imx8ulp falcon image cannot burn
6,472件の閲覧回数
tangchao90
my branch is scarthgap-6.6.36-2.1.0
https://github.com/nxp-imx/meta-imx/tree/scarthgap-6.6.36-2.1.0
https://github.com/nxp-imx-support/meta-imx-fastboot/tree/lf-6.6.36-2.1.0
my board is
https://www.nxp.com/design/design-center/development-boards-and-designs/MCIMX8ULP-EVK?tid=vanimx8ulp...
According to the manual,MACHINE ??= 'imx8ulp-lpddr4-evk'  but the image can't burn,below is  the burn log. when i use branch imx_6.1.55_2.2.0, it can burn and start success,but i want to start quickly in falcon mode
U-Boot SPL 2024.04+gde16f4f1722+p0 (Sep 02 2024 - 10:44:35 +0000)
Normal Boot
ELE firmware version 1.2.0-4b189593
upower_apd_inst_isr: entry
upower_init: soc_id=48
upower_init: version:11.11.13
upower_init: start uPower RAM service
user_upwr_rdy_callb: soc=b
user_upwr_rdy_callb: RAM version:12.18
Turning on switches...
Turn on switches ok
Turning on memories...
Turn on memories ok
Clearing DDR retention...
Clear DDR retention ok
SEC0: RNG instantiated
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
6,316件の閲覧回数
tangchao90
my steps is below
1.  repo init -u https://github.com/nxp-imx/imx-manifest.git -b imx-linux-scarthgap -m imx-6.6.36-2.1.0.xml
2. repo sync
3. enter the source directory and
 git clone -b lf-6.6.36-2.1.0 https://github.com/nxp-imx-support/meta-imx-fastboot
4. DISTRO=fsl-imx-wayland MACHINE=imx8ulpevk source imx-setup-release.sh -b build
5. cd build and
bitbake-layers add-layer ../sources/meta-imx-fastboot
6. bitbake imx-image-full
but my imx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33  file size is 1224KB
i download from  https://www.nxp.com/webapp/Download?colCode=L6.6.36_2.1.0_MX8ULP&appType=license imx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33 file size is 1806KB
so my steps is not ok?
7 返答(返信)
6,444件の閲覧回数
Manuel_Salas
Hello @tangchao90
I hope you are doing well.
Could you please clarify if you are following the AN14093?
Are you using other method?
Please, if possible share steps to reproduce the issue.
Salas.
6,352件の閲覧回数
tangchao90
my step is below:
2. repo sync
4. DISTRO=fsl-imx-wayland MACHINE=imx8ulp-lpddr4-evk source imx-setup-release.sh -b build
5. cd build and
6. bitbake imx-image-multimedia
after building , i can get image and burnin evk board
.\uuu.exe -b emmc_all .\imx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot_m33 .\imx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic
6,419件の閲覧回数
elena_popa
Hi @tangchao90
Are you using UUU to flash the image? If so, please use the commands marked as a solutions in this ticket: https://community.nxp.com/t5/i-MX-Processors/How-to-load-Falcon-mode-image-to-emmc-on-imx8mplus-dev-...
Elena
6,354件の閲覧回数
tangchao90
yes,  I use emmc flash and the command
uuu version is uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.182-0-ga561ed7
6,330件の閲覧回数
elena_popa
Hi @tangchao90
The commands sequence should be:
.\uuu.exe -b emmc_all <default_bootloader> .\imx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic
.\uuu.exe -b emmc <default_bootloader> <falcon_mode_bootloader>
The first uuu command writes the wic image using the default bootloader.
The second uuu command writes the bootloader with falcon mode enabled (<falcon_mode_bootloader>) using the default bootloader.
