[imx8mm] How to customize the partition layout of .sdcard file?
1,120 次查看
cherhow_na
I'm using imx8mm evk board, with Yocto Linux build.
I need the board using my partition layout after flashing the emmc using UUU.
Therefore, I want to customize the partition of the build out image "fsl-image-validation-imx-imx8mmevk.rootfs.sdcard".
Does anyone know which file need to be modified? Thanks.
标记 (1)
1,002 次查看
Rita_Wang
Could you tell us which version of linux BSP are you using?
