imx6q uses EIM bus to read fpga
1,088件の閲覧回数
yacheng_zhang
hi,
 i am testing im6q to read my fpga with device-tree way.i have some question.
1.how to set cs0 and cs1 at same time in device-tree.if i set cs0 and cs1 with MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0xb0b1,How does the kernel know I'm using CS0,
2.how to iomap fpga addr
can you give me some example code with device-tree to learn and solve this problem.thank you.
1,084件の閲覧回数
igorpadykov
Hi 亚成
for chip selects one can refer to sect.22.4 Chip Select Memory Map
i.MX 6Dual/6Quad Applications Processor Reference Manual
dts example and iomap in sect.3.2 EIM NOR  i.MX Linux Reference Manual​
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm/boot/dts/imx6qdl-sabreauto.dtsi?h...