For easiness, you can take the default bootloader from here: https://www.nxp.com/webapp/Download?colCode=L6.6.36_2.1.0_MX8ULP&appType=license
Elena
6,311件の閲覧回数
tangchao90
oh , i understand you!  the <default_bootloader> is build without meta-imx-fastboot!
thank you
now my imx8ulp starts up with falcon image
6,317件の閲覧回数
tangchao90
my steps is below
2. repo sync
5. cd build and
%3CLINGO-SUB%20id%3D%22lingo-sub-2033703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8ULP%20Falcon%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2033703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AFscarthgap-6.6.36-2.1.0%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmeta-imx%2Ftree%2Fscarthgap-6.6.36-2.1.0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmeta-imx%2Ftree%2Fscarthgap-6.6.36-2.1.0%20%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Ftree%2Flf-6.6.36-2.1.0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%2Ftree%2Flf-6.6.36-2.1.0%20%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2FiMX8ULPEVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FMCIMX8ULP-EVK%3Ftid%3Dvanimx8ulpevk%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81MACHINE%20%3F%3F%3D%20'IMX8ULP-LPDDR4-EVK'%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%94%BB%E5%83%8F%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%84%BC%E3%81%8D%E4%BB%98%E3%81%91%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81imx_6.1.55_2.2.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Falcon%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%81%B0%E3%82%84%E3%81%8F%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%88SPL%202024.04%20%2B%20GDE16f4f1722%20%2B%20p0(2024%E5%B9%B49%E6%9C%882%E6%97%A5%20-%2010%3A44%3A35%20%2B0000)%3CBR%20%2F%3E%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%96%E3%83%BC%E3%83%84%3CBR%20%2F%3EELE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.2.0-4b189593%3CBR%20%2F%3Eupower_apd_inst_isr%3A%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%3CBR%20%2F%3Eupower_init%3A%20soc_id%3D48%3CBR%20%2F%3Eupower_init%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A11.11.13%3CBR%20%2F%3Eupower_init%3AuPower%20RAM%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E9%96%8B%E5%A7%8B%3CBR%20%2F%3Euser_upwr_rdy_callb%3A%20soc%3Db%3CBR%20%2F%3Euser_upwr_rdy_callb%3ARAM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A12.18%3CBR%20%2F%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92ON%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BC%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B...%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BC%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%20OK%3CBR%20%2F%3EDDR%E3%83%AA%E3%83%86%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3EDDR%E3%81%AE%E4%BF%9D%E6%8C%81%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3ESEC0%3A%20RNG%20%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ESPL%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%23%23%23%20ERROR%20%23%23%23%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%23%23%23%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2033703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8ulp%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%BC%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%81%82%E3%80%81%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%9F!%20%3CDEFAULT_BOOTLOADER%3E%E3%81%AFmeta-imx-fastboot%E3%81%AA%E3%81%97%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FDEFAULT_BOOTLOADER%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81IMX8ULP%E3%81%8CFalcon%20Image%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8ulp%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%BC%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E1.%26nbsp%3B%26nbsp%3Brepo%20init%20-u%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FP%3E%3CP%3E2.%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%3C%2FP%3E%3CP%3E3.%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E5%85%A5%E3%82%8A%E3%80%81%3C%2FP%3E%3CP%3Egit%20clone%20-b%20lf-6.6.36-2.1.0%3CSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%3C%2FA%3E%3C%2FP%3E%3CP%3E4.%20DISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8ulpevk%20%E3%82%BD%E3%83%BC%E3%82%B9%20imx-setup-release.sh%20-b%20build%3C%2FP%3E%3CP%3E5.%20cd%20build%20%E3%81%A8%3C%2FP%3E%3CP%3Ebitbake-layers%20add-layer%20..%2Fsources%2Fmeta-imx-fastboot%3C%2FP%3E%3CP%3E6.%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AFIMX%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%95%E3%83%AB%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AEimx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF1224KB%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%26amp%3B_gl%3D1*aabk6z*_ga*MzA4NTQ1ODAyLjE3MTk3OTYwODI.*_ga_WM5LE0KMSH*MTczODg5MTgwOS45OS4xLjE3Mzg4OTE5OTIuMC4wLjA.