imx8mp-WOL
imx8mp-WOL
875 次查看
shivashanka141
Hi Nxp,
We are using imx8mp based SOC.
our BSP is based on kirkstone branch.
We have ethernet connected to eqos -> dp83867 & ethenet is functional.
WOL functionality is wokring fine. we are able to resume from suspend
imx8mp :
# ethtool -s eth1 wol g
#systemctl suspend
from any other machine in LAN we are able to trigger WOL packet
#wakeonlan <ethernet mac address >
after resuming from suspend ethernet was not functional found IP was not assiged to the phy.
DTS:
&eqos {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_eqos>;
phy-mode = "rgmii-id";
phy-handle = <&dp83867_1>;
snps,force_thresh_dma_mode;
snps,mtl-tx-config = <&mtl_tx_setup>;
snps,mtl-rx-config = <&mtl_rx_setup>;
status = "okay";
mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <1>;
#size-cells = <0>;
/* TODO : RESET needed
* TODO : IRQ   needed
dp83867_1: ethernet-phy@0 {
/* RGMII-1 */
compatible = "ethernet-phy-id2000.a231";
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_1_75_NS>;
ti,tx-internal-delay = <DP83867_RGMIIDCTL_1_75_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
ti,dp83867-rxctrl-strap-quirk;
interrupt-parent = <&gpio4>;
interrupts = <21 IRQ_TYPE_EDGE_FALLING>;
reset-gpio = <&gpio4 22 GPIO_ACTIVE_LOW>;
reset-assert-us = <10000>;
reset-deassert-us = <80000>;
After resuming from wake on lan IP is not assigned to phy.
Attached log for refernce.
IMX8MPLUS
848 次查看
Bio_TICFSL
Make sure that phy0 is the one as you can check the RGMII as phymode the Ethernet MAC controller node to which the PHY is connected. The phy-handle property links the controller to its corresponding PHY node.
%3CLINGO-SUB%20id%3D%22lingo-sub-2190782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp-WOL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8CNxp%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%20imx8mp%20%E7%9A%84%20SOC%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%20%E4%BB%A5%3CSPAN%3E%E6%9F%AF%E5%85%8B%E6%96%AF%E9%80%9A%3C%2FSPAN%3E%E5%88%86%E6%94%AF%E4%B8%BA%E5%9F%BA%E7%A1%80%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%BF%9E%E6%8E%A5%E5%88%B0%20eqos%20-%26gt%3B%20dp83867%26amp%3B%20ethenet%20%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWOL%20%E5%8A%9F%E8%83%BD%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BB%8E%E6%8C%82%E8%B5%B7%E7%8A%B6%E6%80%81%E6%81%A2%E5%A4%8D%3CBR%20%2F%3E%3CBR%20%2F%3E%20imx8mp%EF%BC%9A%3CBR%20%2F%3E%20%23%20ethtool-s%20eth1%20wol%20g%3CBR%20%2F%3E%20%23systemctl%20suspend%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E5%9C%A8%E5%B1%80%E5%9F%9F%E7%BD%91%E4%B8%AD%E7%9A%84%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E6%9A%82%E5%81%9C%20%E6%88%91%E4%BB%AC%E9%83%BD%E8%83%BD%E8%A7%A6%E5%8F%91%20WOL%20%E6%95%B0%E6%8D%AE%E5%8C%85%3CBR%20%2F%3E%20%23wakeonlan%3CETHERNET%20mac%3D%22%22%20address%3D%22%22%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E4%BB%8E%E6%8C%82%E8%B5%B7%E6%81%A2%E5%A4%8D%20%E5%90%8E%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E5%8F%91%E7%8E%B0%20IP%20%E6%9C%AA%E5%88%86%E9%85%8D%E7%BB%99%20phy%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EDTS%20%3C%2FETHERNET%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%26amp%3Beqos%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-names%20%3D%22%E9%BB%98%E8%AE%A4%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-0%20%3D%26lt%3B%26amp%3B%20pinctrl_eqos%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-mode%20%3D%22rgmii-id%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ephy-handle%20%3D%26lt%3B%26amp%3B%20dp83867_1%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esnps%EF%BC%8Cforce_thresh_dma_mode%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