imx6sl PWM_backlight
1,532 次查看
narutos
Dear all:
I ran into a problem where PWM_backlight suddenly did not output while imx6sl was running, but I restarted the application and it returned to normal. Why?
标记 (2)
2 回复数
1,489 次查看
Zhiming_Liu
Is there any log? Does this issue only exist in your application? Can you test other application?
1,480 次查看
narutos
No logs, no other applications tested, but I think I've solved it, it should be into system hibernation
