imx6ul qt5 programming compile
1,911 次查看
fresxc
Hi All
    I want to compile a programming of HelloQt for imx6ul, the compiler is built by yocto. I use the way of https://community.nxp.com/docs/DOC-333580?commentID=40909#comment-40909 . When I compile helloqt program, the error following:
  /opt/fsl-imx-wayland/4.1.15-2.0.1/sysroots/cortexa7hf-neon-poky-linux-gnueabi/usr/include/qt5/QtCore/qglobal.h:39:21: fatal error: cstddef: no such file or directory.
   How can i fix it?  thanks!
    Best Regards
标签 (3)
1,497 次查看
joanxie
it seems the G++ issu, pls check if you configure the toolchain correctly or not
1,498 次查看
joanxie
1,497 次查看
fresxc
It works after I rechecked the configuration, thanks!
