imx8mp-WOL
imx8mp-WOL
shivashanka141
Hi Nxp,
We are using imx8mp based SOC.
our BSP is based on kirkstone branch.
We have ethernet connected to eqos -> dp83867 & ethenet is functional.
WOL functionality is wokring fine. we are able to resume from suspend
imx8mp :
# ethtool -s eth1 wol g
#systemctl suspend
from any other machine in LAN we are able to trigger WOL packet
#wakeonlan <ethernet mac address >
after resuming from suspend ethernet was not functional found IP was not assiged to the phy.
DTS:
&eqos {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_eqos>;
phy-mode = "rgmii-id";
phy-handle = <&dp83867_1>;
snps,force_thresh_dma_mode;
snps,mtl-tx-config = <&mtl_tx_setup>;
snps,mtl-rx-config = <&mtl_rx_setup>;
status = "okay";
mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <1>;
#size-cells = <0>;
/* TODO : RESET needed
* TODO : IRQ   needed
dp83867_1: ethernet-phy@0 {
/* RGMII-1 */
compatible = "ethernet-phy-id2000.a231";
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_1_75_NS>;
ti,tx-internal-delay = <DP83867_RGMIIDCTL_1_75_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
ti,dp83867-rxctrl-strap-quirk;
interrupt-parent = <&gpio4>;
interrupts = <21 IRQ_TYPE_EDGE_FALLING>;
reset-gpio = <&gpio4 22 GPIO_ACTIVE_LOW>;
reset-assert-us = <10000>;
reset-deassert-us = <80000>;
After resuming from wake on lan IP is not assigned to phy.
Attached log for refernce.
IMX8MPLUS
Bio_TICFSL
Make sure that phy0 is the one as you can check the RGMII as phymode the Ethernet MAC controller node to which the PHY is connected. The phy-handle property links the controller to its corresponding PHY node.
%3CLINGO-SUB%20id%3D%22lingo-sub-2190782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp-WOL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Nxp%2C%3C%2FP%3E%3CP%3EWe%20are%20using%20imx8mp%20based%20SOC.%3C%2FP%3E%3CP%3Eour%20BSP%20is%20based%20on%26nbsp%3B%3CSPAN%3Ekirkstone%20branch.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWe%20have%20ethernet%20connected%20to%20eqos%20-%26gt%3B%20dp83867%20%26amp%3B%20ethenet%20is%20functional.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWOL%20functionality%20is%20wokring%20fine.%20we%20are%20able%20to%20resume%20from%20suspend%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3Eimx8mp%20%3A%3CBR%20%2F%3E%23%26nbsp%3Bethtool%20-s%20eth1%20wol%20g%3CBR%20%2F%3E%23systemctl%20suspend%3CBR%20%2F%3E%3CBR%20%2F%3Efrom%20any%20other%20machine%20in%20LAN%20we%20are%20able%20to%20trigger%20WOL%20packet%3CBR%20%2F%3E%23wakeonlan%20%3CETHERNET%20mac%3D%22%22%20address%3D%22%22%3E%3CBR%20%2F%3E%3CBR%20%2F%3Eafter%20resuming%20from%20suspend%20ethernet%20was%20not%20functional%20found%20IP%20was%20not%20assiged%20to%20the%20phy.%3CBR%20%2F%3E%3CBR%20%2F%3EDTS%3A%26nbsp%3B%3C%2FETHERNET%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%26amp%3Beqos%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-names%20%3D%20%22default%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_eqos%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-mode%20%3D%20%22rgmii-id%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Bdp83867_1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esnps%2Cforce_thresh_dma_mode%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esnps%2Cmtl-tx-config%20%3D%20%26lt%3B%26amp%3Bmtl_tx_setup%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esnps%2Cmtl-rx-config%20%3D%20%26lt%3B%26amp%3Bmtl_rx_setup%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emdio%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22snps%2Cdwmac-mdio%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20TODO%20%3A%20RESET%20needed%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20TODO%20%3A%20IRQ%26nbsp%3B%20%26nbsp%3Bneeded%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edp83867_1%3A%20ethernet-phy%400%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20RGMII-1%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22ethernet-phy-id2000.a231%22%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Crx-internal-delay%20%3D%20%3CDP83867_RGMIIDCTL_1_75_NS%3E%3B%3C%2FDP83867_RGMIIDCTL_1_75_NS%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Ctx-internal-delay%20%3D%20%3CDP83867_RGMIIDCTL_1_75_NS%3E%3B%3C%2FDP83867_RGMIIDCTL_1_75_NS%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Cfifo-depth%20%3D%20%3CDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3B%3C%2FDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Cmin-output-impedance%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Cdp83867-rxctrl-strap-quirk%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einterrupt-parent%20%3D%20%26lt%3B%26amp%3Bgpio4%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einterrupts%20%3D%20%26lt%3B21%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereset-gpio%20%3D%20%26lt%3B%26amp%3Bgpio4%2022%20GPIO_ACTIVE_LOW%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereset-assert-us%20%3D%20%26lt%3B10000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereset-deassert-us%20%3D%20%26lt%3B80000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAfter%20resuming%20from%20wake%20on%20lan%20IP%20is%20not%20assigned%20to%20phy.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EAttached%20log%20for%20refernce.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FIMX8MPLUS%2Fpd-p%2FIMX8MPLUS%22%20class%3D%22lia-product-mention%22%20data-product%3D%2221-1%22%20target%3D%22_blank%22%3EIMX8MPLUS%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2190782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp-WOL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EMake%20sure%20that%20phy0%20is%20the%20one%20as%20you%20can%20check%20the%20RGMII%20as%20phymode%20t%3CSPAN%20class%3D%22T286Pc%22%20data-sfc-cp%3D%22%22%20data-processed%3D%22true%22%3Ehe%20Ethernet%20MAC%20controller%20node%20to%20which%20the%20PHY%20is%20connected.%20The%20%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-processed%3D%22true%22%3Ephy-handle%3C%2FCODE%3E%20property%20links%20the%20controller%20to%20its%20corresponding%20PHY%20node.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22T286Pc%22%20data-sfc-cp%3D%22%22%20data-processed%3D%22true%22%3ERegards%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
