imx8mp uart3/uart4 stop receive data after connect WIFI
1,402件の閲覧回数
dreamxjtu
hello,
    Our device peripherals are shown in the figure below. After the device is powered on, it automatically connects to Wi-Fi and establishes communication with modules A/B. However, after running for a period of time , the qt application program becomes unable to receive data from modules A/B via UART3/4, although it can still send data to them. The Wi-Fi connection remains normal. If the Qt application is killed and reloaded when this issue occurs, communication can be restored.The kernel version is 5.10.9. What might be the reason for this, and how can we troubleshoot and resolve the issue? Thank you.
[59040.102671] RTW: rtw_get_sta_tx_stat() not support
[59043.023763] RTW: rtw_get_sta_tx_stat() not support
[59046.024329] RTW: rtw_get_sta_tx_stat() not support
[59047.866380] ------------[ cut here ]------------
[59047.871251] WARNING: CPU: 0 PID: 80234 at /home/linuxpc/linux_opt/imx8mp_yocto/rtl8852BS/os_dep/linux/sdio_ops_linux.c:580 rtw_sdio_raw_read+0x1c4/0x2cc [8852bs]
[59047.885678] Modules linked in: iio_trig_hrtimer 8852bs(O) imx8_media_dev(C) cfg80211 st_accel_i2c st_sensors_i2c st_accel st_sensors ltr501 industrialio_triggered_buffer kfifo_buf ti_dac082s085 ch9434 ilitek_i2c snd_soc_tas5720 accel_gpio_irq cdc_ether usbnet ch343
[59047.909176] CPU: 0 PID: 80234 Comm: kworker/0:1 Tainted: G WC O 5.10.9-1.0.0+gc78c36e29 #1
[59047.918479] Hardware name: MYIR i.MX8MP BASE falcon mode (DT)
[59047.924229] Workqueue: events sdio_irq_work
[59047.928413] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--)
[59047.934655] pc : rtw_sdio_raw_read+0x1c4/0x2cc [8852bs]
[59047.940096] lr : rtw_sdio_raw_read+0x1bc/0x2cc [8852bs]
[59047.945319] sp : ffff80002adbbb50
[59047.948631] x29: ffff80002adbbb50 x28: 0000000000000000
[59047.953943] x27: 0000000000000000 x26: 0000000000000000
[59047.959254] x25: ffff0000c9d60000 x24: 0000000000000000
[59047.964566] x23: ffff0000c8782000 x22: 0000000000001f00
[59047.969877] x21: ffff0000c096dc00 x20: ffff0000c9d60000
[59047.975188] x19: 0000000000000400 x18: 0000000000000000
[59047.980499] x17: 0000000000000000 x16: 0000000000000000
[59047.985810] x15: 00000112000b9e70 x14: 0000000000000000
[59047.991121] x13: 0000000000000000 x12: 0000000000000000
[59047.996435] x11: 0000000000000000 x10: 0000000000000000
[59048.001745] x9 : 0000000000000000 x8 : 0000000000000080
[59048.007056] x7 : 000000000000007f x6 : 000000000000003d
[59048.012369] x5 : ffff0000ff13f000 x4 : 0000000000005f00
[59048.017681] x3 : 0000000000005f80 x2 : 0000000000000000
[59048.022992] x1 : 0000000000002300 x0 : 00000000ffffffac
[59048.028305] Call trace:
[59048.030985] rtw_sdio_raw_read+0x1c4/0x2cc [8852bs]
[59048.036085] sdio_io+0x198/0x31c [8852bs]
[59048.038236] tas5720 2-006c: failed to read FAULT register: -110
[59048.040311] rtw_sdio_read_cmd53+0x18/0x24 [8852bs]
[59048.051150] rtw_hal_mac_sdio_rx+0x70/0xe8 [8852bs]
[59048.056366] rtw_hal_sdio_rx+0x14/0x20 [8852bs]
[59048.061275] phl_recv_rxfifo_sdio+0x64/0x98 [8852bs]
[59048.066459] rtw_phl_interrupt_handler+0x58/0x198 [8852bs]
[59048.072161] sd_sync_int_hdl+0x40/0x5c [8852bs]
[59048.076694] process_sdio_pending_irqs+0x60/0x1b0
[59048.081397] sdio_irq_work+0x4c/0x80
[59048.084972] process_one_work+0x1cc/0x350
[59048.088981] worker_thread+0x13c/0x470
[59048.092728] kthread+0x154/0x160
[59048.095955] ret_from_fork+0x10/0x30
[59048.099529] ---[ end trace 1b34001a5e7a0146 ]---
[59048.104821] rtl8852bs mmc0:0001:1: rtw_sdio_raw_read: sdio read failed (-84)
[59048.112561] rtl8852bs mmc0:0001:1: RTW_SDIO: READ use CMD53
[59048.119384] rtl8852bs mmc0:0001:1: RTW_SDIO: READ from 0x01f00, 1024 bytes
[59048.126811] RTW_SDIO: READ 00000000: 13 02 20 80 52 00 06 10 4d 9c d9 be 04 00 20 00
[59048.135777] RTW_SDIO: READ 00000010: 16 00 a6 06 02 00 00 10 28 f5 2b 99 16 14 06 00
[59048.144064] RTW: ERROR sdio_io: read FAIL! error(-2) addr=0x01f00 1024 bytes, retry=0,0
[59048.153312] RTW: WARN sdio_io: Retry read addr=0x01f00 1024 bytes, retry=1,1
[59048.188477] RTW: sdio_io: Retry read OK! addr=0x01f00 1024 bytes, retry=1,1
[59048.195471] RTW: Data:
[59048.197953] RTW: F5 01 20 80 62 00 06 10 00 9E D9 BE 04 00 20 00
[59048.205125] RTW: 06 00 A7 06 02 00 00 10 28 F5 2B 99 16 14 06 00
[59048.212286] RTW: 08 42 00 00 01 00 5E 7F FF FA 84 65 69 89 34 80
