Dear Sir/Madam,
We booted the yocto generated core-image-minimal rootfs with NFS, but got the following error message for login:
imx6dlsabresd login: root
login: can't set groups: Operatio
Freescale i.MX Release Distro 3.14.52-1.1.1 imx6dlsabresd /dev/ttymxc0
I would appreciate any help how to solve this problem..
Best regards.
Mehmet Ali Ipin.
解決済! 解決策の投稿を見る。
Hi Mehmet
what bsp used in the case, please try with Demo Images described on below link
linux sources
Dear Igor,
Thank you for your helps, I downloaded image files and extracted fsl-image-validation-imx-xwayland-imxqpdlsolox.tar.bz2 files into my local directory and linked it to /tftpboot/root.
I got "VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: error mounting -2
Freeing unused kernel memory: 424K (80ae0000 - 80b4a000)
Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance" message.
If you know the solution, could you please tell me what and how to do? where the documentation/init.txt is located?
Thanks and best regards.
Mehmet Ali
Hi Mehmet
one can try to use linux documentation (in particular Linux Guide) on
Is it working without nfs, for example with sd.
Dear Igor,
I restarted nfs kernel server and everything worked. Now we have a linux working i.mx6 board.
Thank you so much.
with my best regards.
Hi Mehmet
linux sources
