imx8mp watchdog status regiser doesnt save its value on POR
686件の閲覧回数
shlomz
HI,
I added logic in u-boot for reading the wsr and every time the kernel panics and the watchdog causes a reset I can see the cause as POR and the wsr value is reset.
how can it retain its value?
thanks,
2 返答(返信)
667件の閲覧回数
Bio_TICFSL
You can't save the status of WDT, but make the kernel show a dmesg.
609件の閲覧回数
shlomz
the wd handling must be done at u-boot level to monitor the kernel boot process.
it appears that once the wd timer is set from u-boot (using defconfig and building the binary) the wd hw resets the kernel on panic and no wd driver function is involved
how is possible ro increment a boot counter based on kernel boot panics/failures ?
