Hi @pengyong_zhang Our requirement is 4 Terabit=500Gigabyte. Could you please check and let us know if i.mx8plus supports this in emmc5.1. will there be any addressing limitation with this max storage capacity.
The iMX8MP supports eMMC Flash 5.1, which means all of the eMMCs of this generation (5.1) are supported. What is your requirement for the capacity of EMMC?
Hi @pengyong_zhang Our requirement is 4Tb. Could you please check and let us know if i.mx8plus supports this in emmc5.1. will there be any addressing limitation with this max storage capacity.
As i said before, As long as your EMMC follow the EMMC 5.1 Spec, It can works fine. But But we have only verified 32GB EMMC. So you need to check your EMMC datasheet by yourself.
