imx8ulp falcon image cannot burn
tangchao90
my branch is scarthgap-6.6.36-2.1.0
https://github.com/nxp-imx/meta-imx/tree/scarthgap-6.6.36-2.1.0
https://github.com/nxp-imx-support/meta-imx-fastboot/tree/lf-6.6.36-2.1.0
my board is
https://www.nxp.com/design/design-center/development-boards-and-designs/MCIMX8ULP-EVK?tid=vanimx8ulp...
According to the manual,MACHINE ??= 'imx8ulp-lpddr4-evk'  but the image can't burn,below is  the burn log. when i use branch imx_6.1.55_2.2.0, it can burn and start success,but i want to start quickly in falcon mode
U-Boot SPL 2024.04+gde16f4f1722+p0 (Sep 02 2024 - 10:44:35 +0000)
Normal Boot
ELE firmware version 1.2.0-4b189593
upower_apd_inst_isr: entry
upower_init: soc_id=48
upower_init: version:11.11.13
upower_init: start uPower RAM service
user_upwr_rdy_callb: soc=b
user_upwr_rdy_callb: RAM version:12.18
Turning on switches...
Turn on switches ok
Turning on memories...
Turn on memories ok
Clearing DDR retention...
Clear DDR retention ok
SEC0: RNG instantiated
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
tangchao90
my steps is below
1.  repo init -u https://github.com/nxp-imx/imx-manifest.git -b imx-linux-scarthgap -m imx-6.6.36-2.1.0.xml
2. repo sync
3. enter the source directory and
 git clone -b lf-6.6.36-2.1.0 https://github.com/nxp-imx-support/meta-imx-fastboot
4. DISTRO=fsl-imx-wayland MACHINE=imx8ulpevk source imx-setup-release.sh -b build
5. cd build and
bitbake-layers add-layer ../sources/meta-imx-fastboot
6. bitbake imx-image-full
but my imx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33  file size is 1224KB
i download from  https://www.nxp.com/webapp/Download?colCode=L6.6.36_2.1.0_MX8ULP&appType=license imx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33 file size is 1806KB
so my steps is not ok?
Manuel_Salas
Hello @tangchao90
I hope you are doing well.
Could you please clarify if you are following the AN14093?
Are you using other method?
Please, if possible share steps to reproduce the issue.
Salas.
tangchao90
my step is below:
2. repo sync
4. DISTRO=fsl-imx-wayland MACHINE=imx8ulp-lpddr4-evk source imx-setup-release.sh -b build
5. cd build and
6. bitbake imx-image-multimedia
after building , i can get image and burnin evk board
.\uuu.exe -b emmc_all .\imx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot_m33 .\imx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic
elena_popa
Hi @tangchao90
Are you using UUU to flash the image? If so, please use the commands marked as a solutions in this ticket: https://community.nxp.com/t5/i-MX-Processors/How-to-load-Falcon-mode-image-to-emmc-on-imx8mplus-dev-...
Elena
tangchao90
yes,  I use emmc flash and the command
uuu version is uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.182-0-ga561ed7
elena_popa
Hi @tangchao90
The commands sequence should be:
.\uuu.exe -b emmc_all <default_bootloader> .\imx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic
.\uuu.exe -b emmc <default_bootloader> <falcon_mode_bootloader>
The first uuu command writes the wic image using the default bootloader.
The second uuu command writes the bootloader with falcon mode enabled (<falcon_mode_bootloader>) using the default bootloader.
For easiness, you can take the default bootloader from here: https://www.nxp.com/webapp/Download?colCode=L6.6.36_2.1.0_MX8ULP&appType=license
Elena
tangchao90
oh , i understand you!  the <default_bootloader> is build without meta-imx-fastboot!