[59048.219903] RTW: 54 F2 9F 73 92 28 70 6A 0A 2A C6 60 0E 00 00 00
[59048.226884] RTW: AA AA 03 00 00 00 08 00 45 00 01 BD B9 A7 40 00
[59048.234619] RTW: 04 11 FE 1F AC 1F 21 4F EF FF FF FA 69 AF 07 6C
[59048.241581] RTW: 01 A9 8D A4 4E 4F 54 49 46 59 20 2A 20 48 54 54
[59048.249276] RTW: 50 2F 31 2E 31 0D 0A 48 4F 53 54 3A 20 32 33 39
[59048.256437] RTW: 2E 32 35 35 2E 32 35 35 2E 32 35 30 3A 31 39 30
[59048.264191] RTW: 30 0D 0A 43 41 43 48 45 2D 43 4F 4E 54 52 4F 4C
[59048.271272] RTW: 3A 20 6D 61 78 2D 61 67 65 3D 36 36 0D 0A 4C 4F
[59048.279033] RTW: 43 41 54 49 4F 4E 3A 20 68 74 74 70 3A 2F 2F 31
[59048.286293] RTW: 37 32 2E 33 31 2E 33 33 2E 37 39 3A 34 39 31 35
[59048.293366] RTW: 32 2F 64 65 73 63 72 69 70 74 69 6F 6E 2E 78 6D
[59048.300946] RTW: 6C 0D 0A 4F 50 54 3A 20 22 68 74 74 70 3A 2F 2F
[59048.308553] RTW: 73 63 68 65 6D 61 73 2E 75 70 6E 70 2E 6F 72 67
[59048.315681] RTW: 2F 75 70 6E 70 2F 31 2F 30 2F 22 3B 20 6E 73 3D
[59048.322743] RTW: 30 31 0D 0A 30 31 2D 4E 4C 53 3A 20 30 34 34 30
[59048.330318] RTW: 31 34 62 30 2D 31 64 64 32 2D 31 31 62 32 2D 39
[59048.337345] RTW: 39 31 62 2D 66 35 31 33 37 36 31 32 61 36 66 33
[59048.344868] RTW: 0D 0A 4E 54 3A 20 75 72 6E 3A 6D 69 2D 63 6F 6D
[59048.351895] RTW: 3A 73 65 72 76 69 63 65 3A 52 43 6F 6E 74 72 6F
[59048.359480] RTW: 6C 6C 65 72 3A 31 0D 0A 4E 54 53 3A 20 73 73 64
[59048.366605] RTW: 70 3A 61 6C 69 76 65 0D 0A 53 45 52 56 45 52 3A
[59048.373766] RTW: 20 4C 69 6E 75 78 2F 34 2E 39 2E 31 31 33 20 48
[59048.380785] RTW: 54 54 50 2F 31 2E 30 0D 0A 58 2D 55 73 65 72 2D
[59048.388333] RTW: 41 67 65 6E 74 3A 20 72 65 64 73 6F 6E 69 63 0D
[59048.395367] RTW: 0A 55 53 4E 3A 20 75 75 69 64 3A 37 35 39 36 34
[59048.403003] RTW: 38 61 35 2D 36 30 33 64 2D 34 33 39 66 2D 61 61
[59048.410107] RTW: 62 31 2D 34 63 61 35 66 37 62 33 62 65 38 63 3A
[59048.417850] RTW: 3A 75 72 6E 3A 6D 69 2D 63 6F 6D 3A 73 65 72 76
[59048.424847] RTW: 69 63 65 3A 52 43 6F 6E 74 72 6F 6C 6C 65 72 3A
[59048.432460] RTW: 31 0D 0A 0D 0A 75 1B 2D 33 69 FF 92 1E 6D 7E 43
[59048.439480] RTW: 5B 41 AF DA 59 00 01 00 C0 00 80 01 62 00 06 00
[59048.447042] RTW: 00 00 00 00 01 00 20 00 01 00 F5 31 1F 00 01 00
[59048.454573] RTW: 03 00 00 00 00 00 00 00 8B 43 D9 12 08 00 00 00
[59048.461738] RTW: 00 00 00 00 29 12 B5 01 F9 0A 44 00 58 06 65 00
[59048.468786] RTW: 68 0C 12 00 00 00 00 00 00 00 2E 00 A6 0F E8 03
[59048.476332] RTW: 54 2A 93 08 00 00 00 00 00 00 00 00 00 00 00 00
[59048.483442] RTW: 00 00 00 00 00 00 EF 10 00 00 00 00 1F 2A 8E 5F
[59048.491079] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.498224] RTW: 00 00 00 00 00 00 00 00 02 00 00 00 AA 3E 02 00
[59048.505903] RTW: 8C 09 00 82 82 83 00 00 01 84 2A 34 35 08 90 00
[59048.513069] RTW: 2A 78 6D 09 05 FE FF FF 00 00 00 00 00 25 C0 5F
[59048.520627] RTW: 00 00 00 00 00 00 00 00 49 D5 07 00 00 00 00 00
[59048.527746] RTW: 38 B1 DF AE DF 00 FC E7 D4 F7 F9 F3 E4 F7 F7 BA
[59048.535373] RTW: 32 A0 A0 A0 A0 01 00 00 00 00 00 00 00 00 00 00
[59048.542504] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.550149] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.558420] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.565434] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.573175] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.580164] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.587831] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.594861] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.602530] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.609619] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.616821] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.624497] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.631565] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.638669] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.645707] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.652872] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59048.659914] RTW: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[59049.048296] RTW: rtw_get_sta_tx_stat() not support
[59052.025201] RTW: rtw_get_sta_tx_stat() not support
[59055.097082] RTW: rtw_get_sta_tx_stat() not support
[59058.024508] RTW: rtw_get_sta_tx_stat() not support
[59061.025913] RTW: rtw_get_sta_tx_stat() not support
[59064.046703] RTW: rtw_get_sta_tx_stat() not support
