imx8mp real-time-edge build fail
692 次查看
cuiyunxiao
破坏者
ERROR: harpoon-apps-zephyr-industrial-2.1-r0 do_fetch: Fetcher failure for URL: 'git://github.com/NXPmicro/zephyr.git;protocol=https;branch=feature/aarch64_support;destsuffix=git/zephyr;name=zephyr'. Unable to fetch URL from any source.
When i do fetch, it will fetch again at the end of fetch
and what is the mean of "destsuffix"
 thank you
658 次查看
Dhruvit
Hi @cuiyunxiao
I hope you are doing well.
->"destsuffix": The name of the path in which to place the checkout. By default, the path is git/.
->What command are you applying?
->Please make sure there is no firewall set because sometimes the firewall won't let our system fetch some data as it may be restricted.
->Please make sure to follow the steps mentioned in the user guide.
https://www.nxp.com/docs/en/user-guide/RTEDGEYOCTOUG_Rev2.4.pdf
Thanks & Regards,
Dhruvit Vasavada