thank you
now my imx8ulp starts up with falcon image
tangchao90
my steps is below
2. repo sync
5. cd build and
%3CLINGO-SUB%20id%3D%22lingo-sub-2033703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2033703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emy%20branch%20is%20scarthgap-6.6.36-2.1.0%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmeta-imx%2Ftree%2Fscarthgap-6.6.36-2.1.0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmeta-imx%2Ftree%2Fscarthgap-6.6.36-2.1.0%20%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Ftree%2Flf-6.6.36-2.1.0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Ftree%2Flf-6.6.36-2.1.0%20%3C%2FA%3E%3C%2FP%3E%3CP%3Emy%20board%20is%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2FiMX8ULPEVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FMCIMX8ULP-EVK%3Ftid%3Dvanimx8ulpevk%3C%2FA%3E%3C%2FP%3E%3CP%3EAccording%20to%20the%20manual%EF%BC%8CMACHINE%20%3F%3F%3D%20'imx8ulp-lpddr4-evk'%26nbsp%3B%20but%20the%20image%20can't%20burn%EF%BC%8Cbelow%20is%26nbsp%3B%20the%20burn%20log.%20when%20i%20use%20branch%20imx_6.1.55_2.2.0%2C%20it%20can%20burn%20and%20start%20success%EF%BC%8Cbut%20i%20want%20to%20start%20quickly%20in%20falcon%20mode%26nbsp%3B%3C%2FP%3E%3CP%3EU-Boot%20SPL%202024.04%2Bgde16f4f1722%2Bp0%20(Sep%2002%202024%20-%2010%3A44%3A35%20%2B0000)%3CBR%20%2F%3ENormal%20Boot%3CBR%20%2F%3EELE%20firmware%20version%201.2.0-4b189593%3CBR%20%2F%3Eupower_apd_inst_isr%3A%20entry%3CBR%20%2F%3Eupower_init%3A%20soc_id%3D48%3CBR%20%2F%3Eupower_init%3A%20version%3A11.11.13%3CBR%20%2F%3Eupower_init%3A%20start%20uPower%20RAM%20service%3CBR%20%2F%3Euser_upwr_rdy_callb%3A%20soc%3Db%3CBR%20%2F%3Euser_upwr_rdy_callb%3A%20RAM%20version%3A12.18%3CBR%20%2F%3ETurning%20on%20switches...%3CBR%20%2F%3ETurn%20on%20switches%20ok%3CBR%20%2F%3ETurning%20on%20memories...%3CBR%20%2F%3ETurn%20on%20memories%20ok%3CBR%20%2F%3EClearing%20DDR%20retention...%3CBR%20%2F%3EClear%20DDR%20retention%20ok%3CBR%20%2F%3ESEC0%3A%20RNG%20instantiated%3CBR%20%2F%3ESPL%3A%20failed%20to%20boot%20from%20all%20boot%20devices%3CBR%20%2F%3E%23%23%23%20ERROR%20%23%23%23%20Please%20RESET%20the%20board%20%23%23%23%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2033703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eoh%20%2C%20i%20understand%20you!%26nbsp%3B%20the%26nbsp%3B%3CDEFAULT_BOOTLOADER%3E%20is%20build%20without%26nbsp%3Bmeta-imx-fastboot!%3C%2FDEFAULT_BOOTLOADER%3E%3C%2FP%3E%3CP%3Ethank%20you%3C%2FP%3E%3CP%3Enow%20my%20imx8ulp%20starts%20up%20with%20falcon%20image%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emy%20steps%20is%20below%3C%2FP%3E%3CP%3E1.%26nbsp%3B%26nbsp%3Brepo%20init%20-u%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FP%3E%3CP%3E2.%26nbsp%3Brepo%20sync%3C%2FP%3E%3CP%3E3.%20enter%20the%20source%20directory%20and%3C%2FP%3E%3CP%3E%26nbsp%3Bgit%20clone%20-b%20lf-6.6.36-2.1.0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%3C%2FA%3E%3C%2FP%3E%3CP%3E4.%26nbsp%3BDISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8ulpevk%20source%20imx-setup-release.sh%20-b%20build%3C%2FP%3E%3CP%3E5.%20cd%20build%20and%26nbsp%3B%3C%2FP%3E%3CP%3Ebitbake-layers%20add-layer%20..%2Fsources%2Fmeta-imx-fastboot%3C%2FP%3E%3CP%3E6.%20bitbake%26nbsp%3Bimx-image-full%3C%2FP%3E%3CP%3Ebut%20my%26nbsp%3Bimx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33%26nbsp%3B%20file%20size%20is%201224KB%3C%2FP%3E%3CP%3Ei%20download%20from%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%26amp%3B_gl%3D1*aabk6z*_ga*MzA4NTQ1ODAyLjE3MTk3OTYwODI.*_ga_WM5LE0KMSH*MTczODg5MTgwOS45OS4xLjE3Mzg4OTE5OTIuMC4wLjA.%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%3C%2FA%3E%26nbsp%3Bimx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33%20file%20size%20is%201806KB%3C%2FP%3E%3CP%3Eso%20my%20steps%20is%20not%20ok%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245983%22%20target%3D%22_blank%22%3E%40tangchao90%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20commands%20sequence%20should%20be%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E.