imx6 mipi camera no 25fps
huangpeter
1.bsp linux 4.1.15
2.camera IC  tp2854
3.input D1 camera data fromat , Frame Start/End sent at each field VBLANK
4.imx6 capture yuv422 data is , and  fps is 12.5fps
5.iMX6DQ TP2854 MIPI CSI2 720P HD-TVI camera surround view solution for Linux BSP
joanxie
what's your issue? couldn't capture data with 25fps or playback ? could you give more detailed information, did  you use /mxc_v4l2_tvin.out?
