imx6solosabresd bluetooth
4,461 次查看
li_hong
Hi Team,
I'm using Yocto project and I use imx6solosabresd as my platform.
I connect imx6 bluetooth with may phone,but the BluetoothSetting shows BT audio device.How to configure as a bluetooth device instead.
Thank you in advance.
5 回复数
4,302 次查看
wanbenzhou
where can i buy the board named   imx6solosabresd ??
4,302 次查看
joanxie
we only have imx6dl sabresd board for testing imx6S, but you couldn't order this from official website, maybe you can contact local DFAE to check , or buy the third party board as below:
i.MX 6Solo Applications Processors | Single Arm® Cortex®-A9 @ 1GHz | NXP
find the "application boards"
4,302 次查看
joanxie
do you want to transfer data, not audio, right? maybe you can try to transfer data to check if it works or not
4,302 次查看
li_hong
Yes,I want to transfer data o,but it's  considered as a audio device,so it can't transfer data. My problem is how to change the audio bt device to normal bt device.
4,302 次查看
joanxie
I don't have BT module to test for you, and I don't know what module you use, first you can refer to the two links, we have tested Broadcom BCM4339 on imx6DL sabresd board, and for transfer data, maybe you can try to run mmdc when transferring data
https://wireless.murata.com/products/rf-modules-1/wi-fi-bluetooth-for-nxp-i-mx.html#Linux
https://community.nxp.com/docs/DOC-94235
