the wd handling must be done at u-boot level to monitor the kernel boot process.
it appears that once the wd timer is set from u-boot (using defconfig and building the binary) the wd hw resets the kernel on panic and no wd driver function is involved
how is possible ro increment a boot counter based on kernel boot panics/failures ?
