imx8qxp capture
imx8qxp capture
2,354 次查看
myy
We use imX8QXP platform, when we do not connect the camera with v4l2 application, the screen will appear purple stripes, how to solve?
标记 (1)
2,343 次查看
Bio_TICFSL
Hello myy,
IT looks like a bad connection of the LCD, which LCD are your conecting? LVDS, HDMI...?Sorry you need to explain more about it.
2,327 次查看
myy
This does not look like a connection problem, normal use is no problem, when using the camera is prone to problems
2,317 次查看
Bio_TICFSL
Then is the camera in bad connection or you don't have the proper driver for it, the EVK works as it should.
