imx28evk Yocto Krogoth refusing to generate uImage
1,604件の閲覧回数
edwardtyrrell
Senior Contributor I
I have a custom board based of the imx28evk using Yocto Krogoth 4.1.36 kernel and it's refusing to generate a uImage for the mfgtool. In my local.conf I have added KERNEL_IMAGETYPE = "uImage", I've cleansstated / -c complied -f / -c deployed / the kernel ( linux-fsl, virtual/kernel ) many times but always end up with a fresh zImage. Frustrating..
Any suggestions would be appreciated!
BR.
ラベル(3)
1,467件の閲覧回数
edwardtyrrell
Like usual after battling all day, post for an answer here and then crack the problem! For anyone else add KERNEL_IMAGETYPE = "uImage" to  => /meta-fsl-arm/conf/machine/imx28evk.conf
1,468件の閲覧回数
edwardtyrrell
