383
There is no address limitation with your EMMC, BTW, what is your EMMC vendor? and what is your EMMC name?
B.R
2,225件の閲覧回数
pengyong_zhang
Hi @ZZ383
you mean 4TB or 4Tb?
B.R
2,008件の閲覧回数
ZZ383
Hi @pengyong_zhang
Our requirement is 4Terabit=500Gigabyte.
Could you please check and let us know if i.mx8plus supports this in emmc5.1. will there be any addressing limitation with this max storage capacity.
2,006件の閲覧回数
ZZ383
Hi @pengyong_zhang
Our requirement is 4 Terabit=500Gigabyte.
2,266件の閲覧回数
pengyong_zhang
Hi @ZZ383
The iMX8MP supports eMMC Flash 5.1, which means all of the eMMCs of this generation (5.1) are supported.
What is your requirement for the capacity of EMMC?
B.R
2,233件の閲覧回数
ZZ383
Hi @pengyong_zhang
Our requirement is 4Tb.
2,163件の閲覧回数
pengyong_zhang
Hi @ZZ383
As i said before, As long as your EMMC follow the EMMC 5.1 Spec, It can works fine. But But we have only verified 32GB EMMC. So you need to check your EMMC datasheet by yourself.
B.R
2,204件の閲覧回数
gidame
JEDEC Standard No. 84-B51
2,203件の閲覧回数
gidame
@ZZ383 @pengyong_zhang
I'm ashamed of you as engineers.
Especially @ZZ383
