imx8qxp capture
imx8qxp capture
myy
We use imX8QXP platform, when we do not connect the camera with v4l2 application, the screen will appear purple stripes, how to solve?
Bio_TICFSL
Hello myy,
IT looks like a bad connection of the LCD, which LCD are your conecting? LVDS, HDMI...?Sorry you need to explain more about it.
myy
This does not look like a connection problem, normal use is no problem, when using the camera is prone to problems
Bio_TICFSL
Then is the camera in bad connection or you don't have the proper driver for it, the EVK works as it should.
