ltib cross compiler libxv-dev progra
2,621 次查看
cachegxp
I need to use ltib cross compiler, the # include <X11/extensions/Xvlib.h> This requires the use libxv-dev, but use Ltib compiled system, the library, how to do?...
标记 (2)
8 回复数
2,456 次查看
cachegxp
302-x11.JPGsudo find /-name Xvlib.h not find Xvlib.h file.
Xvlib.h is needed.
2,456 次查看
KrishnaPavan
Do one thing run
sudo find / -name Xvlib.h
and see if it's available.
By the Way, what is the software package that requires Xvlib.h?
2,456 次查看
cachegxp
libXext is there, but to no avail, I would like to need libXv, but no ltib...
2,456 次查看
KrishnaPavan
Hi cache gxp,
In configuration, go for X11 build options and check libXext.
Regards :: Krishna Pavan
2,456 次查看
cachegxp
 how installed Xext?
2,456 次查看
KrishnaPavan
Have you installed Xext?
If you even have sdl cross_compiled and installed, you will have that file.
What I don't understand is, whether you need that header file / library / what?
Regards :: KRISHNA PAVAN
2,456 次查看
cachegxp
X11 in the LTIB configuration not libxv
2,456 次查看
KrishnaPavan
Have you checked for X11 in the LTIB configuration!