[59067.027795] RTW: rtw_get_sta_tx_stat() not support
[59070.100002] RTW: rtw_get_sta_tx_stat() not support
[59073.025578] RTW: rtw_get_sta_tx_stat() not support
[59076.027871] RTW: rtw_get_sta_tx_stat() not support
[59079.046137] RTW: rtw_get_sta_tx_stat() not support
[59082.024076] RTW: rtw_get_sta_tx_stat() not support
[59085.101821] RTW: rtw_get_sta_tx_stat() not support
[59088.026437] RTW: rtw_get_sta_tx_stat() not support
[59091.024759] RTW: rtw_get_sta_tx_stat() not support
[59094.046384] RTW: rtw_get_sta_tx_stat() not support
[59097.024395] RTW: rtw_get_sta_tx_stat() not support
[59100.099472] RTW: rtw_get_sta_tx_stat() not support
[59103.025388] RTW: rtw_get_sta_tx_stat() not support
[59106.025607] RTW: rtw_get_sta_tx_stat() not support
[59109.050832] RTW: rtw_get_sta_tx_stat() not support
[59112.025324] RTW: rtw_get_sta_tx_stat() not support
[59115.100097] RTW: rtw_get_sta_tx_stat() not support
[59118.028286] RTW: rtw_get_sta_tx_stat() not support
[59121.026007] RTW: rtw_get_sta_tx_stat() not support
[59124.048823] RTW: rtw_get_sta_tx_stat() not support
[59127.024156] RTW: rtw_get_sta_tx_stat() not support
[59130.101220] RTW: rtw_get_sta_tx_stat() not support
[59133.027155] RTW: rtw_get_sta_tx_stat() not support
[59136.024104] RTW: rtw_get_sta_tx_stat() not support
[59139.046445] RTW: rtw_get_sta_tx_stat() not support
[59142.023902] RTW: rtw_get_sta_tx_stat() not support
[59145.097767] RTW: rtw_get_sta_tx_stat() not support
[59148.024225] RTW: rtw_get_sta_tx_stat() not support
[59151.024542] RTW: rtw_get_sta_tx_stat() not support
[59154.046677] RTW: rtw_get_sta_tx_stat() not support
[59157.024188] RTW: rtw_get_sta_tx_stat() not support
[59160.100230] RTW: rtw_get_sta_tx_stat() not support
10 返答(返信)
1,326件の閲覧回数
dreamxjtu
hellio,
      The attached device tree is for the currently problematic device, confirmed to be LF5.10.9
1,285件の閲覧回数
Manuel_Salas
Hello @dreamxjtu
Thank you for sharing your files.
I could not find any device tree inconsistency, everything looks good.
Are you able to capture the UART signal with an scope or logic analyzer when this issue happens?
Also, please try to read the pinmux register with memtool when this issue is present.
Salas.
1,260件の閲覧回数
dreamxjtu
hello @Manuel_Salas
we have capture the UART3/4 TX/RX use a scope and logic analyzer when the issue happens.We found that the signals and data parsing are correct, with no abnormalities detected.
which pinmux register can we try to read?UART3/4 TX and RX?or other IO?
root@myd-jx8mp:/work/nfs/unit_tests# ./memtool -32 0x30330440 1
E
Reading 0x1 count starting at address 0x30330440
0x30330440: 00000140
root@myd-jx8mp:/work/nfs/unit_tests# ./memtool -32 0x30330444 1
E
Reading 0x1 count starting at address 0x30330444
0x30330444: 00000140
root@myd-jx8mp:/work/nfs/unit_tests# ./memtool -32 0x30330498 1
E
Reading 0x1 count starting at address 0x30330498
0x30330498: 00000140
root@myd-jx8mp:/work/nfs/unit_tests# ./memtool -32 0x3033049C 1
E
Reading 0x1 count starting at address 0x3033049C
0x3033049C: 00000140
root@myd-jx8mp:/work/nfs/unit_tests# cat /proc/tty/driver/IMX-uart
serinfo:1.0 driver revision:
0: uart:IMX mmio:0x30860000 irq:32 tx:49174 rx:4241 DSR|CD
1: uart:IMX mmio:0x30890000 irq:34 tx:227698 rx:78 RTS|DTR|DSR|CD
2: uart:IMX mmio:0x30880000 irq:33 tx:579 rx:417229256 brk:12 oe:287947352 RTS|DTR|DSR|CD
3: uart:IMX mmio:0x30A60000 irq:40 tx:279 rx:90046331 oe:62148529 RTS|DTR|DSR|CD
1,245件の閲覧回数
Manuel_Salas
Hello.
I refer to the below registers (IOMUX).
For UART3:
3033_01E0 (IOMUXC_SW_MUX_CTL_PAD_ECSPI1_SCLK)
3033_01E4 (IOMUXC_SW_MUX_CTL_PAD_ECSPI1_MOSI)
For UART4:
3033_0238 (IOMUXC_SW_MUX_CTL_PAD_UART4_RXD)
3033_023C (IOMUXC_SW_MUX_CTL_PAD_UART4_TXD)
It is very low probable that those change in this situation but just I want to be sure.
If those are correct while the issue, we need to focus in you QT application.
Salas.
1,205件の閲覧回数
dreamxjtu
hello @Manuel_Salas
in addition,we do a test In our QT application, reinitializing the serial port after detecting a communication abort can restore communication.
1,196件の閲覧回数
Manuel_Salas
If possible, please share the code where the serial communication is handled. (Regarding to the serial communication of UART3 and UART4).
Salas.
937件の閲覧回数
dreamxjtu
hello @Manuel_Salas
the follows is one uart code,maybe not the reseaon.because it have not happened after disconnecting the WIFI .
