imx7d power up sequence issue
906 次查看
felixhsu
Hi All
Platform: i.MX7D with PF3000
Software: Linux 4.1.15.2.0.0
When power up the VLDO3V3 will have abnormal signal then pull high, why reason will bring abnormal signal?
How to fixed abnormal signal?
Thanks.
i.MX7D EVB
Customer board
标签 (3)
743 次查看
art
There is nothing abnormal here. The small initial voltage on the VLDO3V3 power rail is most likely caused by some current back leakage somewhere in the hardware. It should not affect the hardware functionality.
Artur