%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%3C%2FA%3E%26nbsp%3Bimx-boot-imx8ulpevk-sd.bin-flash_singleboot_m33%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%201806KB%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AE%E6%AD%A9%E6%95%B0%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8ulp%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%BC%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245983%22%20target%3D%22_blank%22%3E%40tangchao90%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E.%5Cuuu.exe%20-b%20emmc_all%20%3CDEFAULT_BOOTLOADER%3E%20.%5Cimx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic%0A%0A.%5Cuuu.exe%20-b%20emmc%20%3CDEFAULT_BOOTLOADER%3E%20%3CFALCON_MODE_BOOTLOADER%3E%3C%2FFALCON_MODE_BOOTLOADER%3E%3C%2FDEFAULT_BOOTLOADER%3E%3C%2FDEFAULT_BOOTLOADER%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%20uuu%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%80%81%20%3CSTRONG%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20wic%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2%20%E7%95%AA%E7%9B%AE%E3%81%AE%20uuu%3CSTRONG%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20%E3%80%81falcon%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%3C%2FSTRONG%3E%20%3CFALCON_MODE_BOOTLOADER%3E()%20%E3%81%AB%E3%81%97%E3%81%9F%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FFALCON_MODE_BOOTLOADER%3E%3C%2FP%3E%0A%3CP%3E%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.36_2.1.0_MX8ULP%26amp%3BappType%3Dlicense%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3EElena%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8ulp%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%BC%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E1.%26nbsp%3B%26nbsp%3Brepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest.git%3C%2FA%3E%20-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%3C%2FP%3E%3CP%3E2.%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%3C%2FP%3E%3CP%3E3.%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E5%85%A5%E3%82%8A%E3%80%81%3C%2FP%3E%3CP%3Egit%20clone%20-b%20lf-6.6.36-2.1.0%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fmeta-imx-fastboot%3C%2FA%3E%3C%2FP%3E%3CP%3E4.%20DISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8ulp-lpddr4-evk%20%E3%82%BD%E3%83%BC%E3%82%B9%20imx-setup-release.sh%20-b%20build%3C%2FP%3E%3CP%3E5.%20cd%20build%20%E3%81%A8%3C%2FP%3E%3CP%3Ebitbake-layers%20add-layer%20..%2Fsources%2Fmeta-imx-fastboot%3C%2FP%3E%3CP%3E6.%20bitbake%20imx-image-multimedia%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%80%81EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A8%E3%83%90%E3%83%BC%E3%83%B3%E3%82%92%E5%BE%97%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E.%5Cuuu.exe%20-b%20emmc_all%20.%5Cimx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot_m33%20.%5Cimx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2038136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8ulp%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%BC%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%88%E3%81%88%E3%80%81%E7%A7%81%E3%81%AFemmc%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A8%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E.%5Cuuu.exe%20-b%20emmc_all%20.%5Cimx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot_m33%20.%5Cimx-image-multimedia-imx8ulp-lpddr4-evk.rootfs-20250124060345.wic%3C%2FP%3E%3CP%3Euuu%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%20nxp%20imx%20%E3%83%81%E3%83%83%E3%83%97%E7%94%A8%E3%81%AE%20uuu%20(Universal%20Update%20Utility)%20--%20libuuu_1.4.182-0-ga561ed7%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2034527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8ulp%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%BC%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2034527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245983%22%20target%3D%22_blank%22%3E%40tangchao90%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EUUU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%BB%E5%83%8F%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FHow-to-load-Falcon-mode-image-to-emmc-on-imx8mplus-dev-board-nxp%2Fm-p%2F2015307%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FHow-to-load-Falcon-mode-image-to-emmc-on-imx8mplus-dev-board-nxp%2Fm-p%2F2015307%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3EElena%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2033983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8ulp%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%BC%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2033983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245983%22%20target%3D%22_blank%22%3E%40tangchao90%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14093.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8CAN14093%3C%2FA%3E%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E4%BB%96%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E
