I'm running an application on IMX93 CM33 core and I'm using FLEXIO as the PWM output.
The PWM signal is working good, but our application scenario requires PWM output stop at some certain conditions while re-enable.
Is it possible to enable/disable the PWM output while still keeping the FLEXIO timer running?