%5Cuuu.exe%20-b%20emmc_all%20%3CDEFAULT_BOOTLOADER%3E%20.%5Cimx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic%0A%0A.%5Cuuu.exe%20-b%20emmc%20%3CDEFAULT_BOOTLOADER%3E%20%3CFALCON_MODE_BOOTLOADER%3E%3C%2FFALCON_MODE_BOOTLOADER%3E%3C%2FDEFAULT_BOOTLOADER%3E%3C%2FDEFAULT_BOOTLOADER%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EThe%20first%20uuu%20command%20writes%20the%20wic%20image%20using%20the%20%3CSTRONG%3Edefault%20bootloader%3C%2FSTRONG%3E.%3C%2FP%3E%0A%3CP%3EThe%20second%20uuu%20command%20writes%20the%20%3CSTRONG%3Ebootloader%20with%20falcon%20mode%20enabled%3C%2FSTRONG%3E%20(%3CFALCON_MODE_BOOTLOADER%3E)%20using%20the%20default%20bootloader.%3C%2FFALCON_MODE_BOOTLOADER%3E%3C%2FP%3E%0A%3CP%3EFor%20easiness%2C%20you%20can%20take%20the%20default%20bootloader%20from%20here%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%2C%3C%2FP%3E%0A%3CP%3EElena%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emy%20step%20is%20below%3A%3C%2FP%3E%3CP%3E1.%26nbsp%3B%26nbsp%3Brepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%3C%2FA%3E%20-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FP%3E%3CP%3E2.%26nbsp%3Brepo%20sync%3C%2FP%3E%3CP%3E3.%20enter%20the%20source%20directory%20and%3C%2FP%3E%3CP%3E%26nbsp%3Bgit%20clone%20-b%20lf-6.6.36-2.1.0%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%3C%2FA%3E%3C%2FP%3E%3CP%3E4.%26nbsp%3BDISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8ulp-lpddr4-evk%20source%20imx-setup-release.sh%20-b%20build%3C%2FP%3E%3CP%3E5.%20cd%20build%20and%26nbsp%3B%3C%2FP%3E%3CP%3Ebitbake-layers%20add-layer%20..%2Fsources%2Fmeta-imx-fastboot%3C%2FP%3E%3CP%3E6.%20bitbake%26nbsp%3Bimx-image-multimedia%3C%2FP%3E%3CP%3Eafter%20building%20%2C%20i%20can%20get%20image%20and%20burnin%20evk%20board%3C%2FP%3E%3CP%3E.%5Cuuu.exe%20-b%20emmc_all%20.%5Cimx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot_m33%20.%5Cimx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eyes%2C%26nbsp%3B%20I%20use%20emmc%20flash%20and%20the%20command%3C%2FP%3E%3CP%3E.%5Cuuu.exe%20-b%20emmc_all%20.%5Cimx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot_m33%20.%5Cimx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic%3C%2FP%3E%3CP%3Euuu%20version%20is%26nbsp%3Buuu%20(Universal%20Update%20Utility)%20for%20nxp%20imx%20chips%20--%20libuuu_1.4.182-0-ga561ed7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2034527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2034527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245983%22%20target%3D%22_blank%22%3E%40tangchao90%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAre%20you%20using%20UUU%20to%20flash%20the%20image%3F%20If%20so%2C%20please%20use%20the%20commands%20marked%20as%20a%20solutions%20in%20this%20ticket%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FHow-to-load-Falcon-mode-image-to-emmc-on-imx8mplus-dev-board-nxp%2Fm-p%2F2015307%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FHow-to-load-Falcon-mode-image-to-emmc-on-imx8mplus-dev-board-nxp%2Fm-p%2F2015307%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%2C%3C%2FP%3E%0A%3CP%3EElena%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2033983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8ulp%20falcon%20image%20cannot%20burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2033983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245983%22%20target%3D%22_blank%22%3E%40tangchao90%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECould%20you%20please%20clarify%20if%20you%20are%20following%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14093.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN14093%3C%2FA%3E%3F%3C%2FP%3E%0A%3CP%3EAre%20you%20using%20other%20method%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%2C%20if%20possible%20share%20steps%20to%20reproduce%20the%20issue.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E