SerialPortInfo spInfo{"/dev/ttymxc3",
115200,
QSerialPort::DataBits::Data8,
QSerialPort::Parity::NoParity,
QSerialPort::StopBits::OneStop};
m_transceiver = std::make_shared<Transceiver>(spInfo);
connect(m_serialPtr.get(), &QSerialPort::readyRead,this, &Transceiver::SlotRcvData, Qt::QueuedConnection);// 读取数据
void Transceiver::SlotRcvData()
// 接收逻辑
QByteArray buffer = m_serialPtr->readAll();
if (!buffer.isEmpty())
for(const auto func : m_recvNoticeFuncs)
if (func)
func(std::move(buffer)); //回调通知上层,上传接收到数据帧
if ((DEBUG_PRINT_READ == 1 && m_serialPtr->portName() == DEBUG_PORT) || m_recvPrintFlag.load())
QString printStr = QString("Len(%1) ").arg(buffer.count());
printStr += buffer.toHex(' ');
qDebug(uart) << QString("%1-[%2 recv] <<= %3").arg(QDateTime::currentDateTime().toMSecsSinceEpoch()).arg(m_serialPtr->portName()).arg(printStr);
1,211件の閲覧回数
dreamxjtu
hello @Manuel_Salas
For UART3:
./memtool -32 0x303301E0 2
It appears that the configuration is correct.how to focus in our QT application?
Reading 0x2 count starting at address 0x303301E0
0x303301E0: 00000001 00000001
For UART4:
./memtool -32 0x30330238 2
Reading 0x2 count starting at address 0x30330238
0x30330238: 00000000 00000000
1,339件の閲覧回数
Manuel_Salas
Hello @dreamxjtu
I hope you are doing very well.
Could you pelase share your device tree?
And confirm you are using LF_5.10.9 (Kernel version).
Salas.
1,319件の閲覧回数
dreamxjtu
please see the files,thank you
imx8mp-pinfunc.h,myd-jx8mp.dtsi,myd-jx8mp.dtsi,myd-jx8mp-atk-10.dts
%3CLINGO-SUB%20id%3D%22lingo-sub-2180250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp%20uart3%2Fuart4%E3%81%AFWIFI%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%8F%97%E4%BF%A1%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AF%E4%B8%8B%E5%9B%B3%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%ABWi-Fi%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABA%2FB%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Qt%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AFUART3%2F4%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABA%2FB%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABA%2FB%E3%81%B8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%AFCAN%E3%81%A7%E3%81%99%E3%80%82Wi-Fi%E6%8E%A5%E7%B6%9A%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81Qt%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%BC%B7%E5%88%B6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%80%9A%E4%BF%A1%E3%81%8C%E5%9B%9E%E5%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF5.10.9%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ArronXi625_0-1759653397035.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ArronXi625_0-1759653397035.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359532i175448D0A293D5A0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ArronXi625_0-1759653397035.png%22%20alt%3D%22ArronXi625_0-1759653397035.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%5B59040.102671%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59043.023763%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59046.024329%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59047.866380%5D------------%5B%E3%81%93%E3%81%93%E3%81%A7%E3%82%AB%E3%83%83%E3%83%88%5D------------%3CBR%20%2F%3E%20%5B59047.871251%5D%E8%AD%A6%E5%91%8A%3A%20CPU%3A%200%20PID%3A%2080234%20at%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2FLinuxpc%2FLinux_opt%2Fimx8mp_yocto%2Frtl8852BS%2Fos_dep%2FLinux%2Fsdio_ops_Linux.c%3A580%20rtw_sdio_raw_read%2B0x1c4%2F0x2cc%20%5B8852bs%5D%3CBR%20%2F%3E%5B59047.885678%5D%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%20iio_trig_hrtimer%208852bs(O)%20imx8_media_dev(C)%20cfg80211%20st_accel_i2c%20st_sensors_i2c%20st_accel%20st_sensors%20ltr501%20industrialio_triggered_buffer%20kfifo_buf%20ti_dac082s085%20ch9434%20ilitek_i2c%20snd_soc_tas5720%20accel_gpio_irq%20cdc_ether%20usbnet%20ch343%3CBR%20%2F%3E%20%5B59047.909176%5DCPU%3A%200%20PID%3A%2080234%20%E9%80%9A%E4%BF%A1%3A%20kworker%2F0%3A1%20%E6%B1%9A%E6%9F%93%3A%20G%20WC%20O%205.10.9-1.0.0%2Bgc78c36e29%20%231%3CBR%20%2F%3E%20%5B59047.918479%5D%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%90%8D%3A%20MYIR%20i.MX8MP%20BASE%20%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%20(DT)%3CBR%20%2F%3E%20%5B59047.924229%5D%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%3A%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%20sdio_irq_work%3CBR%20%2F%3E%20%5B59047.928413%5Dpstate%3A%2040000005%20(nZcv%20daif%20-PAN%20-UAO%20-TCO%20BTYPE%3D--)%3CBR%20%2F%3E%20%5B59047.934655%5Dpc%20%3A%20rtw_sdio_raw_read%2B0x1c4%2F0x2cc%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59047.940096%5Dlr%20%3A%20rtw_sdio_raw_read%2B0x1bc%2F0x2cc%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59047.945319%5Dsp%20%3A%20ffff80002adbbb50%3CBR%20%2F%3E%20%5B59047.948631%5Dx29%3A%20ffff80002adbbb50%20x28%3A%200000000000000000%3CBR%20%2F%3E%20%5B59047.953943%5Dx27%3A%200000000000000000%20x26%3A%200000000000000000%3CBR%20%2F%3E%20%5B59047.959254%5Dx25%3A%20ffff0000c9d60000%20x24%3A%200000000000000000%3CBR%20%2F%3E%20%5B59047.964566%5Dx23%3A%20ffff0000c8782000%20x22%3A%200000000000001f00%3CBR%20%2F%3E%20%5B59047.969877%5Dx21%3A%20ffff0000c096dc00%20x20%3A%20ffff0000c9d60000%3CBR%20%2F%3E%20%5B59047.975188%5Dx19%3A%200000000000000400%20x18%3A%200000000000000000%3CBR%20%2F%3E%20%5B59047.980499%5Dx17%3A%200000000000000000%20x16%3A%200000000000000000%3CBR%20%2F%3E%20%5B59047.985810%5Dx15%3A%2000000112000b9e70%20x14%3A%200000000000000000%3CBR%20%2F%3E%20%5B59047.991121%5Dx13%3A%200000000000000000%20x12%3A%200000000000000000%3CBR%20%2F%3E%20%5B59047.996435%5Dx11%3A