install nodejs
install nodejs
2,629 次查看
davidvescovi
I have a working yocto build for the iMX8M mini evk with L5.4.24 and imx-image-full.
Is it possible to install the nodejs package?
2,617 次查看
b36401
You can add a layer to an image by adding following line to the conf/local.conf file inside the build directory:
IMAGE_INSTALL_append = “ nodejs”
