max supply current
max supply current
3,550 次查看
sapirbuz
can you please give me an example of how to calculate the maximum supply current? i didn't understand it from the picture below
NVCC_EMC(max curr)= 42*C*3.3*0.5F= 69.3CF
please help me estimate C and F
3,505 次查看
jingpan
Hi @sapirbuz ,
No, C couldn't be 4.9uF. It's impossible to push 42 4.9uF cap to 60M. Please refer to this post.
https://community.nxp.com/t5/i-MX-Processors/Question-i-MX6Solo-Max-supply-current/m-p/416445
Jing
6 回复数
3,542 次查看
jingpan
Hi @sapirbuz ,
C is the whole capacitor load on the pin group. You can add them all according to your design.
F is signal frequency. For example, if the pin group is for SDRAM, then take the SDRAM working frequency.
Jing
3,540 次查看
sapirbuz
This bank consists 42 pins, what freq should I choose?
what is the maximum freq?
3,531 次查看
jingpan
Hi @sapirbuz ,
This formula can help you to estimate maximum power consumption. It could not be very accurate. So, just use the highest frequency signal. For example, if the highest frequency signal in this group is a SPI, you can use the SPI bus frequency.
https://community.nxp.com/t5/i-MX-RT/RT1170-Max-Supply-Current-Calculation/td-p/1359582
Jing
3,526 次查看
sapirbuz
F= 60MHz (QSPI)
C= 4.9uF (according to eval board)
NVCC_EMC(max curr)= 42*C*3.3*0.5F= 69.3CF= 20374.2A?
what did i miss?
only for QSPI pins:
4*4.9u*3.3*0.5*60M= 1940A
it doesn't make sense
3,506 次查看
jingpan
Hi @sapirbuz ,
Jing
3,502 次查看
sapirbuz
thank you