%200000000000000000%20x10%3A%200000000000000000%3CBR%20%2F%3E%20%5B59048.001745%5Dx9%20%3A%2000000000000000000%20x8%20%3A%2000000000000000080%3CBR%20%2F%3E%20%5B59048.007056%5Dx7%20%3A%200000000000000007f%20x6%20%3A%200000000000000003d%3CBR%20%2F%3E%20%5B59048.012369%5Dx5%20%3A%20ffff0000ff13f000%20x4%20%3A%2000000000000005f00%3CBR%20%2F%3E%20%5B59048.017681%5Dx3%20%3A%200000000000005f80%20x2%20%3A%200000000000000000%3CBR%20%2F%3E%20%5B59048.022992%5Dx1%20%3A%200000000000002300%20x0%20%3A%2000000000ffffffac%3CBR%20%2F%3E%20%5B59048.028305%5D%E9%80%9A%E8%A9%B1%E5%B1%A5%E6%AD%B4%3A%3CBR%20%2F%3E%20%5B59048.030985%5Drtw_sdio_raw_read%2B0x1c4%2F0x2cc%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.036085%5Dsdio_io%2B0x198%2F0x31c%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.038236%5Dtas5720%202-006c%3A%20FAULT%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20-110%3CBR%20%2F%3E%20%5B59048.040311%5Drtw_sdio_read_cmd53%2B0x18%2F0x24%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.051150%5Drtw_hal_mac_sdio_rx%2B0x70%2F0xe8%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.056366%5Drtw_hal_sdio_rx%2B0x14%2F0x20%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.061275%5Dphl_recv_rxfifo_sdio%2B0x64%2F0x98%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.066459%5Drtw_phl_interrupt_handler%2B0x58%2F0x198%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.072161%5Dsd_sync_int_hdl%2B0x40%2F0x5c%20%5B8852bs%5D%3CBR%20%2F%3E%20%5B59048.076694%5D%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9_sdio_pending_irqs%2B0x60%2F0x1b0%3CBR%20%2F%3E%20%5B59048.081397%5Dsdio_irq_work%2B0x4c%2F0x80%3CBR%20%2F%3E%20%5B59048.084972%5D%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9_one_work%2B0x1cc%2F0x350%3CBR%20%2F%3E%20%5B59048.088981%5D%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%2B0x13c%2F0x470%3CBR%20%2F%3E%20%5B59048.092728%5Dk%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%2B0x154%2F0x160%3CBR%20%2F%3E%20%5B59048.095955%5Dret_from_fork%2B0x10%2F0x30%3CBR%20%2F%3E%20%5B59048.099529%5D---%5B%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E7%B5%82%E4%BA%86%201b34001a5e7a0146%20%5D---%3CBR%20%2F%3E%20%5B59048.104821%5Drtl8852bs%20mmc0%3A0001%3A1%3A%20rtw_sdio_raw_read%3A%20sdio%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%A4%B1%E6%95%97%20(-84)%3CBR%20%2F%3E%20%5B59048.112561%5Drtl8852bs%20mmc0%3A0001%3A1%3A%20RTW_SDIO%3A%20READ%20%E4%BD%BF%E7%94%A8%20CMD53%3CBR%20%2F%3E%20%5B59048.119384%5Drtl8852bs%20mmc0%3A0001%3A1%3A%20RTW_SDIO%3A%200x01f00%E3%81%8B%E3%82%891024%E3%83%90%E3%82%A4%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%5B59048.126811%5DRTW_SDIO%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2000000000%3A%2013%2002%2020%2080%2052%2000%2006%2010%204d%209c%20d9%20be%2004%2000%2020%2000%3CBR%20%2F%3E%20%5B59048.135777%5DRTW_SDIO%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2000000010%3A%2016%2000%20a6%2006%2002%2000%2000%2010%2028%20f5%202b%2099%2016%2014%2006%2000%3CBR%20%2F%3E%20%5B59048.144064%5DRTW%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20sdio_io%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%A4%B1%E6%95%97!%20%E3%82%A8%E3%83%A9%E3%83%BC(-2)%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3D0x01f00%201024%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E5%86%8D%E8%A9%A6%E8%A1%8C%3D0%2C0%3CBR%20%2F%3E%20%5B59048.153312%5DRTW%3A%20%E8%AD%A6%E5%91%8A%20sdio_io%3A%20%E5%86%8D%E8%A9%A6%E8%A1%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3D0x01f00%201024%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E5%86%8D%E8%A9%A6%E8%A1%8C%3D1%2C1%3CBR%20%2F%3E%20%5B59048.188477%5DRTW%3A%20sdio_io%3A%20%E5%86%8D%E8%A9%A6%E8%A1%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8AOK!%20addr%3D0x01f00%201024%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E5%86%8D%E8%A9%A6%E8%A1%8C%3D1%2C1%3CBR%20%2F%3E%20%5B59048.195471%5DRTW%3A%20%E3%83%87%E3%83%BC%E3%82%BF%3A%3CBR%20%2F%3E%20%5B59048.197953%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%20F5%2001%2020%2080%2062%2000%2006%2010%2000%209E%20D9%20BE%2004%2000%2020%2000%3CBR%20%2F%3E%20%5B59048.205125%5DRTW%3A%2006%2000%20A7%2006%2002%2000%2000%2010%2028%20F5%202B%2099%2016%2014%2006%2000%3CBR%20%2F%3E%20%5B59048.212286%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2008%2042%2000%2000%2001%2000%205E%207F%20FF%20FA%2084%2065%2069%2089%2034%2080%3CBR%20%2F%3E%20%5B59048.219903%5DRTW%3A%2054%20F2%209F%2073%2092%2028%2070%206A%200A%202A%20C6%2060%200E%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.226884%5DRTW%3A%20AA%20AA%2003%2000%2000%2000%2008%2000%2045%2000%2001%20BD%20B9%20A7%2040%2000%3CBR%20%2F%3E%20%5B59048.234619%5DRTW%3A%2004%2011%20FE%201F%20AC%201F%2021%204F%20EF%20FF%20FF%20FA%2069%20AF%2007%206C%3CBR%20%2F%3E%20%5B59048.241581%5DRTW%3A%2001%20A9%208D%20A4%204E%204F%2054%2049%2046%2059%2020%202A%2020%2048%2054%2054%3CBR%20%2F%3E%20%5B59048.249276%5DRTW%3A%2050%202F%2031%202E%2031%200D%200A%2048%204F%2053%2054%203A%2020%2032%2033%2039%3CBR%20%2F%3E%20%5B59048.256437%5DRTW%3A%202E%2032%2035%2035%202E%2032%2035%2035%202E%2032%2035%2030%203A%2031%2039%2030%3CBR%20%2F%3E%20%5B59048.264191%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2030%200D%200A%2043%2041%2043%2048%2045%202D%2043%204F%204E%2054%2052%204F%204C%3CBR%20%2F%3E%20%5B59048.271272%5DRTW%3A%203A%2020%206D%2061%2078%202D%2061%2067%2065%203D%2036%2036%200D%200A%204C%204F%3CBR%20%2F%3E%20%5B59048.279033%5DRTW%3A%2043%2041%2054%2049%204F%204E%203A%2020%2068%2074%2074%2070%203A%202F%202F%2031%3CBR%20%2F%3E%20%5B59048.286293%5DRTW%3A%2037%2032%202E%2033%2031%202E%2033%2033