imx6q memory map.
imx6q memory map.
saqlainraza
Hello, I need to know the memory map i.e the starting and ending addresses of the RAM and ROM available on sabre lite imx6q board. Please guide me in this regard.
Thanks.
alejandrolozan1
Have you checked the RM? "Chapter 2 Memory Maps" . I wonder if you need something different.
Please let me know if you are looking for something else.
saqlainraza
Thanks for the response. I just want to know that what is the purpose of 256KB internal ram OCRAM available......
alejandrolozan1
The OCRAM can be used as normal RAM. You can create boot images that run in internal RAM instead of external RAM .
As long as the images fit into that memory area of course.
