maximum emmc supported by i.mx8
985 次查看
ZZ383
What is the maximum emmc supported by i.mx8 : MIMX8ML8CVNKZAB?
9 回复数
684 次查看
pengyong_zhang
Hi @ZZ383
There is no address limitation with your EMMC, BTW, what is your EMMC vendor? and what is your EMMC name?
B.R
905 次查看
pengyong_zhang
Hi @ZZ383
you mean 4TB or 4Tb?
B.R
688 次查看
ZZ383
Hi @pengyong_zhang
Our requirement is 4Terabit=500Gigabyte.
Could you please check and let us know if i.mx8plus supports this in emmc5.1. will there be any addressing limitation with this max storage capacity.
686 次查看
ZZ383
Hi @pengyong_zhang
Our requirement is 4 Terabit=500Gigabyte.
946 次查看
pengyong_zhang
Hi @ZZ383
The iMX8MP supports eMMC Flash 5.1, which means all of the eMMCs of this generation (5.1) are supported.
What is your requirement for the capacity of EMMC?
B.R
913 次查看
ZZ383
Hi @pengyong_zhang
Our requirement is 4Tb.
843 次查看
pengyong_zhang
Hi @ZZ383
As i said before, As long as your EMMC follow the EMMC 5.1 Spec, It can works fine. But But we have only verified 32GB EMMC. So you need to check your EMMC datasheet by yourself.
B.R
884 次查看
gidame
JEDEC Standard No. 84-B51
883 次查看
gidame
@ZZ383 @pengyong_zhang
I'm ashamed of you as engineers.
Especially @ZZ383