%202E%2037%2039%203A%2034%2039%2031%2035%3CBR%20%2F%3E%20%5B59048.293366%5DRTW%3A%2032%202F%2064%2065%2073%2063%2072%2069%2070%2074%2069%206F%206E%202E%2078%206D%3CBR%20%2F%3E%20%5B59048.300946%5DRTW%3A%206C%200D%200A%204F%2050%2054%203A%2020%2022%2068%2074%2074%2070%203A%202F%202F%3CBR%20%2F%3E%20%5B59048.308553%5DRTW%3A%2073%2063%2068%2065%206D%2061%2073%202E%2075%2070%206E%2070%202E%206F%2072%2067%3CBR%20%2F%3E%20%5B59048.315681%5D%E5%BE%80%E5%BE%A9%3A%202F%2075%2070%206E%2070%202F%2031%202F%2030%202F%2022%203B%2020%206E%2073%203D%3CBR%20%2F%3E%20%5B59048.322743%5DRTW%3A%2030%2031%200D%200A%2030%2031%202D%204E%204C%2053%203A%2020%2030%2034%2034%2030%3CBR%20%2F%3E%20%5B59048.330318%5D%E5%BE%80%E5%BE%A9%3A%2031%2034%2062%2030%202D%2031%2064%2064%2032%202D%2031%2031%2062%2032%202D%2039%3CBR%20%2F%3E%20%5B59048.337345%5D%E5%88%B0%E7%9D%80%E4%BA%88%E5%AE%9A%E6%99%82%E5%88%BB%3A%2039%2031%2062%202D%2066%2035%2031%2033%2037%2036%2031%2032%2061%2036%2066%2033%3CBR%20%2F%3E%20%5B59048.344868%5DRTW%3A%200D%200A%204E%2054%203A%2020%2075%2072%206E%203A%206D%2069%202D%2063%206F%206D%3CBR%20%2F%3E%20%5B59048.351895%5DRTW%3A%203A%2073%2065%2072%2076%2069%2063%2065%203A%2052%2043%206F%206E%2074%2072%206F%3CBR%20%2F%3E%20%5B59048.359480%5DRTW%3A%206C%206C%2065%2072%203A%2031%200D%200A%204E%2054%2053%203A%2020%2073%2073%2064%3CBR%20%2F%3E%20%5B59048.366605%5DRTW%3A%2070%203A%2061%206C%2069%2076%2065%200D%200A%2053%2045%2052%2056%2045%2052%203A%3CBR%20%2F%3E%20%5B59048.373766%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2020%204C%2069%206E%2075%2078%202F%2034%202E%2039%202E%2031%2031%2033%2020%2048%3CBR%20%2F%3E%20%5B59048.380785%5DRTW%3A%2054%2054%2050%202F%2031%202E%2030%200D%200A%2058%202D%2055%2073%2065%2072%202D%3CBR%20%2F%3E%20%5B59048.388333%5DRTW%3A%2041%2067%2065%206E%2074%203A%2020%2072%2065%2064%2073%206F%206E%2069%2063%200D%3CBR%20%2F%3E%20%5B59048.395367%5DRTW%3A%200A%2055%2053%204E%203A%2020%2075%2075%2069%2064%203A%2037%2035%2039%2036%2034%3CBR%20%2F%3E%20%5B59048.403003%5D%E5%88%B0%E7%9D%80%E4%BA%88%E5%AE%9A%E6%99%82%E5%88%BB%3A%2038%2061%2035%202D%2036%2030%2033%2064%202D%2034%2033%2039%2066%202D%2061%2061%3CBR%20%2F%3E%20%5B59048.410107%5DRTW%3A%2062%2031%202D%2034%2063%2061%2035%2066%2037%2062%2033%2062%2065%2038%2063%203A%3CBR%20%2F%3E%20%5B59048.417850%5DRTW%3A%203A%2075%2072%206E%203A%206D%2069%202D%2063%206F%206D%203A%2073%2065%2072%2076%3CBR%20%2F%3E%20%5B59048.424847%5DRTW%3A%2069%2063%2065%203A%2052%2043%206F%206E%2074%2072%206F%206C%206C%2065%2072%203A%3CBR%20%2F%3E%20%5B59048.432460%5DRTW%3A%2031%200D%200A%200D%200A%2075%201B%202D%2033%2069%20FF%2092%201E%206D%207E%2043%3CBR%20%2F%3E%20%5B59048.439480%5DRTW%3A%205B%2041%20AF%20DA%2059%2000%2001%2000%20C0%2000%2080%2001%2062%2000%2006%2000%3CBR%20%2F%3E%20%5B59048.447042%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2000%2000%2000%2000%2001%2000%2020%2000%2001%2000%20F5%2031%201F%2000%2001%2000%3CBR%20%2F%3E%20%5B59048.454573%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2003%2000%2000%2000%2000%2000%2000%2000%208B%2043%20D9%2012%2008%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.461738%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2000%2000%2000%2000%2029%2012%20B5%2001%20F9%200A%2044%2000%2058%2006%2065%2000%3CBR%20%2F%3E%20%5B59048.468786%5DRTW%3A%2068%200C%2012%2000%2000%2000%2000%2000%2000%2000%202E%2000%20A6%200F%20E8%2003%3CBR%20%2F%3E%20%5B59048.476332%5DRTW%3A%2054%202A%2093%2008%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.483442%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2000%2000%2000%2000%2000%2000%20EF%2010%2000%2000%2000%2000%201F%202A%208E%205F%3CBR%20%2F%3E%20%5B59048.491079%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.498224%5D%E5%88%B0%E7%9D%80%3A%2000%2000%2000%2000%2000%2000%2000%2000%2002%2000%2000%2000%20AA%203E%2002%2000%3CBR%20%2F%3E%20%5B59048.505903%5DRTW%3A%208C%2009%2000%2082%2082%2083%2000%2000%2001%2084%202A%2034%2035%2008%2090%2000%3CBR%20%2F%3E%20%5B59048.513069%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%202A%2078%206D%2009%2005%20FE%20FF%20FF%2000%2000%2000%2000%2000%2025%20C0%205F%3CBR%20%2F%3E%20%5B59048.520627%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2000%2000%2000%2000%2000%2000%2000%2000%2049%20D5%2007%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.527746%5DRTW%3A%2038%20B1%20DF%20AE%20DF%2000%20FC%20E7%20D4%20F7%20F9%20F3%20E4%20F7%20F7%20BA%3CBR%20%2F%3E%20%5B59048.535373%5D%E5%88%B0%E7%9D%80%E6%99%82%E5%88%BB%3A%2032%20A0%20A0%20A0%20A0%2001%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.542504%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.550149%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.558420%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.565434%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.573175%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.580164%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.587831%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.594861%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.602530%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.609619%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.616821%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.624497%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.631565%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.638669%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.645707%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.652872%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59048.659914%5D%E5%88%B0%E7%9D%80%E6%99%82%E9%96%93%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