esnps%2Cmtl-tx-config%20%3D%26lt%3B%26amp%3B%20mtl_tx_setup%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esnps%2Cmtl-rx-config%20%3D%26lt%3B%26amp%3B%20mtl_rx_setup%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%22okay%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emdio%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%22snps%2Cdwmac-mdio%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23address-cells%20%3D%26lt%3B1%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23size-cells%20%3D%26lt%3B0%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E5%BE%85%E5%8A%9E%E4%BA%8B%E9%A1%B9%EF%BC%9A%E9%9C%80%E8%A6%81RESET%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20TODO%20%3A%20%E9%9C%80%E8%A6%81%20IRQ%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edp83867_1%3A%20ethernet-phy%400%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20RGMII-1%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%22ethernet-phy-id2000.a231%22%20%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%26lt%3B0%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Crx-internal-delay%20%3D%3CDP83867_RGMIIDCTL_1_75_NS%3E%20%EF%BC%9B%3C%2FDP83867_RGMIIDCTL_1_75_NS%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Ctx-internal-delay%20%3D%3CDP83867_RGMIIDCTL_1_75_NS%3E%20%EF%BC%9B%3C%2FDP83867_RGMIIDCTL_1_75_NS%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Cfifo-depth%20%3D%3CDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%20%EF%BC%9B%3C%2FDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%EF%BC%8C%E6%9C%80%E5%B0%8F%E8%BE%93%E5%87%BA%E9%98%BB%E6%8A%97%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eti%2Cdp83867-rxctrl-strap-quirk%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%B8%AD%E6%96%AD%E7%88%B6%E7%BA%A7%20%3D%26lt%3B%26amp%3B%20gpio4%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%B8%AD%E6%96%AD%20%3D%26lt%3B21%20IRQ_TYPE_EDGE_FALLING%26gt%3B%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereset-gpio%20%3D%20%26lt%3B%20%26amp%3B%20gpio4%2022%20GPIO_ACTIVE_LOW%20%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereset-assert-us%20%3D%20%26lt%3B10000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereset-deassert-us%20%3D%20%26lt%3B80000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%E4%BB%8E%20lan%20%E5%94%A4%E9%86%92%E6%81%A2%E5%A4%8D%E5%90%8E%EF%BC%8CIP%20%E6%B2%A1%E6%9C%89%E5%88%86%E9%85%8D%E7%BB%99%20phy%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%99%84%E4%B8%8A%E6%97%A5%E5%BF%97%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FIMX8MPLUS%2Fpd-p%2FIMX8MPLUS%22%20class%3D%22lia-product-mention%22%20data-product%3D%2221-1%22%20target%3D%22_blank%22%3EIMX8MPLUS%3C%2FA%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2190782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp-WOL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%98%AF%20phy0%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E4%BD%9C%E4%B8%BA%20phymode%20%E7%9A%84%20RGMII%EF%BC%8C%3CSPAN%20class%3D%22T286Pc%22%20data-sfc-cp%3D%22%22%20data-processed%3D%22true%22%3E%E5%8D%B3%20PHY%20%E6%89%80%E8%BF%9E%E6%8E%A5%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%20MAC%20%E6%8E%A7%E5%88%B6%E5%99%A8%E8%8A%82%E7%82%B9%E3%80%82%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-processed%3D%22true%22%3Ephy-handle%3C%2FCODE%3E%E5%B1%9E%E6%80%A7%E5%B0%86%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%8E%E5%85%B6%E5%AF%B9%E5%BA%94%E7%9A%84%20PHY%20%E8%8A%82%E7%82%B9%E7%9B%B8%E8%BF%9E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22T286Pc%22%20data-sfc-cp%3D%22%22%20data-processed%3D%22true%22%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
