imx6qdl-sabresd.dtsi syntax error issue
1,350 次查看
veeranjaneyulug
HI every one,
in imx6qdl-sabresd.dtsi file i need to change some code in place of volume up and volume down.I gave pir sensor and ntc sensor .But its giving synatx error .
        pir {
                        label = "pir sensor";
                        gpios = <&gpio1 4 1>;
                        gpio-key,wakeup;
                        linux,code = <KEY_PIRSENSOR >; //synatx error showing
                ntc {
                        label = "Ntc sensor";
                        gpios = <&gpio1 5 1>;
                        gpio-key,wakeup;
                        linux,code = <KEY_NTCSENSOR>; //synatx error showing
        pir {
                        gpio-key,wakeup;
                        linux,code = <KEY_VOLUMEUP >; //pir sensor for customboard
                ntc {
                        gpio-key,wakeup;
                        linux,code = <KEY_VOLUMEDOWN>; //ntc sensor for customboard
If i gave pir and ntc inplace of volumeup and volumedown keys .Its building .But i gave reverse its not building showing syntax error .
标签 (3)
909 次查看
alejandrolozan1
Have you checked that the KEY_PIRSENSOR and KEY_NTCSENSOR symbols are defined in a header file?
If not, it is expected to get a sintax error.
KEY_VOLUMEDOWN for example is defined in arch/arm/boot/dts/include/dt-bindings/input/input.h
Alejandro