B59049.048296%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59052.025201%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59055.097082%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59058.024508%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59061.025913%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59064.046703%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59067.027795%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59070.100002%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59073.025578%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59076.027871%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59079.046137%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59082.024076%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59085.101821%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59088.026437%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59091.024759%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59094.046384%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59097.024395%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59100.099472%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59103.025388%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59106.025607%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59109.050832%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59112.025324%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59115.100097%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59118.028286%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59121.026007%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59124.048823%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59127.024156%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59130.101220%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59133.027155%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59136.024104%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59139.046445%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59142.023902%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59145.097767%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59148.024225%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59151.024542%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59154.046677%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59157.024188%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B59160.100230%5DRTW%3A%20rtw_get_sta_tx_stat()%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2180250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%201%20%E3%81%A4%E3%81%AE%20UART%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82WIFI%20%E3%82%92%E5%88%87%E6%96%AD%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E6%83%85%E5%A0%B1%20spInfo%7B%22%2Fdev%2Fttymxc3%22%2C%3CBR%20%2F%3E%20115200%2C%20QSerialPort%3A%3ADataBits%3A%3AData8%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20QSerialPort%3A%3AParity%3A%3ANoParity%E3%80%81%3CBR%20%2F%3E%20QSerialPort%3A%3AStopBits%3A%3AOneStop%7D%3B%3CBR%20%2F%3E%20m_transceiver%20%3D%3CTRANSCEIVER%3E%20std%3A%3Amake_shared(spInfo)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20connect(m_serialPtr.get()%2C%20%26amp%3BQSerialPort%3A%3AreadyRead%2Cthis%2C%20%26amp%3BTransceiver%3A%3ASlotRcvData%2C%20Qt%3A%3AQueuedConnection)%3B%2F%2F%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20void%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%3A%3ASlotRcvData()%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%2F%2F%20%E5%8F%97%E4%BF%A1%E6%94%B6%E9%80%BB%E8%BE%91%3CBR%20%2F%3E%20QByteArray%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20%3D%20m_serialPtr-%26gt%3BreadAll()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20if%20(!buffer.isEmpty())%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20for(const%20auto%20func%20%3A%20m_recvNoticeFuncs)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20if%20(%E9%96%A2%E6%95%B0)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20func(std%3A%3Amove(buffer))%3B%20%2F%2F%E5%9B%9E%E8%B0%83%E9%80%9A%E7%9F%A5%E4%B8%8A%E5%B1%A4%E3%80%81%E4%B8%8A%E5%B1%A4%E3%83%87%E3%83%BC%E3%82%BF%E5%B8%A7%E5%8F%97%E4%BF%A1%7D%3CBR%20%2F%3E%20%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%20if%20((DEBUG_PRINT_READ%20%3D%3D%201%20%26amp%3B%26amp%3B%20m_serialPtr-%26gt%3BportName()%20%3D%3D%20DEBUG_PORT)%20%7C%7C%20m_recvPrintFlag.load())%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20QString%20printStr%20%3D%20QString(%22Len(%251)%20%22).arg(buffer.count())%3B%3CBR%20%2F%3EprintStr%20%2B%3D%20buffer.toHex('')%3B%3CBR%20%2F%3E%20qDebug(uart)%20%26lt%3B%26lt%3B%20QString(%22%20%251-%5B%25%202%20%E5%8F%97%E4%BF%A1%5D%20%26lt%3B%26lt%3B%3D%20%253%22).arg(QDateTime%3A%3AcurrentDateTime().toMSecsSinceEpoch()).arg(m_serialPtr-%26gt%3BportName()).arg(printStr)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3C%2FTRANSCEIVER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E9%80%9A%E4%BF%A1%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%EF%BC%88UART3%E3%81%A8UART4%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E9%80%9A%E4%BF%A1%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%EF%BC%89%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3CBR%20%2F%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81QT%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%80%9A%E4%BF%A1%E3%81%AE%E4%B8%AD%E6%96%AD%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%80%9A%E4%BF%A1%E3%82%92%E5%BE%A9%E5%85%83%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3CBR%20%2F%3E%20UART3%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%203033_01E0%20(IOMUXC_SW_MUX_CTL_PAD_ECSPI1_SCLK)%3CBR%20%2F%3E%203033_01E4%20(IOMUXC_SW_MUX_CTL_PAD_ECSPI1_MOSI)%3CBR%20%2F%3E%3CBR%20%2F%3E%20.%2Fmemtool-32%200x303301E0%202%3CBR%20%2F%3E%E6%A7%8B%E6%88%90%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82QT%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x303301E0%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E0x303301E0%3A%2000000001%2000000001%3CBR%20%2F%3E%3CBR%20%2F%3E%20UART4%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%203033_0238%20(IOMUXC_SW_MUX_CTL_PAD_UART4_RXD)%3CBR%20%2F%3E%203033_023C%20(IOMUXC_SW_MUX_CTL_PAD_UART4_TXD)%3CBR%20%2F%3E%3CBR%20%2F%3E%20.%2Fmemtool-32%200x30330238%202%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x30330238%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E0x30330238%3A%2000000000%2000000000%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%EF%BC%88IOMUX%EF%BC%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EUART3%E3%81%AE%E5%A0%B4%E5%90%88%3A%3C%2FP%3E%0A%3CP%3E3033_01E0%20(IOMUXC_SW_MUX_CTL_PAD_ECSPI1_SCLK)%3C%2FP%3E%0A%3CP%3E3033_01E4%20(IOMUXC_SW_MUX_CTL_PAD_ECSPI1_MOSI)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EUART4%E3%81%AE%E5%A0%B4%E5%90%88%3A%3C%2FP%3E%0A%3CP%3E3033_0238%20(IOMUXC_SW_MUX_CTL_PAD_UART4_RXD)%3C%2FP%3E%0A%3CP%3E3033_023C%20(IOMUXC_SW_MUX_CTL_PAD_UART4_TXD)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%89%E3%81%8C%E5%A4%89%E5%8C%96%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BD%8E%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%BF%B5%E3%81%AE%E3%81%9F%E3%82%81%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81QT%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3CBR%20%2F%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A8%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20UART3%2F4%20TX%2FRX%20%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BF%A1%E5%8F%B7%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%E8%A7%A3%E6%9E%90%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%80%81%E7%95%B0%E5%B8%B8%E3%81%AF%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%A9%E3%81%AE%20pinmux%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%20CAN%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FUART3%2F4%20TX%20%E3%81%8A%E3%82%88%E3%81%B3%20RX%20%E3%81%A7%E3%81%99%E3%81%8B%3F%20%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%BB%96%E3%81%AE%20IO%20%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%20root%40myd-jx8mp%3A%2Fwork%2Fnfs%2Funit_tests%23%20.%2Fmemtool-32%200x30330440%201%3CBR%20%2F%3E%20E%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x30330440%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x1%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%3CBR%20%2F%3E0x30330440%3A%2000000140%3CBR%20%2F%3E%3CBR%20%2F%3E%20root%40myd-jx8mp%3A%2Fwork%2Fnfs%2Funit_tests%23%20.%2Fmemtool-32%200x30330444%201%3CBR%20%2F%3E%20E%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x30330444%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x1%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E0x30330444%3A%2000000140%3CBR%20%2F%3E%3CBR%20%2F%3E%20root%40myd-jx8mp%3A%2Fwork%2Fnfs%2Funit_tests%23%20.%2Fmemtool-32%200x30330498%201%3CBR%20%2F%3E%20E%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x30330498%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x1%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%3CBR%20%2F%3E0x30330498%3A%2000000140%3CBR%20%2F%3E%3CBR%20%2F%3E%20root%40myd-jx8mp%3A%2Fwork%2Fnfs%2Funit_tests%23%20.%2Fmemtool-32%200x3033049C%201%3CBR%20%2F%3E%20E%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x3033049C%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x1%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%3CBR%20%2F%3E0x3033049C%3A%2000000140%3CBR%20%2F%3E%3CBR%20%2F%3E%20root%40myd-jx8mp%3A%2Fwork%2Fnfs%2Funit_tests%23%20cat%20%2Fproc%2Ftty%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2FIMX-uart%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E6%83%85%E5%A0%B1%3A1.0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3A%3CBR%20%2F%3E0%3A%20uart%3AIMX%20mmio%3A0x30860000%20irq%3A32%20tx%3A49174%20rx%3A4241%20DSR%7CCD%3CBR%20%2F%3E1%3A%20uart%3AIMX%20mmio%3A0x30890000%20irq%3A34%20tx%3A227698%20rx%3A78%20RTS%7CDTR%7CDSR%7CCD%3CBR%20%2F%3E2%3A%20uart%3AIMX%20mmio%3A0x30880000%20irq%3A33%20tx%3A579%20rx%3A417229256%20brk%3A12%20oe%3A287947352%20RTS%7CDTR%7CDSR%7CCD%3CBR%20%2F%3E3%3A%20uart%3AIMX%20mmio%3A0x30A60000%20irq%3A40%20tx%3A279%20rx%3A90046331%20oe%3A62148529%20RTS%7CDTR%7CDSR%7CCD%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F222458%22%20target%3D%22_blank%22%3E%40dreamxjtu%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20UART%20%E4%BF%A1%E5%8F%B7%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81memtool%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20pinmux%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3Eimx8mp-pinfunc.h%E3%80%81myd-jx8mp.dtsi%E3%80%81myd-jx8mp.dtsi%E3%80%81myd-jx8mp-atk-10.dts%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%E7%8F%BE%E5%9C%A8%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%82%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81LF5.10.9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20uart3%2Fuart4%20stop%20receive%20data%20after%20connect%20WIFI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F222458%22%20target%3D%22_blank%22%3E%40dreamxjtu%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3ELF_5.10.9%20(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3C%2FLINGO-BODY%3E
